    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 390.5k Views 135 Watching
    • JQLJ Offline
      JQL
      @bob james said:
      Your suggestions create 45 deg rotated squares.
      Why can't someone just make a simple extension to make an orthogonally positioned square starting from a center point?
      If you hit CTRL while designing your square or your four sided circle, you it will create the squared shape as you wish it to... (at least on 2015 I don't know if it's like this in every SU version)
      www.casca.pt
      Visit us on facebook!
        That was a new feature in SU2015.
        Bob, the extension already exists in the Tools on Surface set. I'm sure you must have that one in your library.
          The big one of the day! πŸ˜„
          I am sure that will be the same for some other users! πŸ’š
          When you make a Push Pull + CTRL that make a new volume from the start face ok
          as usual! πŸ˜„
          http://s6.postimg.org/osvrpkq1d/big_dohdoh0.gif
          but...
          that can be used also for make an "impossible Push Pull" ! 😎
          (And thx to TIG for his Solid Solver at the end! πŸ‘
          http://s6.postimg.org/hodygjis1/big_dohdoh.gif
          • Bob JamesB Offline
            Bob James
            Close, but you have to move it around until you find the axis pop-up, enter a length, stretch it in the other axis, and enter the same length. And you have to enter the half-length in each case or the square will be twice the size you want: simple except when the square is to be 4 3/16"
            Still seems like a trivial extension to make for a ruby-guy (like sdmitch,for example): pick a point and enter the size of the square (not the half length) and it automatically draws the correct size square on the orthogonal axes.
              @bob
              why not use a component library of predefined sizes?
              • JQLJ Offline
                JQL
                Well that would work with one component alone if you one unit. Insert it at point scale it using CTRL and SHIFT input your dimension.
                www.casca.pt
                • dereiD Offline
                  derei
                  I just "Discovered" the wheel... 😍
                  using "deg" or "mm" when setting the camera focal distance, can switch between actual focal distance (35mm equiv) and fov (field of view) measured in degrees. πŸ€“
                  • PixeroP Offline
                    Pixero
                    I have to add one I discovered the other week by pure accident.
                    Right click on a toolbar to see a list of all loaded and unloaded toolbars.
                      On toolbars on The Main toolbar! Not on any toolbars floating on the screen! πŸ˜‰
                      • pbacotP Offline
                        I don't think so on a Mac. (SU toolbars and windows on Mac are junk).
                        • JQLJ Offline
                          JQL
                          I'd say the only thing I envy from SU for Mac is pdf import... we don't get that on windows
                          www.casca.pt
                          • david_hD Offline
                            david_h
                            I'm posting my query here because it is probably pretty obvious to you guys out there, but I've always struggled with it. . .
                            I've always found the "Scenes" menu to be counter-intuitive and I can't seem to get it to do what I think it is telling me to do. Specifically, I want one particular scene to be a section but not others I update via the scenes menu, and ONLY that scene but when I tab thru the others the section plane is still active and I have to switch it off. what am I doing wrong. Likewise for things like various styles, or display modes, etc.
                            Please help me so I can slap my head and go "DUH!"
                            Thanks,
                            David H
                            ps My last query got absolutely no response whatsoever. Still looking for some insight on that as well.
                            Thx,
                            D
                            • gonashviliG Offline
                              gonashvili
                              I've got a question about [regular] selecting, or deselecting, rather. You hit he SHIFT key and it works as +/-, right? Is there a way to have just the 'MINUS' function, so you actually ONLY deselect?
                              Cause, when you select some objects and then when you want to deselect you actually might select some undesirable ones, know what I mean? Especially when there are a lot of lines or what not.... It actually acts as an INVERSION, rather than just DESELCTION.
                              • massimoM Offline
                                massimo Moderator
                                shift= +/-
                                ctrl+shift= -
                                ctrl= +
                                  gonashvili
                                  Oh!!! Hah, thanks a lot man!
                                  I mean, DOH! of course.
                                  • JQLJ Offline
                                    JQL
                                    Basically, you're missing the meaning of having those checkboxes checked.
                                    What they mean is:
                                    • When you're creating a scene only the settings that are checked will be stored. All unchecked settings will be not be stored. (Checking sections box on will store current sections settings. If you have an Active section it will be the active section for the scene. If you have no active section, the scene will have no section affecting it. If there are no sections in the scene, then you'll also have no section affecting it.)
                                    • When you have settings unchecked, then you're not storing a state for that section on the scene. (Unchecking Sections will make the scene don't care if a section is active or not. If you insert a section in the model, the scene will be cut, if you change to another scene and come back to this scene, the section from the other scene will still be active, if you change to a scene that has no active section, coming back will keep the scene without an active setting.) Unchecked settings are, therefore, neutral. They can be either on or off, depending on what was the current state when you changed to that scene...
                                    So, in fact, unchecking sections will not make the model fully viewable. It will "randomize" the sections on that scene, unless you know what you're doing, you'll have no control.
                                    www.casca.pt
                                    • david_hD Offline
                                      david_h
                                      thanks for the response. I think i got half of that. πŸŽ‰ But your last sentence kinda summed it up. Is there a Tutorial or something that talks about this? I thought it was much simpler and clearer back in the old days when these were called "Pages". Seemed to work better. 😞
                                      • JQLJ Offline
                                        JQL
                                        David, send me your file, I'll configure it, and send it back. Name the Scenes wisely so I know what you're talking about and describe your issues on a PM. I'll explain exactly what I did and then you could probably understand it better.
                                        www.casca.pt
                                        • david_hD Offline
                                          david_h
                                          Okay . .. I just got a new computer and have reinstalled SU. A lot of this stuff I did so long ago that I can't remember anymore how I did it. My problem here is I had a shortcut for edge style by exis that shows the axes in their respective green, red and blue colors. It used to be accessed via "View>Rendering>Axis"
                                          But on my new download of SU that is no longer there! Any ideas how I can shortcut this?
                                          Thx,
                                          D
                                            Charlie__V
                                            [attachment=2:1fhbp1h6]<!-- ia2 -->axis_1.png<!-- ia2 -->[/attachment:1fhbp1h6][attachment=1:1fhbp1h6]<!-- ia1 -->axis_2.jpg<!-- ia1 -->[/attachment:1fhbp1h6]
                                            Thx,
                                            D
                                            Should be there....I just checked on my install (SU Pro 2016)
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 30 / 35
