    [Plugin] Solid Inspector
    303 Posts 99 Posters 312.0k Views 98 Watching
    • jgbJ Offline
      jgb
      I found it impossible to fix. The bottom face was 3 faces bounded by a single line rectangle. I could not delete a face, it kept coming back if I tried to fix something on an adjoining face. Then when I thought it was almost OK, I did another SI which found many problems. So I said let SI fix it. Ended up with about 8 valid lines and faces. SI "fixed" it by blowing most of it away.
      I blew the rest away, started fresh, and that turned out OK.
      So, anybody, I don't need it fixed. I posted it for ThomThom to ferret out the why.
      jgb
        Ackh! One of them models - where faces start appearing all over the place. I've never found a good solution for that. I saw a good number of them in my previous job - usually ended up recreating the geometry because it was quicker. Never really figured out the cause - but I suspect it was often due to some precision issues which can often creep in from imported geometry.
          Why this must be made by Hand ? (Close the solid) it detects 2 possibilities?
            Because while it's easy for us humans to see the correct solution, it's much harder to code a solution. One can code a solution for this specific situation - but that wouldn't apply to other situations. Generic solution for repairing geometry is difficult.
              The way my SolidSolver deals with that particular case is that it finds faces for the unfaced and single-faced edges on that corner, it then removes the newly added inner triangular partition-face, whilst leaving the three new triangular facets on the outer shell.
              At that point it's a solid.
              It finally prompts you to remove the three coplanar edges.
              If you want the cube actually to have an angled triangular corner facet you need to edit it and delete the unfaced edges before attempting to make it a solid - then the one triangular corner facet is added if it's still missing...
                THX for the infos! πŸ‘
                • jgbJ Offline
                  jgb
                  While I really appreciate TT's SI2's ability to fix problems, (for me it works well about 90%++ of the time) it would be better if it could simply highlight an "unfixable" problem, now indicated as "info" and maintain that highlight when exiting the tool, so I can find it fast and fix it manually.
                  Perhaps, by creating a group on its own temporary layer that traces/duplicates the unfixable errors and renders them in red lines/faces, as is done now to identify those errors. That way I can see and fix any problem outside SI2, then simply delete the highlight layer/group.
                  Just a thought.....
                  jgb
                  • jgbJ Offline
                    jgb
                    I just noticed something; whenever I import an SU-8 model into SU-2015 and make edits to some faces (in what was a perfect solid in SU-8 or SU-15) I often end up with multiple faces off single lines that SI-2 does not see, and SU says it is no longer solid.
                    It has happened in 3 models so far, and I quite often get 3 faces on a single lined perimeter. When I delete just the extraneous faces, it regains solidity.
                    It does not happen when the solid originates in SU-15.
                    Betchya nobody else sees this. πŸ‘Ώ
                    jgb
                    • N Offline
                      NeloNath
                      Your plugin saved my life, thank you πŸ˜„
                      • N Offline
                        nataliablanco87
                        Hi ThomThom, I've been using SI2 for a couple of weeks and is awesome. I totally loved it, but right now I'm checking on a component and it says everything is fine, but still doesn't appear to be a solid component. Dunno what else to do πŸ˜•
                          Are you able to share the model?
                            kiwi15
                            This is not a post about the (excellent) Solid Solver in particular, but it applies to it as well so that is why I am using it as an example.
                            I have problems with eye strains and feel quite uncomfortable looking at many of the low-resolution extension icons that are piling up inside my SU workspace. It looks like they are all out of focus on my Mac retina display, so I found a simple way to upgrade many of them using this simple method. See attached image.
                            I hope someone else out there find this information helpful as well.
                              I just updated this extension to 2.4.4 in order to add some extra debug code for a particular persistent bug I'm getting reports of - which I've been unable to reproduce.
                              Please update to the latest version in order to ensure you can submit error reports with better info back to me.
                              Also, if you run into issues, if you can, please post the model in this thread. (Try to undo whatever Solid Inspector might have tried to fix and submit the model as it where before fixing.)
                              • tuna1957T Offline
                                tuna1957
                                Have a strange issue with Solid Inspector2. Posting screenshot of an example. Modeled the cube at correct size for a casino dice. Made a component. Scaled up 1000x. Drew the "pips" in the scaled up copy, 24 sided circle. Ran Roundcorner on the edges. SU shows it as solid but if I run Solid Inspector I get "short edges" for basically every intersection. No line segment in the scaled up copy is shorter than 2.5". I see this behavior in a lot of different models.
                                Where the problem comes in I will get a "fix model" prompt when closing SU and if you let it fix the model it will destroy some of your geometry. In this models case it's at the corners of the dice. I'm sure it's something I'm doing but like I said I see this a lot in small objects that I do modifications on in a scaled up copy.
                                Edit - forgot to mention.... SU2015Pro on Mac osx 10.10.5
                                  jvcompiani Newcomers
                                  You're the boss! This extension solve all my problems!!!
                                    gnusardni Newcomers
                                    Hello Thom and Forum.
                                    Maybe it is too late, but I never succeed installing solid inspector in my SU 8 pro.
                                    My laptop is the old one windows 7 64 bit with 2 GB RAM, and it was enough for my daily works.
                                    The oldest version found at github is v1.2.0
                                    I read somewhere that v1.1.0 could be work ?
                                    an what is the TT_lib version for that.
                                    But where is it, can not find that file.
                                    Please help
                                    Many Thanks !
                                    • 12
                                    • 13
                                    • 14
                                    • 15
                                    • 16
                                    • 15 / 16
