    SketchUp 2016 Wishlist
    192 Posts 69 Posters 94.6k Views 69 Watching
    • HornOxxH Offline
      HornOxx
      Hello JQL and John
      the developer of a SU-Render plugins turned my attention to the following.
      He said, that for SkUp - based on a scene - always the height proportion of scene content and viewport height remains constant. This means that only the image width is the variable.
      Within my Render plugins this is a true statement - no matter what resolution I choose, the height proportion remains the same. Fortunately! - Because otherwise we could not produce render series on different computers, which perfectly fit together.
      Now I have repeated this procedure as a 2D export in Skup by using the animation export, because I was able to choose any free resolution settings there. Also Skup exports these 2D images always with the same height proportion As you can see in the little sketch below.
      Although my colleague repeated this procedure on his own computer with other Skup viewport settings, and his export result is the same as mine.
      This result is promising, because it would mean that only a freely selectable height-width resolution should be adjustable within SkUpยดs 2D export settings as it is possible in the animation export if you choose JPG for example instead of avi...
      never trust a skinny cook
      • jgbJ Offline
        jgb
        @jql said:
        My wish for 2016 would be that Trimble would hire someone just to try every button and function Sketchup has and find things like:
        • Wrong or unexpected behaviours;
        • Inconsistent UI;
        • Recurrent feature requests;
        • Standardization of usual processes;
        • Etc...
        No need for Trimble to test every button and function. They will not learn much from doing that. SU needs to be worked to discover "bugs" and inconsistencies.
        All Trimble and the SU development team needs to do is READ the past posts here and in other SU forums to learn what goes wrong and needs fixing.
        I have bitched (and others too) about these problems for years, and they are still with us.
        • Near field clipping
        • Hyper zoom (click on empty space when panning...)
        • Z fighting
        • "constrained by..."
          There is a lot more, but only silence from the SU team.
        I'm not talking about enhancements and new stuff.
        This is OLD stuff that still doesn't work right.
        But SU dev has always been far more interested in new bells and whistles for next years SU than in fixing past problems.
        jgb
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Whow, where did you dig out that quote? ๐Ÿ˜„
          Great to hear your project is still alive!
            craigcampbell66
            Deals with higher poly/larger models better.
            Quicker saving/autosave.
            Layout - Active or Current layer 'automatically' switches to Dimensions when activating the dimension tool or Annotation when either notes or text tool is selected. Maybe the ability to customise this feature.
            • dereiD Offline
              derei
              SU 2016 BASIC WISHLIST
              I want for no magic and fairy tales... all I wish is common sense:
              %(#BF0000)[1. Fix Scenes Bug that can lead to accidental Scene Renaming !
              2. Fix Importers/Exporters to work at decent speed (take any other 3d software from the market as example)
              3. Fix the iterating commands in SU, because they take forever to run on complex models. Either if those commands are coded in SU or ran from scripts and plugins. This includes the Outliner crap, that makes everything blow to hell when Outliner is opened.
              4. Make a BETTER Layer manager (get inspired from Layers Panel plugin).
              5. (optional) - try to make plugin parsing a bit faster... would help a lot when SU is loading. One suggestion would be to have all the plugins parsed and converted in binary and saved as a "copy", ready to load in memory. And to have a (manual) function to rescan the Plugins folder in case that plugins were added/removed/updated. This way, won't be needed to parse and interpret all the plugins every time SU is loading...
              1. MAKE LAYOUT DECENT ! - this can become a huge list of things that can be improved. The general idea is that Layout at this moment runs like a Beta version ๐Ÿ‘Ž in all aspects. Text editing is a mess, dimensions placed in SU are not consistent (displayed too big in Layout), general performance is less than decent.. and so on.]
              Thank you very much. This would make SU2016 what it should be, BEFORE adding extra functionality and fancy things that we all dream to. At least make it work, before making it fancy (and before adding price increase).
              DESIGNER AND ARTIST DEREI.UK
              • TommyKT Offline
                TommyK
                I do like the sound of this. What I would imagine is that a pop up window can open when you right click on a layer name and select "layer settings". It would be great if you can make any tool in layout default to any layer you want.
                • oceanembersO Offline
                  oceanembers
                  The... whatever it's called... explorer shell sounds right? The save window. It needs updating - Layout has modernised already, but Sketchup seems stuck in the XP days in this regard. It irritates me that I can't get quick access to my favourites, libraries, etc. when I need it.
                    kaas
                    A wish / fix for Layout:
                    • Don't add an extra style (myStyle1 / myStyle2 etc ) if the style is updated in SketchUp. Just update the style in LayOut to the new settings.
                    • If someone wants a new style in LayOut - just make a new one in SketchUp.
                    • Or at least give the user a prompt in LayOut to re-use the existing style in layOut OR update the existing style to the one from SketchUp OR keep the style in LayOut and create a new one (also nice if inserting several SketchUp files).
                      kaas
                      A wish for SketchUp:
                      option to name a section plane -> Entity Info box
                      • JQLJ Offline
                        JQL
                        For what I've experienced that only happens if you change styles in LO.
                        www.casca.pt
                        Visit us on facebook!
                        • JQLJ Offline
                          JQL
                          It would be very good if these names could be used in Layout automatically for naming section lines in plan views.
                          This would go perfectly along with a way to style section lines in LO and make them, for instance, very short or only visible near the edges of the plan's viewport
                          www.casca.pt
                            tommyg101
                            It would be great to have a manual dimensioning tool. Like you get with most other 3D & 2D programs ie Rhino's 'Box Edit, Cinema 4D's scale and dimensions window or 'transform' box in Illustrator. This would make adjustments to sizes much quicker and easier than have to manually scale an object by moving an edge by a calculated distance to achieve the amended size. It's also a very quick and easy way to see the size of an objects length, depth and width instantly, rather than having to use the tape measure each time, or have drawn dimension lines sitting around the model the whole time. There used to be a plugin called 'Driving Dimensions' which looked like it solved this problem, however this became no longer available a few years back. This seems like a very simple tool that would make such a big impact in the speed and workflow of dimension work in sketchup, the current tools are great but this would just make the process much more efficient and time saving. It would also help migrate more people over to sketchup who are used to this common practice in 3D design.
                            • I Offline
                              intrifen
                              i wish the pan tool with the Middle mouse button,and orbit tool with shift+Middle mouse button,
                              because i use the pan tool frequent, just like the 3Ds MAX software Or can be switch
                              • O Offline
                                olivier1971
                                Would it be great to be able to group layer?
                                • jgbJ Offline
                                  jgb
                                  This has been asked for and ignored in many past versions, so I hold no hope we will see it anytime soon. ๐Ÿ˜ข
                                  There are a few Layer manager plug-ins out there but they don't integrate fully or properly with SU's native layering, so I dropped using them some time back.
                                  jgb
                                  • mariochaM Offline
                                    mariocha
                                    One simple thing ; thumbnails on Mac. Or is it not simple? ๐Ÿ˜„
                                    %(#008000)[Mario C.
                                    • jujuJ Offline
                                      juju
                                      @mariocha said:
                                      Repeated BUGSPLATs, on Windows 7 under Parallels. ๐Ÿ˜•
                                      that's not on my wishlist for SU2016, but hey, each to their own...
                                      ๐Ÿ˜ ๐Ÿ‘Š
                                      and yes
                                      I realise
                                      you were
                                      commenting
                                      on the post
                                      directly
                                      above yours,
                                      it would help
                                      if you
                                      quoted them,
                                      for context
                                      ๐Ÿ‘ โ˜€
                                      • N Offline
                                        numerobis
                                        A divide (line) function without limitation to 100 segments... ๐Ÿ˜’
                                        • pbacotP Offline
                                          Not so hard to type the number, but whatever you think is important.
                                          • srxS Offline
                                            srx
                                            TRIMBELE VR headset and SketchUp! I think that it would be great step forward if Trimble would integrate VR interface in new Sketchup 2016, which would be used for modeling! Trimble VR hardware could be in the packet too ๐Ÿ˜„
                                            www.saurus.rs
                                            • 9 / 10
