    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.4m Views 79 Watching
    • cottyC Offline
      cotty
      It's not my topic, it's a great community topic... ๐Ÿ˜‰
      my SketchUp gallery
      • O Offline
        optimaforever
        btw sometimes when I open a skp with a subd-ed mesh in it, the mesh is invisible (but it's definitely there, as you can select a hollow box and it becomes visible if you toggle the subdivision off)...
        Is there a fix for this? what causes this?
        • olisheaO Offline
          olishea
          My Sub D experimentation is under way ๐Ÿ˜„
          oli
          • BoxB Offline
            I've notice a few people I have talked to and read in some post that there is a misconception that SubD isn't well suited to accurate or specific dimensions.
            I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt.
            This is all one piece and is a solid.
            Proxymouth 40mm.skp
              Cool result! ๐Ÿ˜Ž
              What is the render engine used ?
              • BoxB Offline
                Twilight Hobby.
                • HornOxxH Offline
                  HornOxx
                  @box said:
                  ...I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt...
                  Thatยดs a good hint and a nice example as well! (I thought of any new B & O speakers ๐Ÿ˜› )
                  Did you use the normal SU move tool for to snap and fix these exact points then?
                  never trust a skinny cook
                  • BoxB Offline
                    It doesn't really matter how you arrive at the shapes, it's just a matter of using the crease tool to lock them in place.
                    So if you draw a circle with the normal 24 sides and extrude and expand etc etc but crease the original border of the circle, the hole created by that circle even after subding will be the same as when you created it. So you can happily draw accurate sizes and keep them in the same piece as heavily deformed shapes. Which makes it easier for creating 3d printables.
                    Mind you, there is no reason I couldn't make the fitting and the "mouth" shape separate pieces, and using the same logic mate them together perfectly via creasing.
                      Do you have such a model you can share?
                      And the mesh isn't missing when you save? It could either be some extension that do something to the model when it saves. Or could it be a graphic card issue?
                      Do you ever get a SUbD error dialog?
                      • HornOxxH Offline
                        HornOxx
                        ... again a ... question:
                        to get these topologies (Cut Face A and B), is there a specific tool or can I draw them the usual way with QFT line tool?
                        ... thatยดs a good question and thanks for your useful picture - in 2D, these "curved direction changes" can be drawn with basic SU tools.
                        As they are so useful, Iยดll add them here if someone wants to use them as "instant groups" ๐Ÿ˜„
                        Basic_Geometry1.skp
                        • HornOxxH Offline
                          HornOxx
                          ๐Ÿ‘ thats good! thanks for this workflow
                          just right click on the gif within your web page and copy the gifยดs URL and paste it her - like you would post any other internet linked picture
                          • HieruH Offline
                            Hieru
                            Here's my workflow for building them from scratch.
                            https://media.giphy.com/media/TTgdzuMVNdQ1qNdmnYs/giphy.gif
                            www.davidhier.co.uk
                            • HieruH Offline
                              Hieru
                              Thanks ๐Ÿ‘ . It's so obvious really....let's chalk it up to a senior moment.
                              www.davidhier.co.uk
                              • BoxB Offline
                                I was just fiddling around with this and thought it worth dropping in.
                                This is the funny horn from a few pages back. Rendered in Twilight.
                                http://i155.photobucket.com/albums/s296/storeben/SU/Funny Horn Doodle.jpg
                                • olisheaO Offline
                                  olishea
                                  that speaker-bowl thingy is extremely well modelled well done box
                                  oli
                                  • BoxB Offline
                                    Cheers, Oli, I'm just getting my beginner bits in before you break the mold.
                                      ๐Ÿ˜Ž
                                      http://genevievejurgensen.blog50.com/media/01/00/271183208.jpg
                                      • olisheaO Offline
                                        olishea
                                        lol don't know about that mate! great stuff! By break the mold I think you mean post some weird surrealist crap that doesn't really help anyone. ๐Ÿ˜„
                                        oli
                                        • BoxB Offline
                                          Q: How many surrealists does it take to change a light bulb?
                                          A: Fish.
                                          • olisheaO Offline
                                            olishea
                                            PMSL!
                                            what lightbulb it's just a molten blob of glass?!
                                            On a serious note (if there is such a thing)....is there a multi-face offset for curved surfaces?
                                            So like Tools On Surface offset that you can apply to several faces at once?
                                            oli
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 83
                                            • 84
                                            • 20 / 84
