    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 694.7k Views 143 Watching
    • O Offline
      orei
      no one could help me?
      • cottyC Offline
        cotty
        What would you expect from such a point?
        If you only have some of these, you can move the vertices afterwards manually.
        Or you can use a plugin to smooth the surface after the creation.
        my SketchUp gallery
          Kenny
          If you only have a limited number of these points above the terrain causing the spikes then delete these points before running Toposhaper.
          http://www.townscapesolutions.co.uk/
            Why not use Triangulate Points first by TIG ?
            • dereiD Offline
              derei
              After playing with TopoShaper I ended up with several (three) terrains overlapped. Why this happened? It seems I am missing something in functionality of this plugin, so instead of refining the just created terrain, I end up with new modified copies of the terrain.
              • O Offline
                orei
                I have some deeps and some peeks. I don't know why this happened.
                I know that i can move up and down these points to get a level.. but i would like to understand how to evitate those problem.
                Why suggest to use triangulate point instead of toposhaper? toposhaper is much better than triangulate point for this, or not?
                Thanks mate!
                  It was just a suggestion for have a preview of the terrain and maybe see if there are not aeras where some confusion between near vertices are possible! πŸ˜‰
                  And give to Toposhaper faces and not only vertices! πŸ€“
                  • fredo6F Offline
                    Pilou,
                    The first iteration of TopoShaper is precisely the Delaunay Triangulation (same results normally as with the FalΓ© /TIG plugin).
                    @orei: the spikes are due to singular points with very different altitudes compared with immediate neighbours. TopoShaper CloudPoints generates a surface passing through the points.
                    My suggestion would be that:
                    • you generate the group of isocontours from the triangular mesh (an option in TopoShaper Cloud)
                    • then from the isocontours group, you generate a quad mesh terrain, using the other tool of TopoShaper.
                    This will smooth the spikes
                      πŸ˜„
                      • O Offline
                        orei
                        Sorry Fredo, tried to do what you suggest, but nothing change. I generate the group with triangular mesh (how always i did) and peek and deep are present. After that, used the quad mesh terrain, but peek and deep still present.
                        Could you, please, verify those things with my skp file previously attached to last post?
                        Thanks mate. You are the best!!!
                        • fredo6F Offline
                          Orei,
                          Your cloud points data includes these sharp peaks and deeps. Because TopoShaper Cloud ensures that the terrain surface goes through ALL the points, these peaks will be reflected in the terrain.
                          If they do not correspond to the reality, then simply discard the points or change their altitude.
                          Attached is the file with your original points in both Triangular and Quad Mesh mode.
                          SKP file
                          • pbacotP Offline
                            I find that if you to as Fredo suggests: generate terrain from the isocontours, you get a much more regular terrain and you can smooth the few remaining anomalies more easily. If you have bad points in the cloud, there is nothing the plugin can do to change that, but the above procedures helps to "average" them out some.
                              tulacong
                              good...cool...cool good ....hehehehe
                                tomaszdrgas
                                One suggestion.. Can you make option maybe in the next reliese.. "Stick with orriginal contours" for triangulated mesh.. So the plugin would not make triangles between not adjacent contour lines (for example one point of triangle on hight=2m another h=3m and third h=5m). Could be done by inforcing engine to require for points two the same hights and fird different.. simple check.. I'm crab with programming but could be nice add on.. I usually have to stick with orriginal contours...
                                  rv1974
                                  http://www.scriptspot.com/files/u1362/remesh.gif
                                  http://www.scriptspot.com/3ds-max/scripts/instant-meshes-bridge
                                  Fredo, could Toposhaper follow the contours as shown on attached gif?
                                  And, generally speaking, is doable to make a bridge to this external free retopologizer?
                                  (https://github.com/wjakob/instant-meshes)
                                  Or make something similar but independent πŸ˜‰ ?
                                  • fredo6F Offline
                                    Well. I know how to constrain the triangulation to the contours. Simply, that's not a trivial development and it requires some time. But it should come.
                                      penumbra
                                      Getting some Ruby errors with latest version,
                                      Date: 28-Aug-16 15:37:45
                                      An error occurred in CALCULATING TERRAINS
                                      The operation is fully aborted
                                      undefined method `x' for nil:NilClass
                                      mesh.rb: 134 -- ==
                                      TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
                                      TopoShaperAlgo.rb: 1996 -- each
                                      TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
                                      TopoShaperAlgo.rb: 1979 -- each
                                      TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
                                      TopoShaperAlgo.rb: 1089 -- grid_mark_contours
                                      TopoShaperAlgo.rb: 535 -- top_analysis_contour
                                      TopoShaperAlgo.rb: 418 -- top_processing
                                      TopoShaperTool.rb: 574 -- algo_processing
                                      TopoShaperTool.rb: 666 -- execute_validate
                                      TopoShaperPalette.rb: 130 -- execute_from_palette
                                      TopoShaperPalette.rb: 76 -- notify_from_palette
                                      TopoShaperPalette.rb: 518 -- call
                                      TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
                                      body_Lib6Palette.rb: 3058 -- call
                                      body_Lib6Palette.rb: 3058 -- execute_button
                                      body_Lib6Palette.rb: 2865 -- onLButtonUp
                                      Lib6Palette.rb: 93 -- onLButtonUp
                                      TopoShaperTool.rb: 984 -- onLButtonUp
                                      Thoughts? If it is helpful i have attached the file i am having trouble with.
                                      Topo File
                                        penumbra
                                        OK upon further inspection the errors above were causd by a conflict between toposhaper and the flux.io plugin for sketchup. Hope this is helpful for someone.
                                        • array81A Offline
                                          array81
                                          After created a terrain, is there a way to show the "grid" on it? I see only the surface but would be nice to see the points of the grid for editing.
                                          • fredo6F Offline
                                            Are you generating the terrain
                                            • from Isocontours
                                            • or from a point cloud ?
                                            And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
                                            • 22
                                            • 23
                                            • 4 / 23
