    SketchUp 2016 Wishlist
    192 Posts 69 Posters 94.6k Views 69 Watching
      craigcampbell66
      Deals with higher poly/larger models better.
      Quicker saving/autosave.
      Layout - Active or Current layer 'automatically' switches to Dimensions when activating the dimension tool or Annotation when either notes or text tool is selected. Maybe the ability to customise this feature.
      • dereiD Offline
        derei
        SU 2016 BASIC WISHLIST
        I want for no magic and fairy tales... all I wish is common sense:
        %(#BF0000)[1. Fix Scenes Bug that can lead to accidental Scene Renaming !
        2. Fix Importers/Exporters to work at decent speed (take any other 3d software from the market as example)
        3. Fix the iterating commands in SU, because they take forever to run on complex models. Either if those commands are coded in SU or ran from scripts and plugins. This includes the Outliner crap, that makes everything blow to hell when Outliner is opened.
        4. Make a BETTER Layer manager (get inspired from Layers Panel plugin).
        5. (optional) - try to make plugin parsing a bit faster... would help a lot when SU is loading. One suggestion would be to have all the plugins parsed and converted in binary and saved as a "copy", ready to load in memory. And to have a (manual) function to rescan the Plugins folder in case that plugins were added/removed/updated. This way, won't be needed to parse and interpret all the plugins every time SU is loading...
        1. MAKE LAYOUT DECENT ! - this can become a huge list of things that can be improved. The general idea is that Layout at this moment runs like a Beta version 👎 in all aspects. Text editing is a mess, dimensions placed in SU are not consistent (displayed too big in Layout), general performance is less than decent.. and so on.]
        Thank you very much. This would make SU2016 what it should be, BEFORE adding extra functionality and fancy things that we all dream to. At least make it work, before making it fancy (and before adding price increase).
        DESIGNER AND ARTIST DEREI.UK
        • TommyKT Offline
          TommyK
          I do like the sound of this. What I would imagine is that a pop up window can open when you right click on a layer name and select "layer settings". It would be great if you can make any tool in layout default to any layer you want.
          • oceanembersO Offline
            oceanembers
            The... whatever it's called... explorer shell sounds right? The save window. It needs updating - Layout has modernised already, but Sketchup seems stuck in the XP days in this regard. It irritates me that I can't get quick access to my favourites, libraries, etc. when I need it.
              kaas
              A wish / fix for Layout:
              • Don't add an extra style (myStyle1 / myStyle2 etc ) if the style is updated in SketchUp. Just update the style in LayOut to the new settings.
              • If someone wants a new style in LayOut - just make a new one in SketchUp.
              • Or at least give the user a prompt in LayOut to re-use the existing style in layOut OR update the existing style to the one from SketchUp OR keep the style in LayOut and create a new one (also nice if inserting several SketchUp files).
                kaas
                A wish for SketchUp:
                option to name a section plane -> Entity Info box
                • JQLJ Offline
                  JQL
                  For what I've experienced that only happens if you change styles in LO.
                  www.casca.pt
                  Visit us on facebook!
                  • JQLJ Offline
                    JQL
                    It would be very good if these names could be used in Layout automatically for naming section lines in plan views.
                    This would go perfectly along with a way to style section lines in LO and make them, for instance, very short or only visible near the edges of the plan's viewport
                    www.casca.pt
                      tommyg101
                      It would be great to have a manual dimensioning tool. Like you get with most other 3D & 2D programs ie Rhino's 'Box Edit, Cinema 4D's scale and dimensions window or 'transform' box in Illustrator. This would make adjustments to sizes much quicker and easier than have to manually scale an object by moving an edge by a calculated distance to achieve the amended size. It's also a very quick and easy way to see the size of an objects length, depth and width instantly, rather than having to use the tape measure each time, or have drawn dimension lines sitting around the model the whole time. There used to be a plugin called 'Driving Dimensions' which looked like it solved this problem, however this became no longer available a few years back. This seems like a very simple tool that would make such a big impact in the speed and workflow of dimension work in sketchup, the current tools are great but this would just make the process much more efficient and time saving. It would also help migrate more people over to sketchup who are used to this common practice in 3D design.
                      • I Offline
                        intrifen
                        i wish the pan tool with the Middle mouse button,and orbit tool with shift+Middle mouse button,
                        because i use the pan tool frequent, just like the 3Ds MAX software Or can be switch
                        • O Offline
                          olivier1971
                          Would it be great to be able to group layer?
                          • jgbJ Offline
                            jgb
                            This has been asked for and ignored in many past versions, so I hold no hope we will see it anytime soon. 😢
                            There are a few Layer manager plug-ins out there but they don't integrate fully or properly with SU's native layering, so I dropped using them some time back.
                            jgb
                            • mariochaM Offline
                              mariocha
                              One simple thing ; thumbnails on Mac. Or is it not simple? 😄
                              %(#008000)[Mario C.
                              • jujuJ Offline
                                juju
                                @mariocha said:
                                Repeated BUGSPLATs, on Windows 7 under Parallels. 😕
                                that's not on my wishlist for SU2016, but hey, each to their own...
                                and yes
                                I realise
                                you were
                                commenting
                                on the post
                                directly
                                above yours,
                                it would help
                                if you
                                quoted them,
                                for context
                                • N Offline
                                  numerobis
                                  A divide (line) function without limitation to 100 segments... 😒
                                  • pbacotP Offline
                                    Not so hard to type the number, but whatever you think is important.
                                    • srxS Offline
                                      srx
                                      TRIMBELE VR headset and SketchUp! I think that it would be great step forward if Trimble would integrate VR interface in new Sketchup 2016, which would be used for modeling! Trimble VR hardware could be in the packet too 😄
                                      www.saurus.rs
                                      • mariochaM Offline
                                        mariocha
                                        removed
                                        %(#008000)[Mario C.
                                          mojtaba691001
                                          دِ این لامصبو بدین بیرون دیگه
                                          اینقد روی اعصاب ما راه نرین
                                          WHEN do Dear Trimle release Sketchup 2016?? when??
                                          atleast tell us new version date,PLEAAAAAAAASE
                                            WHEN do Dear Trimble release Sketchup 2016?? when??
                                            at least tell us new version date, PLEAAAAAAAASE
                                            This is not the official Sketchup site.
                                            If it were then you would not be told such sensitive information anyway.
                                            That said, the annual release of new versions of SketchUp have in recent years moved to just before the year changes.
                                            So whilst it is in no way a guarantee, you might hope to see v2016 available within the last few months of 2015...
                                            BUT you'll just have to be patient. 😞
                                            • 9 / 10
