    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.5m Views 580 Watching
      cemileca
      Dear Fredo Curviloft not working in 2015 SU. Please help us
        In Fredo's absence... Have you installed the latest version from RBZ from the PluginStore ?
        http://sketchucation.com/pluginstore?pln=Curviloft
        Have you also installed the latest version of the LibFredo ?
        http://sketchucation.com/pluginstore?pln=LibFredo6
        Have you then restarted SketchUp to effect the updates ?
        If so how is it 'not working' ?
        e.g.
        Not loading ?
        Not functioning as expected ?
        Error messages ?
        etc...
        Help us to help you...
          cemileca
          You are Super,
          Plugin Working...
          Thank you Very Very much for your attention and interest..
            SRoland
            Hy
            I install LibFredo 6.6b (SU2015) but not show the toolbar. I set the "Prefered language" EN. On SU toolbars panel not appear Fredo6 toolbar, but install other plugin that immediately appear on toolbar.
            Please help.
            • emnE Offline
              emn
              Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
              Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
              Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
              Anyone?
                Have you installed the very latest version of SketchUp v2015 ?
                It did previously have some issues with the MAC update to 'Yosemite'...
                Try disabling the jbb_layers_panel plugin.
                After a restart any improvement ?
                It has observers etc and has been linked to some issues with MACs...
                My Mirror plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate.
                • emnE Offline
                  emn
                  TIG,
                  Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
                  Thank you so much....
                  • emnE Offline
                    emn
                    Oops.... A bit premature.... It still crashes.....
                    • emnE Offline
                      emn
                      Installing the newest sketch up version did the trick.... (again: So far...)
                      • tt_suT Offline
                        tt_su
                        Anyone?
                        Did you submit the BugSplats?
                        If you did - did you enter any details in the report? Description, name or email I can use to look up the crash?
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
                          LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
                          See main post of this thread for Download of LibFredo6.
                            coby1012
                              Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
                              Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
                              • fredo6F Offline
                                It would be a bug. There is no need for LibFredo to have traces in the Ruby console.
                                Could you tell me what is output in the console so that I remove the traces
                                Thanks very much
                                  driven
                                  not sure what TT gets, but I see this on every start-up...
                                  (eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here (eval):1: warning: already initialized constant Traductor::RUN_ON_MAC /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
                                  • fredo6F Offline
                                    OK. Thanks. Will fix and re-release.
                                    These Ruby warnings are always ennoyng, and none has found a way to get rid of them.
                                    I thought it was some puts forgotten in the code.
                                      driven
                                      @fredo6 said:
                                      ...none has found a way to get rid of them.
                                      I used to get them from a few different plugins and adding if not defined? e.g. CAS = @cascade if not defined? CAS, but when looking through you dynamic code, I just couldn't work out where that might be added...
                                      the other way is to load a 'Ruby Console' loader as the last ruby file...
                                        Hmm... I just assumed it was LibFredo.. Might have been Bezier Spline as well. I had to temporarily remove them to do some development, but I'll install again and track down the exact messages.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v6.7b - 22 Mar 15
                                          LibFredo6 6.7b is a minor releaseremoving some noisy traces at Startup of Sketchup
                                          • fredo6F Offline
                                            You assumed right!
                                            Actually most noisy traces were coming from BezierSpline, but I removed also two traces in LibFredo6.
                                            So you'll have to upgrade both
                                            • BezierSpline 2.7b
                                            • LibFredo6 6.7b
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 111
                                            • 112
                                            • 48 / 112
