    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • fredo6F
      Pilou,
      Could you post the file with the point cloud. I'll check for the missing triangle and the missing message.
      Which Sketchup version do you use by the way?
        It was from the file previous linked! πŸ˜„
        But here with the points! πŸ˜‰
        I have the 2015 and all at the last versions (plug and Lib) !
        test_topo_points.skp
          Resolved! πŸ˜„
          We must press Concave contour first! 😳
          • B
            Ben Ritter
            When I run the toposhaper using terrain generator, although the contour lines setting is set to 1.0' increments, the first contour line above O.O' becomes 0.783' instead of 1.0'. After that, the contour line intervals are all 1.0' apart.
            What could be the cause of this? How can I fix this?
            Thanks. Ben
            • B
              Ben Ritter
              topo.skpHere is the file of cloud points
              • O
                orei
                Hi my friends,
                i have a little problem.. i tried to model a cloud point to get a soil.. everything ok, except some peek and deep that the plugin generate, and i don't know to get rid.
                You see in the attached screen, and in the skp file with point.
                Hope in your help! Thanks man!!
                PE_9064 - MODELLAZIONE TERRENO_light.skp
                • O
                  orei
                  no one could help me?
                  • cottyC
                    cotty
                    What would you expect from such a point?
                    If you only have some of these, you can move the vertices afterwards manually.
                    Or you can use a plugin to smooth the surface after the creation.
                    my SketchUp gallery
                    • K
                      Kenny
                      If you only have a limited number of these points above the terrain causing the spikes then delete these points before running Toposhaper.
                      http://www.townscapesolutions.co.uk/
                        Why not use Triangulate Points first by TIG ?
                        • dereiD
                          derei
                          After playing with TopoShaper I ended up with several (three) terrains overlapped. Why this happened? It seems I am missing something in functionality of this plugin, so instead of refining the just created terrain, I end up with new modified copies of the terrain.
                          DESIGNER AND ARTIST DEREI.UK
                          • O
                            orei
                            I have some deeps and some peeks. I don't know why this happened.
                            I know that i can move up and down these points to get a level.. but i would like to understand how to evitate those problem.
                            Why suggest to use triangulate point instead of toposhaper? toposhaper is much better than triangulate point for this, or not?
                            Thanks mate!
                              It was just a suggestion for have a preview of the terrain and maybe see if there are not aeras where some confusion between near vertices are possible! πŸ˜‰
                              And give to Toposhaper faces and not only vertices! πŸ€“
                              • fredo6F
                                Pilou,
                                The first iteration of TopoShaper is precisely the Delaunay Triangulation (same results normally as with the FalΓ© /TIG plugin).
                                @orei: the spikes are due to singular points with very different altitudes compared with immediate neighbours. TopoShaper CloudPoints generates a surface passing through the points.
                                My suggestion would be that:
                                • you generate the group of isocontours from the triangular mesh (an option in TopoShaper Cloud)
                                • then from the isocontours group, you generate a quad mesh terrain, using the other tool of TopoShaper.
                                This will smooth the spikes
                                  πŸ˜„
                                  • O
                                    orei
                                    Sorry Fredo, tried to do what you suggest, but nothing change. I generate the group with triangular mesh (how always i did) and peek and deep are present. After that, used the quad mesh terrain, but peek and deep still present.
                                    Could you, please, verify those things with my skp file previously attached to last post?
                                    Thanks mate. You are the best!!!
                                    • fredo6F
                                      Orei,
                                      Your cloud points data includes these sharp peaks and deeps. Because TopoShaper Cloud ensures that the terrain surface goes through ALL the points, these peaks will be reflected in the terrain.
                                      If they do not correspond to the reality, then simply discard the points or change their altitude.
                                      Attached is the file with your original points in both Triangular and Quad Mesh mode.
                                      SKP file
                                      • pbacotP
                                        I find that if you to as Fredo suggests: generate terrain from the isocontours, you get a much more regular terrain and you can smooth the few remaining anomalies more easily. If you have bad points in the cloud, there is nothing the plugin can do to change that, but the above procedures helps to "average" them out some.
                                        • T
                                          tulacong
                                          good...cool...cool good ....hehehehe
                                          • T
                                            tomaszdrgas
                                            One suggestion.. Can you make option maybe in the next reliese.. "Stick with orriginal contours" for triangulated mesh.. So the plugin would not make triangles between not adjacent contour lines (for example one point of triangle on hight=2m another h=3m and third h=5m). Could be done by inforcing engine to require for points two the same hights and fird different.. simple check.. I'm crab with programming but could be nice add on.. I usually have to stick with orriginal contours...
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
