    SketchUp 2015 spring egg hunt
    32 Posts 8 Posters 3.1k Views 8 Watching
      Davor is my name and a place in my country, but it is not an answer - it doesn't have an egg ( )
        ( ) Bloemfontein occurs twice in the SKP - once in a component-definition's description and then in its component-instance's description [i.e. the one with '()Trondheim' appended to its definition name]...
        'Bloemfontein' is a town in South Africa, but it doesn't seem to exist anywhere else - so can its 'egg' be counted twice ?
        The instance.description is not user visible, but can be seen using this:
        d=Sketchup.active_model.definitions['Grass_instance( ) Trondheim'] #<Sketchup::ComponentDefinition:0x0000000adb3918> p d.description "( ) Bloemfontein" d.instances.each{|i| p i.description } "( ) Bloemfontein" [#<Sketchup::ComponentInstance:0x0000000b590e10>]
          @box said:
          I'm in the pub on my phone so can't check. But from memory I went to the watermark tab, it said () Surabaya
          You are correct.
            I know we are discounting any names without a leading ( ) πŸ˜’
            But as an aside, the Model Info's default font for Text and Dims is set to 'Tahoma' - which is a city is California ! πŸ˜‰
            • BoxB Offline
              I wish people wouldn't edit out their posts with invisible mod powers so you look like an idiot.
              • BoxB Offline
                Tig you are starting to sound a bit desperate with your answers.
                Take a breath and picture fluffy clouds and kittens, .... then when you realise you have spent the last 12 hours on youtube cat videos wrap your mind around a different philosophical/mathematical conundrum.
                By parting the Red Sea at that specific point on the coast how many Israelites did Noah actually save?
                • jeff hammondJ Offline
                  that's just how the forum software is set up.. i edit a post in the same exact way you do except it doesn't add the note..
                  more effort is required to add the note and i honestly never think about doing the extra steps.
                  i do understand your point and would find it frustrating as well.. just pointing out that if a mod edits their post, it's not like we're sitting there going "ok, i'm going to do it this way so nobody can see that i've edited'..
                  maybe it should be set up the other way around? a moderator edit defaults to adding the note and requires extra effort to remove the note?
                  idk, not really my call.
                  edit-
                  on a side note-- i've looked all over for this damn 12th egg and can't find it
                    I can't find #12 either... πŸ˜’
                    BUT there are TWO separate entries for '() Bloemfontein' - as I pointed out.
                    Box mistook a simple delete for an edit.
                    He reported a find, with no clue as to its loaction.
                    I asked where it was.
                    He said it was in the watermark.
                    I looked in the Style and found nothing there.
                    I posted saying so.
                    But I was also reloading the SKP and then I found it was there - presumably something unexplained had happened to the Style my-end in the meanwhile, so it had mysteriously vanished.
                    So I [almost] immediately delete the post, as it was simply wrong - but immediately afterwards Box re-posted, having seen it.
                    So I agreed with him by re-quoting him.
                    I didn't think his response post looked stupid...
                    Had my post been up longer than a few seconds I might not have deleted it, but edited it with a correction...
                    Anyone can delete their own posts - it does not need super-mod/admin powers...
                    Mods/admins rarely 'delete' posts - the only time I'd do that is if a newbie posts the same thing twice etc...
                    I occasionally edit a post if it contains a glaring typo - e.g. making a embarrassing faux-pas - Penis vs Denis etc !
                    Now and again unacceptable posts are parked in a siding, for mods to debate at length...
                    • BoxB Offline
                      I didn't mean it to be a big deal and your explanation is very clear. It was just that I scrolled back up and thought wtf where did it go. And just to correct you a tiny bit, it is only possible for us to delete a post if there are no posts after it. As soon as someone replies it is locked in, we can edit it but can't delete it.
                        DavorP
                        If Bloemfontein is somehow showing up twice, it shouldn't. Maybe I did something wrong but I only added it to the component definition description.
                        The last one is harder, exponentially harder.
                          is it something that should be findable with a normal sketchup installation and/or won't require some certain plugin to be installed ..or a particular OS ?
                          because i can't find:
                          Zhengzhou (texture)
                          ..on my computers (macs).. also, when i try to open my skindigo material editor with your model, it's broken/won't open.. i'm assuming it's some sort of clash with podium?
                            The ( ) Zhengzhou.jpg is the texture's image-file associated with the Material with the display_name SketchUp Logo ( ) Boulder
                            So you get two eggs for the price of one. πŸ˜‰
                            On a MAC can't you see the texture's image-file name ?
                              not that i know of..
                              mac is limited to seeing the material name via a tooltip when hovering over the material or it can be seen when editing it.
                                So on a MAC if you go to save the material's texture to file what happens ?
                                  i didn't know that's possible and i don't think the ability is there on mac.. if i right-click the material, these are the options i get:
                                    On MAC.
                                    Open the Material dialog.
                                    Select the logo material icon [in model].
                                    Context-menu > Edit
                                    To the right of its name is an option to edit in an external image editor.
                                    Choose that and the image file opens in whatever app you have set in the Preferences.
                                    That shows you the name of the image file...
                                    On PC.
                                    Click the Tab named 'Edit'.
                                    The image file name is shown in the bottom half of the Edit pane [called 'Texture'].
                                    Immediately to the right of the name is an option to save the texture as an external file
                                    To the right of that is an option to edit in an external image editor.
                                    That also shows you the name of the image file...
                                    In addition to these extra options compared to a MAC, there is also a 'Colorize' check-box and a Color-Reset option in that pane on PC.
                                    The Materials on a PC are much easier to use than on a MAC !
                                      @tig said:
                                      On MAC.
                                      Context-menu > Edit
                                      for whatever reason, there's something weird about this egg model with my computers and the materials.. like i said earlier, it breaks skindigo's material editor (can't open the material editor while this model is open).. also, can't edit the material with an external app. I get this:
                                      whereas doing the same thing with other models works fine when editing materials externally (in pixelmator.app)
                                      yeah, that's what i gathered over the years.. the mac materials browser could most certainly use an overhaul.. we don't even have a list view and can only see thumbnails of the materials. πŸ˜•
                                        slbaumgartner
                                        Drifting off topic a bit, but I've always thought the materials editor on Mac was driven more by reuse of the standard Mac OS color UI than by an effort to provide a useful tool in SketchUp! The concepts just don't quite line up, and it results in a very awkward SketchUp tool.
                                          further, sketchup hijacks the osx 'color palette' which is the one with a list view.. renames it to 'texture palette' and takes away the list capability.. this is especially problematic when a model has different materials of similar color yet varying properties (such as black leather and black shiny paint in the same model.. there's no simple way to differentiate between the two via the color picker)
                                          the color picker elsewhere in osx has a list view palette.. sketchup cancels the ability.
                                          • 2 / 2
