    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • ely862meE
      ely862me
      It doesn't work for me. I have sent the bug. I get one every time I try it.
      Elisei (sketchupper)
      Come and See EliseiDesign
      • micioneM
        micione
        Elisei ,
        check your other plugins.
        it is a conflict.
          works for me too
            @ely862me said:
            I thought this was happening only with this model, but it seems it happens with all. I don't remember doing any changes later. This is a bit strange. Maybe Thomas has some hints from the error I sent his way.
            Edit
            Thomas, have you released any updates recently ?
            When I went to Welcomne to SubD panel it said a new version is available. Then I went to SCF pluginstore and installed SubD. Now it seems to work.
            You where running an expired beta build. Guess you didn't update after the release.
            • ely862meE
              ely862me
              Edit
              When I went to the Welcome to SubD panel it said a new version is available. Then I went to the SCF pluginstore and installed SubD. Now it seems to work.
              • ely862meE
                ely862me
                Strange as it worked until today !
                I believe I didn't update after the release.
                Thanks, back and runnin' fine !
                  The beta builds have an expiry time based on the build date.
                  • BoxB
                    A little late night doodle.
                    http://i155.photobucket.com/albums/s296/storeben/SU/Funny Horn.gif
                    Funny Horn Doodle.skp
                    • HornOxxH
                      HornOxx
                      πŸ‘
                      your doodle has even material thickness 😲 how do you get that ? ! ?
                      never trust a skinny cook
                      • ely862meE
                        ely862me
                        That's why Fredo invented JPP !
                          πŸ‘Ώ
                          • BoxB
                            No JPP used. I simply started with a hexagonal doughnut. The whole model is an extrusion from that hexagon therefore creating a printable solid.
                            • BoxB
                              This is the basic process I used, forgive the wandering mouse as I haven't had my coffee yet but this could be tweaked to any detail level you desire and done correctly will remain a solid with a suitable double skin. It is after all nothing more than a scaled tube.
                              http://i155.photobucket.com/albums/s296/storeben/SU/Funnel.gif
                              • pbacotP
                                That's nice. For some reason I didn't think you started with a solid in the first place!
                                • ntxdaveN
                                  ntxdave
                                  @Box, another great tutorial for those of us who are trying to move further along with quad modeling. Between this and the other tutorial you share earlier today, I am getting the oicture clearer.
                                  The other aspect that I have seen in you instrument post that woul ge nice to see is how you achieved the curved sections.
                                  I have now downloaded the trial versions of the Subd and Vertex Tools plus the QFT plugins. I created one model so far. It has errors but I now have a better idea of where I should go. Will be trying some more tomorrow. It is not as big a mystery as it was before.
                                  Again, thanks for sharing you knowledge with the rest of us.
                                  Press F1...thank me later
                                  • BoxB
                                    It's all about segmentation, you can use follow me to create shapes but they don't need to be 'round'.
                                    Here I have used the arc tool set at 3 segments. You can use more or less depending on what you need. I used too many in the horn but it was an unplanned shape so just evolved. Tigs split tools are very handy too as you need everything split into quads. You can manually draw the edges in but Split tools speeds up the process.
                                    • BoxB
                                      Another very quick doodle.
                                      How to make a passable sports bra from an empty box by moving a few vertices.
                                      I've added the proxy so you can make em as big as you want adjust them to fit.
                                      Sports Bra.skp
                                      • HornOxxH
                                        HornOxx
                                        @box said:
                                        Another very quick doodle...
                                        Thanks Box for your great "Doodle"-Tutorial-Shorts here!!
                                        like some others here - there is a lot to learn
                                        πŸ‘ πŸ˜„
                                            I you make 2 holes you have very design glasses! πŸ’š
                                            • 11
                                            • 12
                                            • 13
                                            • 83
                                            • 84
                                            • 11 / 84
