    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • F
      faust07
      How does the added curve functions (similar to SketchyPhysics) work? Can't wait to see an example because my attempts to transform SP-scripts to MSP will take years...
      • B
        BallBearing
        At first glance MSPhysics working "mostly", nicely with SPGears & Linux SU8. When Using UI only simulation tab works on Linux / Wine.
        SketchUp, 3D printing stuff and more:
        http://www.youtube.com/user/CinemaTablet
        • P
          PituPhysics
          What exactly do you think? curve.skp
          • F
            faust07
            Yes, this is exactly what I mean. Thank you very much! The first step to this:
            path following bird
              Anton_S
              Hey faust, here is your birdy configured to work on MSPhysics and SketchyPhysics. I think it needs some adjustments though.
              BirdTest01SUF.skp
              • F
                faust07
                Hey Anton, this is more than I could wish. It works excellent. Many thanks also to you!
                For people who want to work with the unlimited possibilities of Physics scripts, such examples are fundamental.
                In addition to the new capabilities of MSP, especially the transfer of SP to MSP is interesting for me because there are so many very good models and scripts. And when you look at this example, there are significant differences in the scripts. I would like to explore them in the near future ...
                • F
                  faust07
                  @Anton: cool new MSPhysics models in 3D-Warehouse - you linked in the first post πŸ‘
                  Magnets test, copyable joints, new turret with missiles, buoyancy with flow on water surface ... - impressive!
                  • T
                    tomasz
                    Can we have an option to store Replay in a model, please?
                    • F
                      faust07
                      And from Anton's TODO list - the fracture/split function and Twilight implementation. 😎
                        andychang28
                        Hey everyone, first post here. I have MSPhysics 0.4.0, and I have a model which I would like to use in a physics simulation. The model is a box with several protrusions and a few holes. When I run the simulation with show collision meshes enabled, the box's mesh is rendered as a box with all the empty spaces included, so objects hit the spaces between the protrusions instead of continuing through. Any help would be much appreciated!
                          SynSuka3D
                          I speak French
                          Excuse me my english
                          I want a body designated by name ? Please
                          I TEST get_"group_by_name(name) Does not work !!!
                          β˜€ ex: skechiphysics FindBodyName(NAME)...
                            SynSuka3D
                            findBody("name") and findGroupByName("name") ==> version MSPhysics ????, please.
                              Ralphxyz
                              Not knowing what I am doing I cannot get a good install!!
                              ERRRORS:
                              Error Loading File C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                              Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                              C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                              C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                              C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                              C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                              Thanks for the help.
                                @Ralph
                                The file:
                                I not being found.
                                I a proper installation it should be there.
                                How did you install the files and subfolders ?
                                Did you install the contents of both of the required ZIP files, keep the subfolder structure entirely as it is in the ZIP ?
                                Do you actually have the missing file installed ?
                                Open the Plugins folder and have a look...
                                Compare the ZIP file's contents with what's in Plugins...
                                All files are needed...
                                  Ralphxyz
                                  Thanks TIG, C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so is there!!
                                  There was no "installation" I just downloaded the zip file, unzipped and copied to the Plugins folder.
                                  The "missing" file msp_lib.so is the MSPhysics\win64\2.0 folder.
                                  I'll try again this time un zipping directly to the plugins folder possible something was missed with the copy paste but the reported missing file is there.
                                    Anton_S
                                    What windows version and sketchup are you using, Ralphxyz?
                                      Ralphxyz
                                      Windows 10 SketchUp 15 Pro
                                        Anton_S
                                        SynSuka3D here are various ways to get bodies and groups in MSPhysics:
                                        • body = simulation.get_body_by_name(name)
                                        • body = simulation.get_body_by_group(group)
                                        • group = simulation.get_group_by_name(name)
                                        • group = this.get_group # get group by body
                                        See extended docs here: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Simulation
                                        Ralphxyz, it works on mine. It strange that it doesn't work on yours. Can you open MSPhysics/main.rb and uncomment #UI.messagebox info, on line 21. After you start SU a messagebox box should display with a list of libraries and their loaded IDs. Then post the library names that have their IDs set to zero if there's any. The ID of zero indicates that library failed to load.
                                          Ralphxyz
                                          "Error Loading File MSPhysics/main.rb
                                          Could not find included file 'MSPhysics/main.rb'
                                          I have main.rb in both MSPhysics folders but it is not found!!
                                            Anton_S
                                            Hey Ralphxyz,
                                            Okay, first of all, did you extract MSPhysics_0.7.0 into the plugins folder properly? You said you have main.rb in both MSPhysics folders, what do you mean by both? There should be only one MSPhysics folder in the plugins folder. And that one folder should be named "MSPhysics". Refer to the first post of this thread to see how the MSPhysics related content in the plugins folder should look. Please elaborate more if I misunderstood.
                                            Now, the error you just posted might also mean that you didn't uncomment the requested line in main.rb properly. Here is the main.rb file with the uncommented line. Place and overwrite the original file that is located in ../Plugins/MSPhysics/ folder. After you start Sketchup, a messagebox should appear listing all library names and their IDs. I would like you to post me at the forums which libraries appear with a zero ID (if any).
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 46
                                            • 47
                                            • 14 / 47
