    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 360.0k Views 45 Watching
    • panixiaP
      panixia
      @box said:
      I'm not quite sure which artifacts you mean
      i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
      • cottyC
        cotty
        He did this intentionally...
        @box said:
        I deliberately wanted to create the stretch you get when you pull hot glass
        I think he reached a realistic effect in this special case. πŸ‘
        my SketchUp gallery
        • BoxB
          Thanks Cotty, Yes, I'm fully aware of how to make the faces flat or regular. That's not what I wanted, so they aren't Artifacts they are design decisions.
          Look at the shape you get when you pull a spoon out of thick honey, it's a fluid solid and behaves in a very particular way. The surface tension isn't uniform so you get stretching.
          • soloS
            @rich o brien said:
            it's ok. i just wanted to have a doodle....
            [attachment=1:jgvor0yd]<!-- ia1 -->thing2.png<!-- ia1 -->[/attachment:jgvor0yd]
            [attachment=0:jgvor0yd]<!-- ia0 -->thing.png<!-- ia0 -->[/attachment:jgvor0yd]
            Blender?
              Ultra nice! 😎
              • panixiaP
                panixia
                ok if it's intentional and you are happy with thw result that's fine πŸ‘
                i was only pointing it in case you did'nt know of the control loops stuff, when you know what you are doing, "rules" can be broke here and there β˜€
                • HieruH
                  Hieru
                  Makes sense to me.
                  Molten glass has a much greater surface tension than something like honey, so whilst you will get deformation when pulling away gathers of glass, flat surfaces will tend to remain pretty even.
                  If I was modelling this I would add control loops and then move their position to allow for varying degrees of deformation/stretch.
                  I'd forget about actually making it in glass as it would be an absolute nightmare. Pulling multiple gathers off the plate whilst maintaining it's shape is one thing, but then adding in a pre-blown centre piece and twisting the gathers before everything collapses is insane....and then you'll have to keep everything in place whilst reheating the plate so that it will form-fit with the wood.....aaaarghhhh!!!!
                  www.davidhier.co.uk
                  • BoxB
                    Obviously my 35 years of working with molten glass are meaningless.
                      @solo said:
                      Blender?
                      yes, and rendered using freestyle edges
                      • HieruH
                        Hieru
                        Pretty sure I didn't say that or give cause for you to take offence.
                        If you aren't bothered about the topology and the model/render works for your purposes, then you've done a good job. I was just offering some friendly advice on how you could improve the model next time around.
                        And just because I can see the difficulty in making the design in reality, it doesn't follow that I think you don't know what you are doing and you are not up to doing the job.
                        www.davidhier.co.uk
                        • BoxB
                          I must have a better look at Blender when I have time.
                          • panixiaP
                            panixia
                            quadface/vertextools training.. work in progress.. 😎
                            any good reference for ear topology?
                            • bazB
                              baz
                              @panixia said:
                              quadface/ 😎
                              Pardon, could you say that again?
                              • olisheaO
                                olishea
                                http://www.creativecrash.com/tutorialimages/242/009.jpg
                                oli
                                • bazB
                                  baz
                                  Ah...thanks Oli, I woz a bit sarcastic, as in simple aritsan examples. Go for it tho, its educational πŸ˜„
                                  • panixiaP
                                    panixia
                                    thanks oli.. ill'try πŸ˜„
                                      • panixiaP
                                        panixia
                                        that looks cool rich (and rather complex too)
                                        • panixiaP
                                          panixia
                                          a first try.. still to refine a lot.. πŸ˜’
                                          • HieruH
                                            Hieru
                                            Just a very simple bottle opener that I had to knock together in a rush.
                                            The model and proxy are available to download from the 3DWarehouse
                                            www.davidhier.co.uk
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
