    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • emnE
      emn
      Installing the newest sketch up version did the trick.... (again: So far...)
      • tt_suT
        tt_su
        @emn said:
        Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
        Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
        Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
        Anyone?
        Did you submit the BugSplats?
        If you did - did you enter any details in the report? Description, name or email I can use to look up the crash?
        • fredo6F
          NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
          LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
          See main post of this thread for Download of LibFredo6.
          • C
            coby1012
              Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
              Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
              • fredo6F
                It would be a bug. There is no need for LibFredo to have traces in the Ruby console.
                Could you tell me what is output in the console so that I remove the traces
                Thanks very much
                  driven
                  not sure what TT gets, but I see this on every start-up...
                  (eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here (eval):1: warning: already initialized constant Traductor::RUN_ON_MAC /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
                  • fredo6F
                    OK. Thanks. Will fix and re-release.
                    These Ruby warnings are always ennoyng, and none has found a way to get rid of them.
                    I thought it was some puts forgotten in the code.
                      driven
                      @fredo6 said:
                      ...none has found a way to get rid of them.
                      I used to get them from a few different plugins and adding if not defined? e.g. CAS = @cascade if not defined? CAS, but when looking through you dynamic code, I just couldn't work out where that might be added...
                      the other way is to load a 'Ruby Console' loader as the last ruby file...
                        Hmm... I just assumed it was LibFredo.. Might have been Bezier Spline as well. I had to temporarily remove them to do some development, but I'll install again and track down the exact messages.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v6.7b - 22 Mar 15
                          LibFredo6 6.7b is a minor releaseremoving some noisy traces at Startup of Sketchup
                          • fredo6F
                            You assumed right!
                            Actually most noisy traces were coming from BezierSpline, but I removed also two traces in LibFredo6.
                            So you'll have to upgrade both
                            • BezierSpline 2.7b
                            • LibFredo6 6.7b
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              I still get this :
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:28: warning: already initialized constant Traductor::LBT__DEF
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:31: warning: previous definition of LBT__DEF was here
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:32: warning: already initialized constant Traductor::VALID_ERROR
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:35: warning: previous definition of VALID_ERROR was here
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:34: warning: already initialized constant Traductor::VALID_MIN
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:38: warning: previous definition of VALID_MIN was here
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:35: warning: already initialized constant Traductor::VALID_MAX
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:39: warning: previous definition of VALID_MAX was here
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:36: warning: already initialized constant Traductor::VALID_PATTERN
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:40: warning: previous definition of VALID_PATTERN was here
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: redefining constant Struct::DlgItem
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: already initialized constant Traductor::DialogBox::DlgItem
                              C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:183: warning: previous definition of DlgItem was here
                                I think a 'loose' LibTraductor file is très old, its now kept in the LibFredo folder ?
                                I believe that if you removed it altogether Fredo's tools should still work just fine after a restart...
                                If any RB file is [re]loaded which remakes existing Constants, then those warnings always appear in the Ruby Console.
                                If you are duplicating the translation code with two versions loading Ruby will warn you...
                                  Same as Jimini - I removed all files from previous versions, including the LibTraductor.rb - after installing I got warnings:
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;31; warning; already initialized constant Traductor;;LBT__DEF
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;28; warning; previous definition of LBT__DEF was here
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;35; warning; already initialized constant Traductor;;VALID_ERROR
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;32; warning; previous definition of VALID_ERROR was here
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;38; warning; already initialized constant Traductor;;VALID_MIN
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;34; warning; previous definition of VALID_MIN was here
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;39; warning; already initialized constant Traductor;;VALID_MAX
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;35; warning; previous definition of VALID_MAX was here
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;40; warning; already initialized constant Traductor;;VALID_PATTERN
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;36; warning; previous definition of VALID_PATTERN was here
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; redefining constant Struct;;DlgItem
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; already initialized constant Traductor;;DialogBox;;DlgItem
                                  C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; previous definition of DlgItem was here
                                    The previous post was what I got upon install. When I restart I get more:
                                    args = ["Bezier"]
                                    args = ["BZ__Polyline"]
                                    args = ["BZ__Animation"]
                                    args = ["BZ__Arc"]
                                    args = ["BZ__BSplineU"]
                                    args = ["BZ__Catmull"]
                                    args = ["BZ__Chamfer"]
                                    args = ["BZ__Courbette"]
                                    args = ["BZ__CubicBezier"]
                                    args = ["BZ__Divider"]
                                    args = ["BZ__DogBone"]
                                    args = ["BZ__TBone"]
                                    args = ["BZ__FSpline"]
                                    args = ["BZ__Segmentor"]
                                    args = []
                                    args = []
                                    args = []
                                    args = []
                                    args = ["Edition"]
                                    args = []
                                    args = []
                                    args = []
                                    args = []
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;28; warning; already initialized constant Traductor;;LBT__DEF
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;31; warning; previous definition of LBT__DEF was here
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;32; warning; already initialized constant Traductor;;VALID_ERROR
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;35; warning; previous definition of VALID_ERROR was here
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;34; warning; already initialized constant Traductor;;VALID_MIN
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;38; warning; previous definition of VALID_MIN was here
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;35; warning; already initialized constant Traductor;;VALID_MAX
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;39; warning; previous definition of VALID_MAX was here
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;36; warning; already initialized constant Traductor;;VALID_PATTERN
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;40; warning; previous definition of VALID_PATTERN was here
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; redefining constant Struct;;DlgItem
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;570; warning; already initialized constant Traductor;;DialogBox;;DlgItem
                                    C;/Users/tthomas2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb;183; warning; previous definition of DlgItem was here
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v6.7c - 22 Mar 15
                                      LibFredo6 6.7b is a second minor release removing some noisy traces at Startup of Sketchup. I hope this will make it!
                                        Perfect! Thank you Fredo! 😍
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          • E
                                            Evil Shrike
                                            Error with the location of the directory LIBFREDO6_DATA_Dir (on root drive instead catalog on this drive) has been going on for a long time. Is there a chance to solve it? Garbage in the root of drive is not very happy.
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 113
                                            • 114
                                            • 48 / 114
