    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • ntxdaveN
      ntxdave
      @thomthom said:
      Btw, have you had a look at the links on the Quad section of the SUbD website?
      Yes, but I am going to look at it again. I have also been reading the Blender for Dummies book. While I am not Blender's biggest fan and the book does not really teach you to use the software very well. It is a very good background for understanding the whole Quad environment and learning some of the terminology related to the quad/mesh environment.
      I did finally do my first quad model yesterday. Unfortunately I did it before Box's gif's so it has several mistakes but at least I did one.
      Here it is:
      Everyone has to start somewhere and then learn from your mistakes.
      Press F1...thank me later
        Challenge: Someone come up with a way to pause/play a GIF
        Windows Media Player inside your Windows system
        can read these Gif with Stop button, Next, etc... πŸ˜‰
        Image following is just an image, not an animation!
          Aye. Quad-based workflow has a steeper learning curve than your normal SketchUp workflows. However, the long-term benefits are great.
          • BoxB
            Here's a little exercise to help people understand how a low poly proxy can become a complex structure.
            As you see I simply made a basic child's stick figure as a series of connected blocks. Then gradually refine the shape by moving the blocks around. This helps you to retain a quad structure.
            QFT lets you click to add or remove whole loops as you need them. As the level of detail increases you can refine the shape more and more while still having an easily navigable mesh to work with.
              http://www.mesnie.org/wp-content/uploads/2016/01/evolution.jpg
              • Bob JamesB
                Bob James
                @box said:
                Each of the movements are me selecting vertices and moving them with the Vertex Gizmo just like in the ones earlier.
                That's all I really needed to know. Thank you.
                • BoxB
                  I'm glad that helped Bob.
                  By the way, if anyone wants that proxy to play with and develop further let me know, I think I saved it and could attach it when I get home.
                  • BoxB
                    Pilou I actually saved the file as Evolution with that in mind, but I prefer this image.
                    • olisheaO
                      olishea
                      @box said:
                      I've added the proxy so you can make em as big as you want adjust them to fit.
                      πŸ˜„ πŸ˜„ πŸ˜„
                      oli
                        rv1974
                        Box how do you work with symmetrical geometry? Do you temporaly make mirrored low poly components or make all editing twice (from both sides simultaneously)?
                        • jo-keJ
                          jo-ke
                          This is exactely the same question that I asked myself
                          http://www.zz7.de
                            Maybe like this! The GIZMO of Vertex tools is incredible! πŸ˜‰
                            (Left click Move + CTRL on the opposite Arrow)
                            It has such combinaisons (Shift, Ctrl, Alt) than that is a program itself! 😎
                            White background of the forum is not favourable for painting master pieces! πŸ’š
                            • BoxB
                              Simple answer is 'all of the above'.
                              Depends what I am doing and what shape I am heading for.
                              Sometimes I select both sides as you get a better view when it all moves together,
                              Sometimes I only work with half an object then just mirror it.
                              Sometimes when working with a complete structure I'll work both sides simultaneously then gradually make them different.
                              Quite often I will split a model in half and delete the bad side and replace it with the good.
                              So I'd have to say I have no fixed method and I often do the same things differently the next time.
                              It's worth mentioning that QFT and VT tools make it very easy to select and manipulate both sides at the same time.
                              • BoxB
                                Thomthom it's all your fault, I wander off to the pub with my tablet, I drink beer, I chat, I drink more beer, I doodle, I roughly render a few bits and pieces, I stagger home. While tucked up in bed 'she who must be obeyed' flicks through my doodles and now insists I must produce this hipbath in real life for her.
                                A two beer doodle and a grainy render will drive me nuts for months.
                                  YOu know what they say; never sketch and drink! πŸ˜„
                                  Seriously - that looks really nice. Looking forward to seeing the real thing! πŸ˜„
                                  (Oh, and can we peek at the wireframe and control-mesh?)
                                  • BoxB
                                    Sorry Thom I don't have the control mesh any more as I unsubed it when I wanted to get the profile to make the support.
                                    • JQLJ
                                      JQL
                                      It would be cool if SubD worked on reverse.
                                      Then we could reverse engineer some models... (again this is me talking without having had time to try subd)
                                      www.casca.pt
                                      Visit us on facebook!
                                      • dereiD
                                        derei
                                        404 Not Found
                                        (sketchucation.com)
                                        DESIGNER AND ARTIST DEREI.UK
                                        • ntxdaveN
                                          ntxdave
                                          As I continue to try to learn how to use the quad modeling tools (I am using QFT, Vertex Tools, and SubD) I seem to be making a real mess of things. I have a some silly questions:
                                          1. Several of you show pictures of your models with the quad faces. How do you do that? As soon as I click out of editing the group it no longer shows the quad faces.
                                          2. Along with that, how do you increase the amount of faces and continue to show it as a picture?
                                          3. I have a group where I scaled the middle of the group to create a groove in the center of the object. It appears to me that the groove has the same size quads as the edges at the top and bottom of the object but the rounding of the edges for the groove are much sharper than the edge at the top and bottom of the object. Why is that?
                                          4. In my "grooved" object, if I increase the number of quads and then decrease the number of quads the groove disappears. Why does that happen?
                                          5. Assuming I get all of this worked out in my mind, if I have a complex model where only a part of my model is a quad face object, how do I deal with all of this in the full model? (Hope that question makes sense)
                                          I think I am understanding the basics of what the tools do but am obviously not getting the full picture.
                                          One last item, @Box, would you mind sharing the skp file where you created the person? I think there is a lot to learn from it and your elegant tub.
                                          • BoxB
                                            Sure Ntxdave, here it is saved back to Version 8 for anyone who needs it that old.
                                            Note the last two are the same, so the last one is ready to be modified.
                                            Too busy just now to answer your other questions.
                                            Figure progressionV8.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 83
                                            • 84
                                            • 12 / 84
