    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
      PituPhysics
      @anton_s said:
      Announcing 0.7.0: Change Log
      Here is a little turret with particle effects.
      OMG πŸ˜„ it's very cool. And good the innovation on UI dialog.
      I will try the "create_particle" function.
      • F Offline
        faust07
        Example turret works under Windows 7, SU16 make very good. But immediate BugSplat under Windows 8.1, SU16 make (have to test more). Smoke and fire are not reproduced in Replay. And ... if the velocity is too low, the sun will never shine again ... πŸ˜‰
        • F Offline
          faust07
          @PituPhysics: cool new MSPhysics models in 3D-Warehouse πŸ‘
          • F Offline
            faust07
            How does the added curve functions (similar to SketchyPhysics) work? Can't wait to see an example because my attempts to transform SP-scripts to MSP will take years...
              BallBearing
              At first glance MSPhysics working "mostly", nicely with SPGears & Linux SU8. When Using UI only simulation tab works on Linux / Wine.
              SketchUp, 3D printing stuff and more:
              http://www.youtube.com/user/CinemaTablet
                PituPhysics
                What exactly do you think? curve.skp
                • F Offline
                  faust07
                  Yes, this is exactly what I mean. Thank you very much! The first step to this:
                  path following bird
                    Anton_S
                    Hey faust, here is your birdy configured to work on MSPhysics and SketchyPhysics. I think it needs some adjustments though.
                    BirdTest01SUF.skp
                    • F Offline
                      faust07
                      Hey Anton, this is more than I could wish. It works excellent. Many thanks also to you!
                      For people who want to work with the unlimited possibilities of Physics scripts, such examples are fundamental.
                      In addition to the new capabilities of MSP, especially the transfer of SP to MSP is interesting for me because there are so many very good models and scripts. And when you look at this example, there are significant differences in the scripts. I would like to explore them in the near future ...
                      • F Offline
                        faust07
                        @Anton: cool new MSPhysics models in 3D-Warehouse - you linked in the first post πŸ‘
                        Magnets test, copyable joints, new turret with missiles, buoyancy with flow on water surface ... - impressive!
                          tomasz
                          Can we have an option to store Replay in a model, please?
                          • F Offline
                            faust07
                            And from Anton's TODO list - the fracture/split function and Twilight implementation. 😎
                              andychang28
                              Hey everyone, first post here. I have MSPhysics 0.4.0, and I have a model which I would like to use in a physics simulation. The model is a box with several protrusions and a few holes. When I run the simulation with show collision meshes enabled, the box's mesh is rendered as a box with all the empty spaces included, so objects hit the spaces between the protrusions instead of continuing through. Any help would be much appreciated!
                                SynSuka3D
                                I speak French
                                Excuse me my english
                                I want a body designated by name ? Please
                                I TEST get_"group_by_name(name) Does not work !!!
                                β˜€ ex: skechiphysics FindBodyName(NAME)...
                                  SynSuka3D
                                  findBody("name") and findGroupByName("name") ==> version MSPhysics ????, please.
                                    Ralphxyz
                                    Not knowing what I am doing I cannot get a good install!!
                                    ERRRORS:
                                    Error Loading File C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                                    Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                                    C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                    C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                    C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                                    C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                                    Thanks for the help.
                                      @Ralph
                                      The file:
                                      I not being found.
                                      I a proper installation it should be there.
                                      How did you install the files and subfolders ?
                                      Did you install the contents of both of the required ZIP files, keep the subfolder structure entirely as it is in the ZIP ?
                                      Do you actually have the missing file installed ?
                                      Open the Plugins folder and have a look...
                                      Compare the ZIP file's contents with what's in Plugins...
                                      All files are needed...
                                        Ralphxyz
                                        Thanks TIG, C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so is there!!
                                        There was no "installation" I just downloaded the zip file, unzipped and copied to the Plugins folder.
                                        The "missing" file msp_lib.so is the MSPhysics\win64\2.0 folder.
                                        I'll try again this time un zipping directly to the plugins folder possible something was missed with the copy paste but the reported missing file is there.
                                          Anton_S
                                          What windows version and sketchup are you using, Ralphxyz?
                                            Ralphxyz
                                            Windows 10 SketchUp 15 Pro
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 46
                                            • 47
                                            • 14 / 47
