    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • HornOxxH Offline
      HornOxx
      @box said:
      ...I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt...
      That´s a good hint and a nice example as well! (I thought of any new B & O speakers 😛 )
      Did you use the normal SU move tool for to snap and fix these exact points then?
      never trust a skinny cook
      • BoxB Offline
        It doesn't really matter how you arrive at the shapes, it's just a matter of using the crease tool to lock them in place.
        So if you draw a circle with the normal 24 sides and extrude and expand etc etc but crease the original border of the circle, the hole created by that circle even after subding will be the same as when you created it. So you can happily draw accurate sizes and keep them in the same piece as heavily deformed shapes. Which makes it easier for creating 3d printables.
        Mind you, there is no reason I couldn't make the fitting and the "mouth" shape separate pieces, and using the same logic mate them together perfectly via creasing.
          @optimaforever said:
          btw sometimes when I open a skp with a subd-ed mesh in it, the mesh is invisible (but it's definitely there, as you can select a hollow box and it becomes visible if you toggle the subdivision off)...
          Is there a fix for this? what causes this?
          Do you have such a model you can share?
          And the mesh isn't missing when you save? It could either be some extension that do something to the model when it saves. Or could it be a graphic card issue?
          Do you ever get a SUbD error dialog?
          • HornOxxH Offline
            HornOxx
            ... again a ... question:
            to get these topologies (Cut Face A and B), is there a specific tool or can I draw them the usual way with QFT line tool?
            ... that´s a good question and thanks for your useful picture - in 2D, these "curved direction changes" can be drawn with basic SU tools.
            As they are so useful, I´ll add them here if someone wants to use them as "instant groups" 😄
            Basic_Geometry1.skp
            • HornOxxH Offline
              HornOxx
              👍 thats good! thanks for this workflow
              just right click on the gif within your web page and copy the gif´s URL and paste it her - like you would post any other internet linked picture
              • HieruH Offline
                Hieru
                Here's my workflow for building them from scratch.
                https://media.giphy.com/media/TTgdzuMVNdQ1qNdmnYs/giphy.gif
                www.davidhier.co.uk
                • HieruH Offline
                  Hieru
                  Thanks 👍 . It's so obvious really....let's chalk it up to a senior moment.
                  www.davidhier.co.uk
                  • BoxB Offline
                    I was just fiddling around with this and thought it worth dropping in.
                    This is the funny horn from a few pages back. Rendered in Twilight.
                    http://i155.photobucket.com/albums/s296/storeben/SU/Funny Horn Doodle.jpg
                    • olisheaO Offline
                      olishea
                      that speaker-bowl thingy is extremely well modelled well done box
                      oli
                      • BoxB Offline
                        Cheers, Oli, I'm just getting my beginner bits in before you break the mold.
                          http://genevievejurgensen.blog50.com/media/01/00/271183208.jpg
                          • olisheaO Offline
                            olishea
                            lol don't know about that mate! great stuff! By break the mold I think you mean post some weird surrealist crap that doesn't really help anyone. 😄
                            oli
                            • BoxB Offline
                              Q: How many surrealists does it take to change a light bulb?
                              A: Fish.
                              • olisheaO Offline
                                olishea
                                PMSL!
                                what lightbulb it's just a molten blob of glass?!
                                On a serious note (if there is such a thing)....is there a multi-face offset for curved surfaces?
                                So like Tools On Surface offset that you can apply to several faces at once?
                                oli
                                  How would it differ from TOS?
                                  You mean something that preserves quads?
                                  • olisheaO Offline
                                    olishea
                                    I think you can only offset one face at a time with TOS? And multi face offset is coplanar faces only.
                                    I want to offset the lines from SubD....then you can JPP rails to form a complex shell that follows the SUbD topology.
                                    oli
                                    • olisheaO Offline
                                      olishea
                                      OK let's use Rich's model as example. Picture says a thousands words n all that....
                                      This would allow you to create "cages" for 3D printing etc. Hollowed out skeletons. 😄
                                      I want to offset every single quad like this with one click:
                                      And then JPP or other....
                                      oli
                                        Ah, yes - I see now. We like pictures. And I like your idea.
                                        Btw - the QFT issue tracker is public and a good way to file feature requests: https://bitbucket.org/thomthom/quadface-tools/issues?status=new%26amp;status=open
                                        • olisheaO Offline
                                          olishea
                                          Great!
                                          Also is an edge direction procedural out of the question? It can make the edge flow turn through 45 degrees. Then you could achieve a really funky cage!
                                          See this 3DSMax video at 4:40 to see what I mean.
                                          Thanks I'll be frequenting the QFT issue tracker 😄
                                          oli
                                            Thanks. Once SUbD migrates to OpenSubdiv I'll turn my focus to Vertex Tools and QFT for improving the modelling tools. References like that are great to have (please include them in feature requests in the issue tracker.)
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 82
                                            • 83
                                            • 21 / 83
