    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 48.0k Views 32 Watching
    • brodieB Offline
      brodie
      Great plugin, thanks TIG. Not one I'll likely use very often but I just had need of it and it worked perfectly.
      -Brodie
        DavidXJ98
        Thank you for this plugin... it's quite useful.
          MartinK
          Thanks TIG, I've got just the project for this.
          • bagateloB Offline
            bagatelo
            I set keyboard shortcuts for all the plugins I use.
            Since this script takes a long time to complete their tasks in some files, I get confused sometimes I use the shortcuts, and inadvertently I press the shortcut for this plugin. You could insert an option to be given a warning to accept or not if we want to do cleaning?
            Another interesting option is the possibility of inserting a percentage level where materials are not identical, but similar would be united into one.
            It's possible to rename all the materials in words capitalized?
            If we could make a clean sweep in the names would also help.
            Why? Try it:
            http://www.den4b.com/?x=products&product=renamer
              First things last... ๐Ÿ˜‰
              You cannot 'rename' materials via the Ruby API unless you have Sketchup >= v8M1 [OR my SKMtools installed] because material.name=string doesn't exist as a method otherwise. If the method is available then this one-liner will rename ALL materials in the model using CAPITAL letters - otherwise you'll get an error message!
              Sketchup.active_model.materials.each{|m|m.name=m.name.upcase}
              The accuracy idea would apply to what exactly ? I expect Red, Green, Blue, Alpha โ“
              At the moment the code has several tests of equivalence like
              next if mat.color.red != m0.color.red
              You can edit the code [using a plain text editor like Notepad/Notepad++ etc] to apply an accuracy thus, where you'll define the accuracy as say per=0.01 [i.e. we'll accept it as a match if it's within 1%]. You can either hardcode the 'per' or you could get this from an added dialog as the tool runs... [see below]
              So now tweak the test[s]
              next if mat.color.red > m0.color.red*(1+per) or mat.color.red < m0.color.red*(1-per)
              Repeat this for RGB and A...
              To get the accuracy from a dialog add this at the start of the code on a new line immediately after ' initialize()'
              results=inputbox(["0.NNN; "],[0.01],"Material Consolidator Accuracy")
              return nil unless results
              per=results[0]
              you then enter the required accuracy in the format 0.01 =1%, 0.1 =10%, 0.5 =50% etc.
              Obviously if you use the dialog to set the accuracy you do not need a line that says per=... elsewhere in the code!
              If you cancel the dialog the material-consolidation is aborted.
              This accuracy dialog could act as your startup prompt... BUT if you don't implement it then add this line at the start of the code instead
              return nil if UI.messagebox("Consolidate All Materials ?",MB_YESNO,"")==7
              ๐Ÿค“
              • irwanwrI Offline
                irwanwr
                thank you for the plugin ๐Ÿ˜„
                  Gabbiano
                  Really a great plugin!
                  Thank you TIG!
                  • H Offline
                    hegemonicoMX
                    Came down in the best moment. I had a horrible mess in the materials of a collaborative model. ๐Ÿ˜‰ its a blessing
                    • E Offline
                      Ecuadorian
                      Hey, TIG. How about adding some "fuzzy" logic to this? I mean, sometimes you have very similar materials that have only slightly different properties. For example, half a dozen of glasses with only slightly different tints, or slightly different alpha values, and it would be useful to consolidate them.
                      -Miguel Lescano
                      • JClementsJ Offline
                        JClements
                        A mighty handy plugin. Thanks!
                          bsfranza
                          is there somebody out there who can compile the above mentioned "accuracy" code addon into the plugin and share it with us ๐Ÿ˜„?
                          would be awesome!!
                          thanks
                            Here's v2.0 which includes optional 'tolerances' for RGBA values.
                            So you can now consolidate colors which are almost a match !
                            Use it with thought...
                            But it is one-step undo-able !
                            https://sketchucation.com/pluginstore?pln=materialconsolidator
                            Please read the updated usage notes in the first post: http://sketchucation.com/forums/viewtopic.php?p=295290#p295290
                              db11
                              Thanks TIG. This will be a very useful addition to an often-used plugin.
                              • pbacotP Offline
                                Thank you!
                                  Sorry, for any inconvenience !
                                  Here's v3.0
                                  It tweaks any options checking - to avoid unexpected results !
                                    bsfranza
                                    WOW super many muchas gracias ๐Ÿ˜„
                                    heavily appreciated!
                                    edit:
                                    of course one is never satisfied for long ...
                                    plugin works as expected now, but its kind of slow on scenes with many many polygons and the report does not state the progress or if the plugin is still working or if the app is frozen and also there are some crucial options missing...
                                    for example: work in only on entities in active context or vice versa, ignore entities and materials of active objects
                                    dont know if anyone is aware of the age old plugin material maintance - this one is quite fast with what it does ..
                                    maybe someone in the future can combine them and make a proper plugin, i personally would be happy to pay for something like that ๐Ÿ˜„
                                    • 1 Offline
                                      1010 Gunner
                                      Need help with installation or use of this plugin.
                                      'materialconsolidator' shows in my extension manager although there is no version, author etc information.
                                      It is not showing in the 'extensions' tab
                                      What do I need to do to get it to work?
                                        First thing I'd do is look in the Tools Menu where the instructions say it will be located. See the first post.
                                        If it's not there, then we need to look at how you went about installing it.
                                        What version of SketchUp are you using? Your profile indicates version 7 but it had no Extension Manager.
                                        • 1 Offline
                                          1010 Gunner
                                          That's it, thank you.
                                            SirFievel33
                                            Hey TIG, so I'm running your program on my 150MB file with many materials (~150) and components. It seems to 'freeze' on the "Making Nested Entities List." step. Takes up a lot of CPU processing power but not seeing any progress. I'm leaving it 'running' for a few hours to give it a chance to finish. If it's not frozen and working as intended, could I suggest making some form of a progress bar or status updates, maybe even a pause option. If it's not working as intended, well, consider yourself informed. ๐Ÿ˜•
                                            • 2 / 3
