    A quest for better understanding of textures
    renderpluginsextensions
    39 Posts 15 Posters 126.8k Views 15 Watching
    • panixiaP
      panixia
      @eidam655 said:
      • rock/noise pattern. is not affected by UV repeat values.
      • smoke/noise pattern. is not affected by UV repeat values.
      • snow/noise pattern with alternating alpha. is not affected by UV repeat values.
      • speckle/noise pattern. is not affected by UV repeat values.
      • splat/noise pattern. is not affected by UV repeat values.
      • presumably stucco/noise pattern. is not affected by UV repeat values. sadly,
      • is not affected by UV repeat values. in fact, it's the same case as with Stucco. a
      my 50 cents to help your quest. ๐Ÿ’ญ
      recently i discovered that for the textures rock - stucco - smoke - snow - speckle - splat - water you should untick "use 3d mapping" to enable UV tiling control. ๐Ÿ‘
        jackwatson
        Has anyone ever come across any clear documentation for all of these effects? The fact that there are so many cool procedural maps available, but the tutorials for how to utilise them are not seems a waste.
        I've spent a good few hours playing around with them before but managed to get no practical use out of them because, as you know, with all the variables you can change it would take weeks or months to learn anything through trial an error.
        This is probably less of an issue for Max users who tend to have had some kind of professional training, but those who use Sketchup for visualisation are at the shallow end of the visualisation pool are largely self trained I imagine. (Along with using amazing resources such as Sketchucation, of course ๐Ÿ˜‰)
        • eidam655E
          eidam655
          well, at least i haven't, that's why i opened this thread ๐Ÿ˜„
          I'm using SketchUp 2017, V-Ray 3.4
          • B
            bbergem
            Do the original images to this thread still exist? I've been looking for this information on vray materials for a while, and this is the most promising result.. but it seems the image links are no longer valid? Or, can the information be found elsewhere?
            • eidam655E
              eidam655
              hm, it seems my access to the old server got taken down (or my files have).
              i'll try to find the images somewhere in my backups... however, all of these were for vray 1.49 and the question is how relevant they still are.
              but as i said, i'll try to find them, just in case the were.
              • NemesisN
                Nemesis
                Hi eidam655, are there any chances that you have found images from the first message?
                • eidam655E
                  eidam655
                  Hi, I haven't found the images.
                  But after the school's done in January I'll try and recreate the post again; the question is, how many people would be interested in the old 1.49 version and how many in the new VRay 2.0, since I imagine quite a lot of people have adopted the new release.
                  let me know,
                  eidam
                  • NemesisN
                    Nemesis
                    Hi eidam655, so are there some news about sample pictures?
                    • onzkiO
                      onzki
                      Hi, I bet many have asked or noticed this already- the "reset color" in material editor is greyed out since I installed Vray, now it's hard to revert to original texture after playing around with sliders. Also, my textures was automatically saved and renamed into a temp folder (Chaos Group), not a big deal though..
                      Have someone figured out how to unlink Vray from overriding my materials control? I appreciate any help, I'm really hoping to get the "reset color" button working again. Thanks a lot!
                      PS: (to Admin) If this is the wrong section, please move it. thanks!
                      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                        This is something you should report to the V-ray for SketchUp developers so they can address it.
                        (Also, it's useful to include V-Ray and SketchUp version when asking questions like this given how different version may act differently.)
                        • 2 / 2
