    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.7m Views 580 Watching
    • X Offline
      xianglin
      Hi Fredo you have MSN number.
      Tell me this number, I want to talk to you about SketchUp's plugin.
      Thank you
        alisonkr
        This is what I get from the Ruby Console:
        Sketchup.find_support_file('Plugins') H:/Program Files (x86)/Google/Google SketchUp 8/Plugins ENV["APPDATA"] C:\Users\Alison\AppData\Roaming
        And no I don't see "LibFredo6 settings..." in the Windows menu of Sketchup. (Edit: After looking at the System Preferences > Extensions I did find the LibFredo6 Settings option and enabled it. So now I do see it in the Windows menu.)
        I was able load the Bezier Spline toolbar without any errors but nothing was added to the Windows menu.
          Shinnah1
          Version 6.8 seems to be broken. It says "An error was found when processing geometry Corner at fault is highlighted in the model" Everything works fine unless trying to use only one segment.
            This sounds more like your geometry has a problem but you're blaming the tool. How about sharing the part of the model where you get the error. And what tool were you using when you got this message.
              Shinnah1
              It was not my intention to "blame the tool", but to point out a possible bug. I certainly thought my model was at fault, but tested it in several situations before concluding there may be a bug.
              Cube.skp
                How big is this 'box' you are trying to 'round' ?
                The 'rounding' is currently set to be 6" - so if the object itself is smaller that that the operation will fail...
                Giving us the [simple] problem SKP itself - with your clear intentions regarding this 'rounding' - would be more use...
                Help us to help you...
                  It worked fine for me using the same settings so I don't think there's a problem with LibFred6 or with Round Corner. Do you have the most recent versions of both installed?
                    I agree with Dave.
                    I can round [or chamfer] the corner at 6" - no problems at all.
                    So please check you have installed the latest Lib and Plugin version - both available from the SketchUcation PluginStore...
                      Shinnah1
                      I have installed the current version of both. In fact, the chamfer (one segment) tool worked fine until I updated to latest versions. I will reinstall both and try again. Thanks for the help guys.
                      I just discovered that an in-house plugin was causing interference. Thanks again guys.
                      • I Offline
                        ittayd
                        I installed the library by downloading the file and installing it. Now when I start sketchup I get:
                        SketchUp
                        LibFredo6: Problem of installation in creation of Data directories in C:/Windows
                        OK
                          @ittayd said:
                          I installed the library by downloading the file and installing it...
                          How did you download it?
                          Was it the RBZ from the PluginStore ?
                          How did you install it?
                          Using the Preferences > Extensions > Install Extensions... button ?
                          Have you restarted SketchUp?
                          If the file and its subfolder in your user Plugins folder ??
                          • fredo6F Offline
                            SketchUp
                            OK
                            It looks like your environment is not well defined in Windows.
                            Normally, if you type ENV["LOCALAPPDATA"], you should get a directory under you local user name. Apparently you get C:\Windows and you do not have the permissions to create subfolders in this directory.
                            Which Windows system do you run?
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v6.9b - 13 Nov 15
                              LibFredo6 6.9b is a maintenance release for fixing bugs
                              See main post of this thread for Download of LibFredo6.
                                maxosmedia
                                Hm... where is "download" button?
                                  Hm...It helps to look at the first post of the thread to which Fredo linked.
                                    maxosmedia
                                    Thanks Dave R! But, you links is for LibFredo6_v6.8
                                      The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
                                        maxosmedia
                                        What am I doing wrong?
                                          Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
                                            maxosmedia
                                            IE? MacOSX. No file associations problem on OS level
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 111
                                            • 112
                                            • 51 / 112
