[Plugin Library] LibFredo6 - v14.5b - 24 May 24
I have installed the current version of both. In fact, the chamfer (one segment) tool worked fine until I updated to latest versions. I will reinstall both and try again. Thanks for the help guys.
I just discovered that an in-house plugin was causing interference. Thanks again guys.
I installed the library by downloading the file and installing it. Now when I start sketchup I get:
SketchUp
LibFredo6: Problem of installation in creation of Data directories in C:/Windows
OK
@ittayd said:
I installed the library by downloading the file and installing it...
How did you download it?
Was it the RBZ from the PluginStore ?
How did you install it?
Using the Preferences > Extensions > Install Extensions... button ?
Have you restarted SketchUp?
If the file and its subfolder in your user Plugins folder ?? -
SketchUp
OK
It looks like your environment is not well defined in Windows.
Normally, if you type ENV["LOCALAPPDATA"], you should get a directory under you local user name. Apparently you get C:\Windows and you do not have the permissions to create subfolders in this directory.
Which Windows system do you run?
NEW RELEASE: LibFredo6 v6.9b - 13 Nov 15
LibFredo6 6.9b is a maintenance release for fixing bugs
See main post of this thread for Download of LibFredo6.
Hm... where is "download" button?
Hm...It helps to look at the first post of the thread to which Fredo linked. -
Thanks Dave R! But, you links is for LibFredo6_v6.8
The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
What am I doing wrong?
Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
IE? MacOSX. No file associations problem on OS level
Sorry. Clear the Safari caches.
Safari caches? This screenshot is from SU plugin "Sketcucation plugin store"
On a PC all of SketchUp's dialogs use Internet-Explorer.
On a MAC all of SketchUp's dialogs use Safari.
This usage is quite separate from whatever you use for your day-to-day browsing.Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
So if you are on a MAC open Safari, then empty its cache...
Then restart SketchUp and see if that helps... -
Thanks TIG! Cleaned. No effect, the same bug
when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
Drag this to Trash...
~/Library/Caches/com.sketchup.SketchUp.2015or whatever version of SU your running [your profile says v8???]
Thanks driven!
SU cache is trashed, SU is restarted, No effect! -
well unless your really still on v8, WebDialog seems to not be the issue...
I'll try and instal it...
john -
works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
maybe later...
