    SketchUp 2016 Wishlist
    192 Posts 69 Posters 85.0k Views 69 Watching
    • JQLJ Offline
      JQL
      @kaas said:
      A wish / fix for Layout:
      • Don't add an extra style (myStyle1 / myStyle2 etc ) if the style is updated in SketchUp. Just update the style in LayOut to the new settings.
      • If someone wants a new style in LayOut - just make a new one in SketchUp.
      • Or at least give the user a prompt in LayOut to re-use the existing style in layOut OR update the existing style to the one from SketchUp OR keep the style in LayOut and create a new one (also nice if inserting several SketchUp files).
      For what I've experienced that only happens if you change styles in LO.
      www.casca.pt
      Visit us on facebook!
      • JQLJ Offline
        JQL
        @kaas said:
        A wish for SketchUp:
        option to name a section plane -> Entity Info box
        It would be very good if these names could be used in Layout automatically for naming section lines in plan views.
        This would go perfectly along with a way to style section lines in LO and make them, for instance, very short or only visible near the edges of the plan's viewport
        www.casca.pt
          tommyg101
          It would be great to have a manual dimensioning tool. Like you get with most other 3D & 2D programs ie Rhino's 'Box Edit, Cinema 4D's scale and dimensions window or 'transform' box in Illustrator. This would make adjustments to sizes much quicker and easier than have to manually scale an object by moving an edge by a calculated distance to achieve the amended size. It's also a very quick and easy way to see the size of an objects length, depth and width instantly, rather than having to use the tape measure each time, or have drawn dimension lines sitting around the model the whole time. There used to be a plugin called 'Driving Dimensions' which looked like it solved this problem, however this became no longer available a few years back. This seems like a very simple tool that would make such a big impact in the speed and workflow of dimension work in sketchup, the current tools are great but this would just make the process much more efficient and time saving. It would also help migrate more people over to sketchup who are used to this common practice in 3D design.
          • I Offline
            intrifen
            i wish the pan tool with the Middle mouse button,and orbit tool with shift+Middle mouse button,
            because i use the pan tool frequent, just like the 3Ds MAX software Or can be switch
            • O Offline
              olivier1971
              Would it be great to be able to group layer?
              • jgbJ Offline
                jgb
                This has been asked for and ignored in many past versions, so I hold no hope we will see it anytime soon. 😢
                There are a few Layer manager plug-ins out there but they don't integrate fully or properly with SU's native layering, so I dropped using them some time back.
                jgb
                • mariochaM Offline
                  mariocha
                  One simple thing ; thumbnails on Mac. Or is it not simple? 😄
                  %(#008000)[Mario C.
                  • jujuJ Offline
                    juju
                    @mariocha said:
                    Repeated BUGSPLATs, on Windows 7 under Parallels. 😕
                    that's not on my wishlist for SU2016, but hey, each to their own...
                    and yes
                    I realise
                    you were
                    commenting
                    on the post
                    directly
                    above yours,
                    it would help
                    if you
                    quoted them,
                    for context
                    • N Offline
                      numerobis
                      A divide (line) function without limitation to 100 segments... 😒
                      • pbacotP Offline
                        Not so hard to type the number, but whatever you think is important.
                        • srxS Offline
                          srx
                          TRIMBELE VR headset and SketchUp! I think that it would be great step forward if Trimble would integrate VR interface in new Sketchup 2016, which would be used for modeling! Trimble VR hardware could be in the packet too 😄
                          www.saurus.rs
                          • mariochaM Offline
                            mariocha
                            removed
                            %(#008000)[Mario C.
                              mojtaba691001
                              دِ این لامصبو بدین بیرون دیگه
                              اینقد روی اعصاب ما راه نرین
                              WHEN do Dear Trimle release Sketchup 2016?? when??
                              atleast tell us new version date,PLEAAAAAAAASE
                                WHEN do Dear Trimble release Sketchup 2016?? when??
                                at least tell us new version date, PLEAAAAAAAASE
                                This is not the official Sketchup site.
                                If it were then you would not be told such sensitive information anyway.
                                That said, the annual release of new versions of SketchUp have in recent years moved to just before the year changes.
                                So whilst it is in no way a guarantee, you might hope to see v2016 available within the last few months of 2015...
                                BUT you'll just have to be patient. 😞
                                • pbacotP Offline
                                  "Save a copy as" on Mac: This would be useful for saving versions for other users/ colleagues who are not up to date. That way you could remain in your version of the drawing while sending off a copy. But alas the version options are missing from this save dialog.
                                  • N Offline
                                    numerobis
                                    Yes, you're right. I can do this. But it doesn't display the length calculation for more than 100 segments. So in many cases where i need a specific length it's try and error. Sure, i can do the calculation by hand (i have to do it this way now), but the interactivity is really helpful in many cases. A variable would be great, so that you can set the limit as you like/need it.
                                    One more general wish...
                                    A "cancel" button or better the ESC-key that simply works on EVERY Ruby action. Many times an operation gets stuck or can run forever, e.g. with an accidentally wrong selection. And then the only option is to shut down SU. Not very elegant... and very annoying if the last autosave is missing some important changes...
                                      Brighter3D
                                      Faster "save all textures" from the api.
                                      It would speed up all renderers export time...
                                      Best Regards,
                                      brighter3d.com
                                      • jgbJ Offline
                                        jgb
                                        I asked about this a long while back and the answer from one of the Ruby Magicians is the the Ruby API does not poll the keyboard during certain operations, so it never sees the ESC key (or any other) and cannot exit a perpetual loop.
                                        jgb
                                          I would like..... Pretty please.
                                          1. Produce a proper set of extrusion tools that is not just intended for flash roof building and can act the same as a cad program.
                                          2. Finally get rid of the extra facets and lines.
                                          3. Make a proper method of allowing close up view of components and groups for editing, WITHOUT clipping problems.
                                          I understand there are several plugins for the extrusion problem but they are limited.
                                          Oh, and 4. Continue to make the program more stable rather than adding extra functions.
                                          • 10 / 10
