    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 327.9k Views 45 Watching
    • HieruH Offline
      Hieru
      The modelling stages illustrated are pretty straightforward. Is there a particular stage you don't understand?
      www.davidhier.co.uk
      • bazB Offline
        baz
        @john2 said:
        @alvis said:
        original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
        This is really awesome. Can you explain the procedure for making this please? πŸ‘
        Yes it is quite awesome. Perhaps you could tell us which parts of the 'procedure' that you are wanting?
        • john2J Offline
          john2
          Hexagonal chain onwards, it was rotated and copied around a central axis,. Then what happened? You did a joint push pull I suppose, but how did the final outcome, the bend occur?
          Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
          • olisheaO Offline
            olishea
            Free Form Deformation plugin. FFD. A classic.
            Could also do it with a couple of other plugins.
            There are some other similar things on this thread:
            404 Not Found
            (sketchucation.com)
            oli
              Click image....
              [sw:36hr5zeo]8ooOjnfQxycbKwV[/sw:36hr5zeo]
              Click Image...
              [sw:36hr5zeo]kv02TBsbR5JGVgg[/sw:36hr5zeo]
              • mitcorbM Offline
                mitcorb
                Very nice, Rich:
                Which viewer is this?
                • BoxB Offline
                  I was just fiddling with some ideas while eating lunch and thought it might fit this thread.
                  I wanted a solid egg shape with pulled legs.
                  I can make it in glass, I just wanted to see if I could model and effectively show it.
                  So a very quick model, and an equally quick render.
                  The whole thing could have been done in a 30min challenge.
                  So here's the proxy and the artisan result.
                  And a very fast Twilight render.
                    Philippe Stark revival! πŸ˜„
                    • cottyC Offline
                      cotty
                      Nice example, Box!
                      my SketchUp gallery
                      • panixiaP Offline
                        panixia
                        really nice.. just try to achieve a bit cleaner topology in the bottom to avoid those little smoothing artifacts.. πŸ‘
                        • BoxB Offline
                          I'm not quite sure which artifacts you mean but I deliberately wanted to create the stretch you get when you pull hot glass.
                          I took this another step further and made the full Faberge/Stark lemon juicer with a turned wood base. The glass picks up the wood texture nicely.
                          The client specifically asked for something earthy with a modern feel and mentioned both Faberge and Stark and then threw in "but we love oriental Lacquer-ware". They looked at this today and said when can we have it.
                            wow!
                            can you wing me the proxy?
                            • BoxB Offline
                              If by the proxy you mean the rough before subdivide and smooth, No, fraid not, I'm far too casual to keep that. If I don't like something I start again or go back. Once it's working I move ahead so all I have is the model.
                                it's ok. i just wanted to have a doodle....
                                • panixiaP Offline
                                  panixia
                                  i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
                                  • cottyC Offline
                                    cotty
                                    He did this intentionally...
                                    I think he reached a realistic effect in this special case. πŸ‘
                                    my SketchUp gallery
                                    • BoxB Offline
                                      Thanks Cotty, Yes, I'm fully aware of how to make the faces flat or regular. That's not what I wanted, so they aren't Artifacts they are design decisions.
                                      Look at the shape you get when you pull a spoon out of thick honey, it's a fluid solid and behaves in a very particular way. The surface tension isn't uniform so you get stretching.
                                      • soloS Offline
                                        [attachment=1:jgvor0yd]<!-- ia1 -->thing2.png<!-- ia1 -->[/attachment:jgvor0yd]
                                        [attachment=0:jgvor0yd]<!-- ia0 -->thing.png<!-- ia0 -->[/attachment:jgvor0yd]
                                        Blender?
                                          Ultra nice! 😎
                                          • panixiaP Offline
                                            panixia
                                            ok if it's intentional and you are happy with thw result that's fine πŸ‘
                                            i was only pointing it in case you did'nt know of the control loops stuff, when you know what you are doing, "rules" can be broke here and there β˜€
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
