    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 404.5k Views 30 Watching
    • fredo6F Offline
      I would suggest that you, dear beta testers, post (almost) finished animations under this thread (as YouTube videos).
        • ntxdaveN Offline
          ntxdave
          Car Wash - Top Brush Demo
          Demo of a piece of car wash equipment (called Top Brush) that shows the car passing through the equipment and the animation of the equipment.
          Drone Demo
          My Drone demo showing animation and some camera positioning.
          • ntxdaveN Offline
            ntxdave
            Fredo6 I really like the rendered version. Nice to see this. Now I have to figure out how to afford one of the render engines. 😎 πŸ‘ πŸ‘
              • jiminy-billy-bobJ Offline
                jiminy-billy-bob
                How does it look like on a larger surface? πŸ˜„
                  I haven't figured out yet how to apply the movement to all instances. I thought if I animate one then do a Skatter the animation would inherit but it didn't.
                  More play time needed.... πŸ‘
                  • fredo6F Offline
                    If you embed the plant into a component, and then duplicate that frame component, then all of them should move the same.
                    • PixeroP Offline
                      Pixero
                      That's cool.
                      Will it be possible to animate the vertices with for example a sinus curve for some ambient motion of plants and leaves?
                      For components, is it possible with some random time adjustments so they don't move all exactly the same?
                      • JQLJ Offline
                        JQL
                        And animating proxies?
                        www.casca.pt
                        Visit us on facebook!
                          jiminy-billy-bob
                          I believe animated proxies is already possible in Vray (with vrmesh animated in another software)
                          • JQLJ Offline
                            JQL
                            I know what you're talking about, but I'm a Thea user... I just had an idea of what I'm going to try with Animator.
                            www.casca.pt
                            • soloS Offline
                              quick test using Thea, bit of a pain in the arse as thea only renders 7 frames at a time.
                              • ntxdaveN Offline
                                ntxdave
                                Solo - another good example of using a rendering engine in combination with Animator. I have Twilight-Hobby so I am going to have to step up to another rendering engine.
                                • soloS Offline
                                  @ntxdave said:
                                  Now if I could just find a way to animate the texture πŸ˜„
                                  Hope this gives some of you some other creative ideas.
                                  • ntxdaveN Offline
                                    ntxdave
                                    Do you know what is clicked at the 3 second mark?
                                    Is this a plugin that will allow you to create animated textures?
                                    • soloS Offline
                                      Not sure if it ever was released, Tavi (TBD) was the author.
                                      • ntxdaveN Offline
                                        ntxdave
                                        This is a work in progress but I am attempting to show how you can use scenes and layers to show/hide object in your animation.
                                        Scene/Layer Demo - click to view animation
                                        My ultimate goal is to be able to show water and foam spraying when a car is going through a car wash. In this one, I just made a stupid looking little object to represent the water spray.
                                        I will have to find a cleaner way to show the shape of the spray and a better texture to use for the water and foam.
                                        Anyway, the object here, as I said above, was to show that you can make objects show up and hide by altering which scenes and layers are visible during any part of the animation. If you watch, you will see that I added views at different points that capture the screen with different layers activated.
                                        • soloS Offline
                                          • ntxdaveN Offline
                                            ntxdave
                                            I found 2 in the Extension Warehouse that I will have to take a look at:
                                            Animatex by Renderiza
                                            Video Texture Plugin for SketchUp by Marc S
                                            • 1 / 6
