    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • aarondietzenA Offline
      aarondietzen
      @thomthom said:
      Just waiting for the minion to become SketchUp's "teapot". πŸ˜„
      "Imagination is more important than knowledge..."
      - Albert Einstein
      • HornOxxH Offline
        HornOxx
        @pilou said:
        That is excellent! 😎
        @box said:
        I blame that Hornie Ox up there.
        @thomthom said:
        Just waiting for the minion to become SketchUp's "teapot". πŸ˜„ ...
        πŸ‘
        @aarondietzen said:
        πŸ‘ πŸ‘ πŸ’š
        Thanks, to all of you posting SubD-stuff & knowledge here in CottyΒ΄s great thread
        @Box - on your Manifold model, somewhere up there, I have broken my teeth !!! πŸ˜›
        never trust a skinny cook
        • cottyC Offline
          cotty
          It's not my topic, it's a great community topic... πŸ˜‰
          my SketchUp gallery
          • O Offline
            optimaforever
            btw sometimes when I open a skp with a subd-ed mesh in it, the mesh is invisible (but it's definitely there, as you can select a hollow box and it becomes visible if you toggle the subdivision off)...
            Is there a fix for this? what causes this?
            • olisheaO Offline
              olishea
              My Sub D experimentation is under way πŸ˜„
              oli
              • BoxB Offline
                I've notice a few people I have talked to and read in some post that there is a misconception that SubD isn't well suited to accurate or specific dimensions.
                I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt.
                This is all one piece and is a solid.
                Proxymouth 40mm.skp
                  Cool result! 😎
                  What is the render engine used ?
                  • BoxB Offline
                    Twilight Hobby.
                    • HornOxxH Offline
                      HornOxx
                      @box said:
                      ...I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt...
                      ThatΒ΄s a good hint and a nice example as well! (I thought of any new B & O speakers πŸ˜› )
                      Did you use the normal SU move tool for to snap and fix these exact points then?
                      • BoxB Offline
                        It doesn't really matter how you arrive at the shapes, it's just a matter of using the crease tool to lock them in place.
                        So if you draw a circle with the normal 24 sides and extrude and expand etc etc but crease the original border of the circle, the hole created by that circle even after subding will be the same as when you created it. So you can happily draw accurate sizes and keep them in the same piece as heavily deformed shapes. Which makes it easier for creating 3d printables.
                        Mind you, there is no reason I couldn't make the fitting and the "mouth" shape separate pieces, and using the same logic mate them together perfectly via creasing.
                          Do you have such a model you can share?
                          And the mesh isn't missing when you save? It could either be some extension that do something to the model when it saves. Or could it be a graphic card issue?
                          Do you ever get a SUbD error dialog?
                          • HornOxxH Offline
                            HornOxx
                            ... again a ... question:
                            to get these topologies (Cut Face A and B), is there a specific tool or can I draw them the usual way with QFT line tool?
                            ... thatΒ΄s a good question and thanks for your useful picture - in 2D, these "curved direction changes" can be drawn with basic SU tools.
                            As they are so useful, IΒ΄ll add them here if someone wants to use them as "instant groups" πŸ˜„
                            Basic_Geometry1.skp
                            • HornOxxH Offline
                              HornOxx
                              πŸ‘ thats good! thanks for this workflow
                              just right click on the gif within your web page and copy the gifΒ΄s URL and paste it her - like you would post any other internet linked picture
                              • HieruH Offline
                                Hieru
                                Here's my workflow for building them from scratch.
                                https://media.giphy.com/media/TTgdzuMVNdQ1qNdmnYs/giphy.gif
                                www.davidhier.co.uk
                                • HieruH Offline
                                  Hieru
                                  Thanks πŸ‘ . It's so obvious really....let's chalk it up to a senior moment.
                                  www.davidhier.co.uk
                                  • BoxB Offline
                                    I was just fiddling around with this and thought it worth dropping in.
                                    This is the funny horn from a few pages back. Rendered in Twilight.
                                    http://i155.photobucket.com/albums/s296/storeben/SU/Funny Horn Doodle.jpg
                                    • olisheaO Offline
                                      olishea
                                      that speaker-bowl thingy is extremely well modelled well done box
                                      oli
                                      • BoxB Offline
                                        Cheers, Oli, I'm just getting my beginner bits in before you break the mold.
                                          http://genevievejurgensen.blog50.com/media/01/00/271183208.jpg
                                          • olisheaO Offline
                                            olishea
                                            lol don't know about that mate! great stuff! By break the mold I think you mean post some weird surrealist crap that doesn't really help anyone. πŸ˜„
                                            oli
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 82
                                            • 83
                                            • 68 / 83
