    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
      @ely862me said:
      I thought this was happening only with this model, but it seems it happens with all. I don't remember doing any changes later. This is a bit strange. Maybe Thomas has some hints from the error I sent his way.
      Edit
      Thomas, have you released any updates recently ?
      When I went to Welcomne to SubD panel it said a new version is available. Then I went to SCF pluginstore and installed SubD. Now it seems to work.
      You where running an expired beta build. Guess you didn't update after the release.
      • ely862meE
        ely862me
        Edit
        When I went to the Welcome to SubD panel it said a new version is available. Then I went to the SCF pluginstore and installed SubD. Now it seems to work.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • ely862meE
          ely862me
          Strange as it worked until today !
          I believe I didn't update after the release.
          Thanks, back and runnin' fine !
            The beta builds have an expiry time based on the build date.
            • BoxB
              A little late night doodle.
              http://i155.photobucket.com/albums/s296/storeben/SU/Funny Horn.gif
              Funny Horn Doodle.skp
              • HornOxxH
                HornOxx
                πŸ‘
                your doodle has even material thickness 😲 how do you get that ? ! ?
                never trust a skinny cook
                • ely862meE
                  ely862me
                  That's why Fredo invented JPP !
                    πŸ‘Ώ
                    • BoxB
                      No JPP used. I simply started with a hexagonal doughnut. The whole model is an extrusion from that hexagon therefore creating a printable solid.
                      • BoxB
                        This is the basic process I used, forgive the wandering mouse as I haven't had my coffee yet but this could be tweaked to any detail level you desire and done correctly will remain a solid with a suitable double skin. It is after all nothing more than a scaled tube.
                        http://i155.photobucket.com/albums/s296/storeben/SU/Funnel.gif
                        • pbacotP
                          That's nice. For some reason I didn't think you started with a solid in the first place!
                          • ntxdaveN
                            ntxdave
                            @Box, another great tutorial for those of us who are trying to move further along with quad modeling. Between this and the other tutorial you share earlier today, I am getting the oicture clearer.
                            The other aspect that I have seen in you instrument post that woul ge nice to see is how you achieved the curved sections.
                            I have now downloaded the trial versions of the Subd and Vertex Tools plus the QFT plugins. I created one model so far. It has errors but I now have a better idea of where I should go. Will be trying some more tomorrow. It is not as big a mystery as it was before.
                            Again, thanks for sharing you knowledge with the rest of us.
                            Press F1...thank me later
                            • BoxB
                              It's all about segmentation, you can use follow me to create shapes but they don't need to be 'round'.
                              Here I have used the arc tool set at 3 segments. You can use more or less depending on what you need. I used too many in the horn but it was an unplanned shape so just evolved. Tigs split tools are very handy too as you need everything split into quads. You can manually draw the edges in but Split tools speeds up the process.
                              • BoxB
                                Another very quick doodle.
                                How to make a passable sports bra from an empty box by moving a few vertices.
                                I've added the proxy so you can make em as big as you want adjust them to fit.
                                Sports Bra.skp
                                • HornOxxH
                                  HornOxx
                                  @box said:
                                  Another very quick doodle...
                                  Thanks Box for your great "Doodle"-Tutorial-Shorts here!!
                                  like some others here - there is a lot to learn
                                  πŸ‘ πŸ˜„
                                      I you make 2 holes you have very design glasses! πŸ’š
                                      • Bob JamesB
                                        Bob James
                                        Considering all that you have already provided in the practical use of these new tools I feel somewhat guilty in asking you to do the same step-by-step tutorial for the creation of your sports bra. It may not seem so to you, but for numb-noses like me these tuts are REALLY, REALLY helpful.
                                        I've spent so many years using SU with the native tools and Ruby plugins/extensions that I'm finding it more than a little difficult re-structuring my workflow. At this point it's not obvious that the quad workflow is better/faster. I'm trusting in all of you "quad guys" that, in the long run, the quad workflow is the "way of the future".
                                        Thank you again for your great explanations.
                                        @whaat
                                        This is the stuff that has distracted me from the PB2 beta testing. It's not fair for these guys to dangle M&Ms in front of a chocoholic 😳
                                        • BoxB
                                          Bob there's not a lot I could add to that little bra number, all you are seeing there are the undo steps played backwards. Each of the movements are me selecting vertices and moving them with the Vertex Gizmo just like in the ones earlier. The creation of the lines around the faces is also shown above, but they could just be drawn in.
                                          I'm also on my phone now so unable to work with it.
                                          I think people need to realise that they shouldn't be frightened of quads, once you understand them you can easily work them into your normal workflow as necessary. They actually help you with selecting and manipulating edges even without thinking about the SubD aspect of them. Working with geometry that is a network of loops and rings rather than a tangled web of triangles is so refreshing.
                                            I'm so happy to hear people say this. It also makes writing modelling tools and extensions easier if they can focus on dealing with quads.
                                            That being said - these GIFs you made box are really nice. Exactly the kind I want to create for the new QFT site.
                                            • 11
                                            • 12
                                            • 13
                                            • 83
                                            • 84
                                            • 11 / 84
