    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 585 Posters 9.8m Views 587 Watching
    • OxerO
      Oxer
      Spanish Language LibFredo6 v6.6a
      LibFredo6_ES.lang.zip
      • fredo6F
        NEW RELEASE: LibFredo6 v6.6b - 18 Jan 15
        LibFredo6 6.6b is a small update of the v6.6a release mainly for FredoTools::ElementStats 1.0 (Interactive Statistics on Model and Entities). It fixes a few bugs and some adjustments. Il also includes an update to the Spanish translation by Oxer.
        See main post of this thread for Download of LibFredo6.
        • L
          Lokal
          Thank
          • C
            cemileca
            Dear Fredo Curviloft not working in 2015 SU. Please help us
              In Fredo's absence... Have you installed the latest version from RBZ from the PluginStore ?
              http://sketchucation.com/pluginstore?pln=Curviloft
              Have you also installed the latest version of the LibFredo ?
              http://sketchucation.com/pluginstore?pln=LibFredo6
              Have you then restarted SketchUp to effect the updates ?
              If so how is it 'not working' ?
              e.g.
              Not loading ?
              Not functioning as expected ?
              Error messages ?
              etc...
              Help us to help you...
              • C
                cemileca
                You are Super,
                Plugin Working...
                Thank you Very Very much for your attention and interest..
                  SRoland
                  Hy
                  I install LibFredo 6.6b (SU2015) but not show the toolbar. I set the "Prefered language" EN. On SU toolbars panel not appear Fredo6 toolbar, but install other plugin that immediately appear on toolbar.
                  Please help.
                  • emnE
                    emn
                    Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
                    Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
                    Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
                    Anyone?
                      Have you installed the very latest version of SketchUp v2015 ?
                      It did previously have some issues with the MAC update to 'Yosemite'...
                      Try disabling the jbb_layers_panel plugin.
                      After a restart any improvement ?
                      It has observers etc and has been linked to some issues with MACs...
                      My Mirror plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate.
                      • emnE
                        emn
                        TIG,
                        Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
                        Thank you so much....
                        • emnE
                          emn
                          Oops.... A bit premature.... It still crashes.....
                          • emnE
                            emn
                            Installing the newest sketch up version did the trick.... (again: So far...)
                            • tt_suT
                              tt_su
                              Anyone?
                              Did you submit the BugSplats?
                              If you did - did you enter any details in the report? Description, name or email I can use to look up the crash?
                              • fredo6F
                                NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
                                LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
                                • C
                                  coby1012
                                    Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
                                    Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
                                    • fredo6F
                                      It would be a bug. There is no need for LibFredo to have traces in the Ruby console.
                                      Could you tell me what is output in the console so that I remove the traces
                                      Thanks very much
                                        driven
                                        not sure what TT gets, but I see this on every start-up...
                                        (eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here (eval):1: warning: already initialized constant Traductor::RUN_ON_MAC /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
                                        • fredo6F
                                          OK. Thanks. Will fix and re-release.
                                          These Ruby warnings are always ennoyng, and none has found a way to get rid of them.
                                          I thought it was some puts forgotten in the code.
                                            driven
                                            @fredo6 said:
                                            ...none has found a way to get rid of them.
                                            I used to get them from a few different plugins and adding if not defined? e.g. CAS = @cascade if not defined? CAS, but when looking through you dynamic code, I just couldn't work out where that might be added...
                                            the other way is to load a 'Ruby Console' loader as the last ruby file...
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 113
                                            • 114
                                            • 48 / 114
