    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 830.9k Views 143 Watching
      Ben Ritter
      When I run the toposhaper using terrain generator, although the contour lines setting is set to 1.0' increments, the first contour line above O.O' becomes 0.783' instead of 1.0'. After that, the contour line intervals are all 1.0' apart.
      What could be the cause of this? How can I fix this?
      Thanks. Ben
        Ben Ritter
        topo.skpHere is the file of cloud points
        • O Offline
          orei
          Hi my friends,
          i have a little problem.. i tried to model a cloud point to get a soil.. everything ok, except some peek and deep that the plugin generate, and i don't know to get rid.
          You see in the attached screen, and in the skp file with point.
          Hope in your help! Thanks man!!
          PE_9064 - MODELLAZIONE TERRENO_light.skp
          • O Offline
            orei
            no one could help me?
            • cottyC Offline
              cotty
              What would you expect from such a point?
              If you only have some of these, you can move the vertices afterwards manually.
              Or you can use a plugin to smooth the surface after the creation.
              my SketchUp gallery
                Kenny
                If you only have a limited number of these points above the terrain causing the spikes then delete these points before running Toposhaper.
                http://www.townscapesolutions.co.uk/
                  Why not use Triangulate Points first by TIG ?
                  • dereiD Offline
                    derei
                    After playing with TopoShaper I ended up with several (three) terrains overlapped. Why this happened? It seems I am missing something in functionality of this plugin, so instead of refining the just created terrain, I end up with new modified copies of the terrain.
                    DESIGNER AND ARTIST DEREI.UK
                    • O Offline
                      orei
                      I have some deeps and some peeks. I don't know why this happened.
                      I know that i can move up and down these points to get a level.. but i would like to understand how to evitate those problem.
                      Why suggest to use triangulate point instead of toposhaper? toposhaper is much better than triangulate point for this, or not?
                      Thanks mate!
                        It was just a suggestion for have a preview of the terrain and maybe see if there are not aeras where some confusion between near vertices are possible! ๐Ÿ˜‰
                        And give to Toposhaper faces and not only vertices! ๐Ÿค“
                        • fredo6F Offline
                          Pilou,
                          The first iteration of TopoShaper is precisely the Delaunay Triangulation (same results normally as with the Falรฉ /TIG plugin).
                          @orei: the spikes are due to singular points with very different altitudes compared with immediate neighbours. TopoShaper CloudPoints generates a surface passing through the points.
                          My suggestion would be that:
                          • you generate the group of isocontours from the triangular mesh (an option in TopoShaper Cloud)
                          • then from the isocontours group, you generate a quad mesh terrain, using the other tool of TopoShaper.
                          This will smooth the spikes
                            ๐Ÿ˜„
                            • O Offline
                              orei
                              Sorry Fredo, tried to do what you suggest, but nothing change. I generate the group with triangular mesh (how always i did) and peek and deep are present. After that, used the quad mesh terrain, but peek and deep still present.
                              Could you, please, verify those things with my skp file previously attached to last post?
                              Thanks mate. You are the best!!!
                              • fredo6F Offline
                                Orei,
                                Your cloud points data includes these sharp peaks and deeps. Because TopoShaper Cloud ensures that the terrain surface goes through ALL the points, these peaks will be reflected in the terrain.
                                If they do not correspond to the reality, then simply discard the points or change their altitude.
                                Attached is the file with your original points in both Triangular and Quad Mesh mode.
                                SKP file
                                • pbacotP Offline
                                  I find that if you to as Fredo suggests: generate terrain from the isocontours, you get a much more regular terrain and you can smooth the few remaining anomalies more easily. If you have bad points in the cloud, there is nothing the plugin can do to change that, but the above procedures helps to "average" them out some.
                                    tulacong
                                    good...cool...cool good ....hehehehe
                                      tomaszdrgas
                                      One suggestion.. Can you make option maybe in the next reliese.. "Stick with orriginal contours" for triangulated mesh.. So the plugin would not make triangles between not adjacent contour lines (for example one point of triangle on hight=2m another h=3m and third h=5m). Could be done by inforcing engine to require for points two the same hights and fird different.. simple check.. I'm crab with programming but could be nice add on.. I usually have to stick with orriginal contours...
                                        rv1974
                                        http://www.scriptspot.com/files/u1362/remesh.gif
                                        http://www.scriptspot.com/3ds-max/scripts/instant-meshes-bridge
                                        Fredo, could Toposhaper follow the contours as shown on attached gif?
                                        And, generally speaking, is doable to make a bridge to this external free retopologizer?
                                        (https://github.com/wjakob/instant-meshes)
                                        Or make something similar but independent ๐Ÿ˜‰ ?
                                        • fredo6F Offline
                                          Well. I know how to constrain the triangulation to the contours. Simply, that's not a trivial development and it requires some time. But it should come.
                                            penumbra
                                            Getting some Ruby errors with latest version,
                                            Date: 28-Aug-16 15:37:45
                                            An error occurred in CALCULATING TERRAINS
                                            The operation is fully aborted
                                            undefined method `x' for nil:NilClass
                                            mesh.rb: 134 -- ==
                                            TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
                                            TopoShaperAlgo.rb: 1996 -- each
                                            TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
                                            TopoShaperAlgo.rb: 1979 -- each
                                            TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
                                            TopoShaperAlgo.rb: 1089 -- grid_mark_contours
                                            TopoShaperAlgo.rb: 535 -- top_analysis_contour
                                            TopoShaperAlgo.rb: 418 -- top_processing
                                            TopoShaperTool.rb: 574 -- algo_processing
                                            TopoShaperTool.rb: 666 -- execute_validate
                                            TopoShaperPalette.rb: 130 -- execute_from_palette
                                            TopoShaperPalette.rb: 76 -- notify_from_palette
                                            TopoShaperPalette.rb: 518 -- call
                                            TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
                                            body_Lib6Palette.rb: 3058 -- call
                                            body_Lib6Palette.rb: 3058 -- execute_button
                                            body_Lib6Palette.rb: 2865 -- onLButtonUp
                                            Lib6Palette.rb: 93 -- onLButtonUp
                                            TopoShaperTool.rb: 984 -- onLButtonUp
                                            Thoughts? If it is helpful i have attached the file i am having trouble with.
                                            Topo File
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
