    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 952.0k Views 79 Watching
    • BoxB Offline
      It happens every time!
      You're quietly working away on simple things,
      you make a simple bowl, then a stick and a strange little blob.....
      http://i155.photobucket.com/albums/s296/storeben/SU/Bowl.jpg
      then someone goes and lets minions into the thread and it all goes to hell. πŸ’š
      http://i155.photobucket.com/albums/s296/storeben/SU/Chopsticks training Min.jpg
      I blame that Hornie Ox up there.
      • ely862meE Offline
        ely862me
        Lovely render, Box !
        @garydorn said:
        an hour!
        shite, I've worked on this for atleast 12 hrs -
        I have about 10 years of working with Sketchup(yet I am far from some people around here) and I first started with modifying the cars I found on the Warehouse. My first car was quite lame but slowly you make progress.
        A body shape can be achieved fast but getting it to the right/perfect flow takes more than 12 hours.
        Elisei (sketchupper)
        Come and See EliseiDesign
          @hornoxx said:
          Character Modeling would be somewhat exaggerated in this Minion case
          ... but at least I managed to make any (stupid) face expression πŸ˜›
          Each part is made with SubD
          That! Is! Awesome! (And I love minions as well!!)
            @baz said:
            an hour!
            I hear you brother
            I've worked on and off with that Charger model for ... two years now. My problem is that I keep getting distracted by the urge to improve or write new tools to "optimize" my workflow. In the end I code more than I model. 😞
              πŸ˜„
              Just waiting for the minion to become SketchUp's "teapot". πŸ˜„
              Nice render by the way. But what is the glass pebbles for?
              • BoxB Offline
                The meandering theory of the model was a Chopstick trainer.
                You have a bowl of slippery little suckers to pick up and move. Many people learn to use chopsticks by moving dried peas from one bowl to another. It's one of those save face skills that you need to know if you are in that sort of industry. I happily eat peanuts with chopsticks without thinking these days.
                However the slippery little yellow fella distracted me.
                I rendered the bowl, chopsticks and blobs and it all looked very elegant, or should I say too neat to be interesting. As you can see from the proxy's the modelling was done while eating a sandwich so Hornoxx's outstanding work helped to bring my little bit to life.
                And just to finish off, everything about that render is QFT, VT or SubD. The clean lines of the colours are because I could easily select the loops and paint them. Even a tiny line of copper just to highlight the band of red that nobody would actually notice, but makes a significant difference to the final image. The shape of the blobs, the square to round of the chopsticks............
                • aarondietzenA Offline
                  aarondietzen
                  "Imagination is more important than knowledge..."
                  - Albert Einstein
                  • HornOxxH Offline
                    HornOxx
                    @pilou said:
                    That is excellent! 😎
                    @thomthom said:
                    Just waiting for the minion to become SketchUp's "teapot". πŸ˜„ ...
                    πŸ‘
                    @aarondietzen said:
                    πŸ‘ πŸ‘ πŸ’š
                    Thanks, to all of you posting SubD-stuff & knowledge here in CottyΒ΄s great thread
                    @Box - on your Manifold model, somewhere up there, I have broken my teeth !!! πŸ˜›
                    never trust a skinny cook
                    • cottyC Offline
                      cotty
                      It's not my topic, it's a great community topic... πŸ˜‰
                      my SketchUp gallery
                      • O Offline
                        optimaforever
                        btw sometimes when I open a skp with a subd-ed mesh in it, the mesh is invisible (but it's definitely there, as you can select a hollow box and it becomes visible if you toggle the subdivision off)...
                        Is there a fix for this? what causes this?
                        • olisheaO Offline
                          olishea
                          My Sub D experimentation is under way πŸ˜„
                          oli
                          • BoxB Offline
                            I've notice a few people I have talked to and read in some post that there is a misconception that SubD isn't well suited to accurate or specific dimensions.
                            I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt.
                            This is all one piece and is a solid.
                            Proxymouth 40mm.skp
                              Cool result! 😎
                              What is the render engine used ?
                              • BoxB Offline
                                Twilight Hobby.
                                • HornOxxH Offline
                                  HornOxx
                                  @box said:
                                  ...I modeled this as an example of an organic shape flowing into a very accurate connector. This would fit onto the other side of the connector I modeled it from. Right down to the 6.2mm holes to take 6mm contersunk engineering bolt...
                                  ThatΒ΄s a good hint and a nice example as well! (I thought of any new B & O speakers πŸ˜› )
                                  Did you use the normal SU move tool for to snap and fix these exact points then?
                                  • BoxB Offline
                                    It doesn't really matter how you arrive at the shapes, it's just a matter of using the crease tool to lock them in place.
                                    So if you draw a circle with the normal 24 sides and extrude and expand etc etc but crease the original border of the circle, the hole created by that circle even after subding will be the same as when you created it. So you can happily draw accurate sizes and keep them in the same piece as heavily deformed shapes. Which makes it easier for creating 3d printables.
                                    Mind you, there is no reason I couldn't make the fitting and the "mouth" shape separate pieces, and using the same logic mate them together perfectly via creasing.
                                      Do you have such a model you can share?
                                      And the mesh isn't missing when you save? It could either be some extension that do something to the model when it saves. Or could it be a graphic card issue?
                                      Do you ever get a SUbD error dialog?
                                      • HornOxxH Offline
                                        HornOxx
                                        ... again a ... question:
                                        to get these topologies (Cut Face A and B), is there a specific tool or can I draw them the usual way with QFT line tool?
                                        ... thatΒ΄s a good question and thanks for your useful picture - in 2D, these "curved direction changes" can be drawn with basic SU tools.
                                        As they are so useful, IΒ΄ll add them here if someone wants to use them as "instant groups" πŸ˜„
                                        Basic_Geometry1.skp
                                        • HornOxxH Offline
                                          HornOxx
                                          πŸ‘ thats good! thanks for this workflow
                                          just right click on the gif within your web page and copy the gifΒ΄s URL and paste it her - like you would post any other internet linked picture
                                          • HieruH Offline
                                            Hieru
                                            Here's my workflow for building them from scratch.
                                            https://media.giphy.com/media/TTgdzuMVNdQ1qNdmnYs/giphy.gif
                                            www.davidhier.co.uk
                                            • 11
                                            • 82
                                            • 83
                                            • 9 / 83
