    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      @ittayd said:
      I installed the library by downloading the file and installing it...
      How did you download it?
      Was it the RBZ from the PluginStore ?
      How did you install it?
      Using the Preferences > Extensions > Install Extensions... button ?
      Have you restarted SketchUp?
      If the file and its subfolder in your user Plugins folder ??
      • fredo6F
        @ittayd said:
        I installed the library by downloading the file and installing it. Now when I start sketchup I get:
        SketchUp
        LibFredo6: Problem of installation in creation of Data directories in C:/Windows
        OK
        It looks like your environment is not well defined in Windows.
        Normally, if you type ENV["LOCALAPPDATA"], you should get a directory under you local user name. Apparently you get C:\Windows and you do not have the permissions to create subfolders in this directory.
        Which Windows system do you run?
        • fredo6F
          NEW RELEASE: LibFredo6 v6.9b - 13 Nov 15
          LibFredo6 6.9b is a maintenance release for fixing bugs
          See main post of this thread for Download of LibFredo6.
            maxosmedia
            Hm... where is "download" button?
              Hm...It helps to look at the first post of the thread to which Fredo linked.
                maxosmedia
                Thanks Dave R! But, you links is for LibFredo6_v6.8
                  The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
                    maxosmedia
                    What am I doing wrong?
                      Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
                        maxosmedia
                        IE? MacOSX. No file associations problem on OS level
                          Sorry. Clear the Safari caches.
                            maxosmedia
                            Safari caches? This screenshot is from SU plugin "Sketcucation plugin store"
                              On a PC all of SketchUp's dialogs use Internet-Explorer.
                              On a MAC all of SketchUp's dialogs use Safari.
                              This usage is quite separate from whatever you use for your day-to-day browsing.
                              Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
                              So if you are on a MAC open Safari, then empty its cache...
                              Then restart SketchUp and see if that helps...
                                maxosmedia
                                Thanks TIG! Cleaned. No effect, the same bug
                                  driven
                                  when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
                                  Drag this to Trash...
                                  ~/Library/Caches/com.sketchup.SketchUp.2015
                                  or whatever version of SU your running [your profile says v8???]
                                    maxosmedia
                                    Thanks driven!
                                    SU cache is trashed, SU is restarted, No effect!
                                      driven
                                      well unless your really still on v8, WebDialog seems to not be the issue...
                                      I'll try and instal it...
                                        driven
                                        works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
                                        maybe later...
                                          driven
                                          but it did instal using Preferences >> Instal Extension...
                                          • P
                                            Poot
                                            I installed the joint push pull by rubyscript. And i'm trying to install the lib fredo..... by plugin store.
                                            What am i doing wrong here? I push install in the plugin store then this comes out.
                                            When i restart sketchup he says this?
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 115
                                            • 116
                                            • 52 / 116
