    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Have you installed the very latest version of SketchUp v2015 ?
      It did previously have some issues with the MAC update to 'Yosemite'...
      Try disabling the jbb_layers_panel plugin.
      After a restart any improvement ?
      It has observers etc and has been linked to some issues with MACs...
      My Mirror plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate.
      • emnE Offline
        emn
        TIG,
        Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
        Thank you so much....
        • emnE Offline
          emn
          Oops.... A bit premature.... It still crashes.....
          • emnE Offline
            emn
            Installing the newest sketch up version did the trick.... (again: So far...)
            • tt_suT Offline
              tt_su
              @emn said:
              Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
              Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
              Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
              Anyone?
              Did you submit the BugSplats?
              If you did - did you enter any details in the report? Description, name or email I can use to look up the crash?
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
                LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
                See main post of this thread for Download of LibFredo6.
                  coby1012
                    Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
                    Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
                    • fredo6F Offline
                      It would be a bug. There is no need for LibFredo to have traces in the Ruby console.
                      Could you tell me what is output in the console so that I remove the traces
                      Thanks very much
                        driven
                        not sure what TT gets, but I see this on every start-up...
                        (eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here (eval):1: warning: already initialized constant Traductor::RUN_ON_MAC /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
                        • fredo6F Offline
                          OK. Thanks. Will fix and re-release.
                          These Ruby warnings are always ennoyng, and none has found a way to get rid of them.
                          I thought it was some puts forgotten in the code.
                            driven
                            @fredo6 said:
                            ...none has found a way to get rid of them.
                            I used to get them from a few different plugins and adding if not defined? e.g. CAS = @cascade if not defined? CAS, but when looking through you dynamic code, I just couldn't work out where that might be added...
                            the other way is to load a 'Ruby Console' loader as the last ruby file...
                              Hmm... I just assumed it was LibFredo.. Might have been Bezier Spline as well. I had to temporarily remove them to do some development, but I'll install again and track down the exact messages.
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v6.7b - 22 Mar 15
                                LibFredo6 6.7b is a minor releaseremoving some noisy traces at Startup of Sketchup
                                • fredo6F Offline
                                  You assumed right!
                                  Actually most noisy traces were coming from BezierSpline, but I removed also two traces in LibFredo6.
                                  So you'll have to upgrade both
                                  • BezierSpline 2.7b
                                  • LibFredo6 6.7b
                                  • jiminy-billy-bobJ Offline
                                    jiminy-billy-bob
                                    I still get this :
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:28: warning: already initialized constant Traductor::LBT__DEF
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:31: warning: previous definition of LBT__DEF was here
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:32: warning: already initialized constant Traductor::VALID_ERROR
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:35: warning: previous definition of VALID_ERROR was here
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:34: warning: already initialized constant Traductor::VALID_MIN
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:38: warning: previous definition of VALID_MIN was here
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:35: warning: already initialized constant Traductor::VALID_MAX
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:39: warning: previous definition of VALID_MAX was here
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:36: warning: already initialized constant Traductor::VALID_PATTERN
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:40: warning: previous definition of VALID_PATTERN was here
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: redefining constant Struct::DlgItem
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: already initialized constant Traductor::DialogBox::DlgItem
                                    C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:183: warning: previous definition of DlgItem was here
                                      I think a 'loose' LibTraductor file is très old, its now kept in the LibFredo folder ?
                                      I believe that if you removed it altogether Fredo's tools should still work just fine after a restart...
                                      If any RB file is [re]loaded which remakes existing Constants, then those warnings always appear in the Ruby Console.
                                      If you are duplicating the translation code with two versions loading Ruby will warn you...
                                        Same as Jimini - I removed all files from previous versions, including the LibTraductor.rb - after installing I got warnings:
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;31; warning; already initialized constant Traductor;;LBT__DEF
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;28; warning; previous definition of LBT__DEF was here
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;35; warning; already initialized constant Traductor;;VALID_ERROR
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;32; warning; previous definition of VALID_ERROR was here
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;38; warning; already initialized constant Traductor;;VALID_MIN
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;34; warning; previous definition of VALID_MIN was here
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;39; warning; already initialized constant Traductor;;VALID_MAX
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;35; warning; previous definition of VALID_MAX was here
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;40; warning; already initialized constant Traductor;;VALID_PATTERN
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;36; warning; previous definition of VALID_PATTERN was here
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; redefining constant Struct;;DlgItem
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; already initialized constant Traductor;;DialogBox;;DlgItem
                                        C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; previous definition of DlgItem was here
                                          The previous post was what I got upon install. When I restart I get more:
                                          args = ["Bezier"]
                                          args = ["BZ__Polyline"]
                                          args = ["BZ__Animation"]
                                          args = ["BZ__Arc"]
                                          args = ["BZ__BSplineU"]
                                          args = ["BZ__Catmull"]
                                          args = ["BZ__Chamfer"]
                                          args = ["BZ__Courbette"]
                                          args = ["BZ__CubicBezier"]
                                          args = ["BZ__Divider"]
                                          args = ["BZ__DogBone"]
                                          args = ["BZ__TBone"]
                                          args = ["BZ__FSpline"]
                                          args = ["BZ__Segmentor"]
                                          args = []
                                          args = []
                                          args = []
                                          args = []
                                          args = ["Edition"]
                                          args = []
                                          args = []
                                          args = []
                                          args = []
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;28; warning; already initialized constant Traductor;;LBT__DEF
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;31; warning; previous definition of LBT__DEF was here
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;32; warning; already initialized constant Traductor;;VALID_ERROR
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;35; warning; previous definition of VALID_ERROR was here
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;34; warning; already initialized constant Traductor;;VALID_MIN
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;38; warning; previous definition of VALID_MIN was here
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;35; warning; already initialized constant Traductor;;VALID_MAX
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;39; warning; previous definition of VALID_MAX was here
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;36; warning; already initialized constant Traductor;;VALID_PATTERN
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;40; warning; previous definition of VALID_PATTERN was here
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; redefining constant Struct;;DlgItem
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; already initialized constant Traductor;;DialogBox;;DlgItem
                                          C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; previous definition of DlgItem was here
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v6.7c - 22 Mar 15
                                            LibFredo6 6.7b is a second minor release removing some noisy traces at Startup of Sketchup. I hope this will make it!
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 109
                                            • 110
                                            • 59 / 110
