    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 44.7k Views 32 Watching
      Staatsfeind
      thank you for this useful tool !
      but one question:
      how do i delete unused materials that result from objects imported by
      the warehouse and which i dont use anymore?
      to be more exactly, i tried out several warehouse objects to fit my needs
      and mixed some of them. at the end i got 50+ textures loaded but maybe only
      15 are in use. deleting all by hand would take some time.
      did i get something wrong ?
      cheers
      http://www.frenchtouchstudio.com
      manager/modeler
        but one question:
        cheers
        'Used' Materials are not 'purged'...
        Erase all unwanted Component Instances OR go to the Component Browser and find the unwanted component, right-click its icon and pick 'Delete' - this removes it from the model/browser/data-base.
        OR if there are no Instances left use Component Browser > Purge... pop-out to remove any unused Components
        It's recommended that you also use Layer Browser > Purge... pop-out to remove any unused Layers [that might have been associated with Components that you have just purged]
        NOW use Material Browser > Purge... pop-out to remove any unused Materials [that might have been associated with Components that you have just purged]
        OR simply use Model Info > Statistics > Purge Unused... to purge them all in one go - this also includes a purge of unused Styles.
        OR try my 'Purge' script which is similar but it lets you choose which kinds of thing to purge, and makes a 'report' of what's gone too...
          Staatsfeind
          hell you react fast ! ;D
          thx for your answer, will give it a try.
          manager/modeler
          • brodieB Offline
            brodie
            Great plugin, thanks TIG. Not one I'll likely use very often but I just had need of it and it worked perfectly.
            -Brodie
              DavidXJ98
              Thank you for this plugin... it's quite useful.
                MartinK
                Thanks TIG, I've got just the project for this.
                • bagateloB Offline
                  bagatelo
                  I set keyboard shortcuts for all the plugins I use.
                  Since this script takes a long time to complete their tasks in some files, I get confused sometimes I use the shortcuts, and inadvertently I press the shortcut for this plugin. You could insert an option to be given a warning to accept or not if we want to do cleaning?
                  Another interesting option is the possibility of inserting a percentage level where materials are not identical, but similar would be united into one.
                  It's possible to rename all the materials in words capitalized?
                  If we could make a clean sweep in the names would also help.
                  Why? Try it:
                  http://www.den4b.com/?x=products&product=renamer
                    First things last... 😉
                    You cannot 'rename' materials via the Ruby API unless you have Sketchup >= v8M1 [OR my SKMtools installed] because material.name=string doesn't exist as a method otherwise. If the method is available then this one-liner will rename ALL materials in the model using CAPITAL letters - otherwise you'll get an error message!
                    Sketchup.active_model.materials.each{|m|m.name=m.name.upcase}
                    The accuracy idea would apply to what exactly ? I expect Red, Green, Blue, Alpha ❓
                    At the moment the code has several tests of equivalence like
                    next if mat.color.red != m0.color.red
                    You can edit the code [using a plain text editor like Notepad/Notepad++ etc] to apply an accuracy thus, where you'll define the accuracy as say per=0.01 [i.e. we'll accept it as a match if it's within 1%]. You can either hardcode the 'per' or you could get this from an added dialog as the tool runs... [see below]
                    So now tweak the test[s]
                    next if mat.color.red > m0.color.red*(1+per) or mat.color.red < m0.color.red*(1-per)
                    Repeat this for RGB and A...
                    To get the accuracy from a dialog add this at the start of the code on a new line immediately after ' initialize()'
                    results=inputbox(["0.NNN; "],[0.01],"Material Consolidator Accuracy")
                    return nil unless results
                    per=results[0]
                    you then enter the required accuracy in the format 0.01 =1%, 0.1 =10%, 0.5 =50% etc.
                    Obviously if you use the dialog to set the accuracy you do not need a line that says per=... elsewhere in the code!
                    If you cancel the dialog the material-consolidation is aborted.
                    This accuracy dialog could act as your startup prompt... BUT if you don't implement it then add this line at the start of the code instead
                    return nil if UI.messagebox("Consolidate All Materials ?",MB_YESNO,"")==7
                    • irwanwrI Offline
                      irwanwr
                      thank you for the plugin 😄
                        Gabbiano
                        Really a great plugin!
                        Thank you TIG!
                        • H Offline
                          hegemonicoMX
                          Came down in the best moment. I had a horrible mess in the materials of a collaborative model. 😉 its a blessing
                          • E Offline
                            Ecuadorian
                            Hey, TIG. How about adding some "fuzzy" logic to this? I mean, sometimes you have very similar materials that have only slightly different properties. For example, half a dozen of glasses with only slightly different tints, or slightly different alpha values, and it would be useful to consolidate them.
                            -Miguel Lescano
                            • JClementsJ Offline
                              JClements
                              A mighty handy plugin. Thanks!
                                bsfranza
                                is there somebody out there who can compile the above mentioned "accuracy" code addon into the plugin and share it with us 😄?
                                would be awesome!!
                                thanks
                                  Here's v2.0 which includes optional 'tolerances' for RGBA values.
                                  So you can now consolidate colors which are almost a match !
                                  Use it with thought...
                                  But it is one-step undo-able !
                                  https://sketchucation.com/pluginstore?pln=materialconsolidator
                                  Please read the updated usage notes in the first post: http://sketchucation.com/forums/viewtopic.php?p=295290#p295290
                                    db11
                                    Thanks TIG. This will be a very useful addition to an often-used plugin.
                                    • pbacotP Offline
                                      Thank you!
                                        Sorry, for any inconvenience !
                                        Here's v3.0
                                        It tweaks any options checking - to avoid unexpected results !
                                          bsfranza
                                          WOW super many muchas gracias 😄
                                          heavily appreciated!
                                          edit:
                                          of course one is never satisfied for long ...
                                          plugin works as expected now, but its kind of slow on scenes with many many polygons and the report does not state the progress or if the plugin is still working or if the app is frozen and also there are some crucial options missing...
                                          for example: work in only on entities in active context or vice versa, ignore entities and materials of active objects
                                          dont know if anyone is aware of the age old plugin material maintance - this one is quite fast with what it does ..
                                          maybe someone in the future can combine them and make a proper plugin, i personally would be happy to pay for something like that 😄
                                          • 1 Offline
                                            1010 Gunner
                                            Need help with installation or use of this plugin.
                                            'materialconsolidator' shows in my extension manager although there is no version, author etc information.
                                            It is not showing in the 'extensions' tab
                                            What do I need to do to get it to work?
                                            • 2 / 3
