    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 45.7k Views 32 Watching
      rocorona
      @tig said:
      @gaieus said:
      @tig said:
      These are:-
      materialType
      color RGB
      transparency [alpha]
      What is a material "type"?
      I feel I'm missing something basilar, but I can't find this in the "modify material" window.
        @rocorona said:
        @tig said:
        @gaieus said:
        @tig said:
        These are:-
        materialType
        color RGB
        The materialType is accessible via the API - it returns values [0/1/2] depending on if the material is simply a 'plain-color', has a 'texture' or it has a texture and it has been 'colorized'... that's all... http://code.google.com/apis/sketchup/docs/ourdoc/material.html#materialType
          rocorona
          TIG, "thanks" for your reply, and "thanks" for your great and valuable work!
          • E Offline
            Ecuadorian
            I was thinking about this yesterday, as using FormFonts objects bloats my files with duplicate materials.
            Thanks, TIG! 👍
            -Miguel Lescano
              Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
              It is now wrapped into its own class 'MaterialConsolidator'.
              • H Offline
                headshot
                GR8 !!!
                TY.
                  Staatsfeind
                  thank you for this useful tool !
                  but one question:
                  how do i delete unused materials that result from objects imported by
                  the warehouse and which i dont use anymore?
                  to be more exactly, i tried out several warehouse objects to fit my needs
                  and mixed some of them. at the end i got 50+ textures loaded but maybe only
                  15 are in use. deleting all by hand would take some time.
                  did i get something wrong ?
                  cheers
                  http://www.frenchtouchstudio.com
                  manager/modeler
                    but one question:
                    cheers
                    'Used' Materials are not 'purged'...
                    Erase all unwanted Component Instances OR go to the Component Browser and find the unwanted component, right-click its icon and pick 'Delete' - this removes it from the model/browser/data-base.
                    OR if there are no Instances left use Component Browser > Purge... pop-out to remove any unused Components
                    It's recommended that you also use Layer Browser > Purge... pop-out to remove any unused Layers [that might have been associated with Components that you have just purged]
                    NOW use Material Browser > Purge... pop-out to remove any unused Materials [that might have been associated with Components that you have just purged]
                    OR simply use Model Info > Statistics > Purge Unused... to purge them all in one go - this also includes a purge of unused Styles.
                    OR try my 'Purge' script which is similar but it lets you choose which kinds of thing to purge, and makes a 'report' of what's gone too...
                      Staatsfeind
                      hell you react fast ! ;D
                      thx for your answer, will give it a try.
                      manager/modeler
                      • brodieB Offline
                        brodie
                        Great plugin, thanks TIG. Not one I'll likely use very often but I just had need of it and it worked perfectly.
                        -Brodie
                          DavidXJ98
                          Thank you for this plugin... it's quite useful.
                            MartinK
                            Thanks TIG, I've got just the project for this.
                            • bagateloB Offline
                              bagatelo
                              I set keyboard shortcuts for all the plugins I use.
                              Since this script takes a long time to complete their tasks in some files, I get confused sometimes I use the shortcuts, and inadvertently I press the shortcut for this plugin. You could insert an option to be given a warning to accept or not if we want to do cleaning?
                              Another interesting option is the possibility of inserting a percentage level where materials are not identical, but similar would be united into one.
                              It's possible to rename all the materials in words capitalized?
                              If we could make a clean sweep in the names would also help.
                              Why? Try it:
                              http://www.den4b.com/?x=products&product=renamer
                                First things last... 😉
                                You cannot 'rename' materials via the Ruby API unless you have Sketchup >= v8M1 [OR my SKMtools installed] because material.name=string doesn't exist as a method otherwise. If the method is available then this one-liner will rename ALL materials in the model using CAPITAL letters - otherwise you'll get an error message!
                                Sketchup.active_model.materials.each{|m|m.name=m.name.upcase}
                                The accuracy idea would apply to what exactly ? I expect Red, Green, Blue, Alpha ❓
                                At the moment the code has several tests of equivalence like
                                next if mat.color.red != m0.color.red
                                You can edit the code [using a plain text editor like Notepad/Notepad++ etc] to apply an accuracy thus, where you'll define the accuracy as say per=0.01 [i.e. we'll accept it as a match if it's within 1%]. You can either hardcode the 'per' or you could get this from an added dialog as the tool runs... [see below]
                                So now tweak the test[s]
                                next if mat.color.red > m0.color.red*(1+per) or mat.color.red < m0.color.red*(1-per)
                                Repeat this for RGB and A...
                                To get the accuracy from a dialog add this at the start of the code on a new line immediately after ' initialize()'
                                results=inputbox(["0.NNN; "],[0.01],"Material Consolidator Accuracy")
                                return nil unless results
                                per=results[0]
                                you then enter the required accuracy in the format 0.01 =1%, 0.1 =10%, 0.5 =50% etc.
                                Obviously if you use the dialog to set the accuracy you do not need a line that says per=... elsewhere in the code!
                                If you cancel the dialog the material-consolidation is aborted.
                                This accuracy dialog could act as your startup prompt... BUT if you don't implement it then add this line at the start of the code instead
                                return nil if UI.messagebox("Consolidate All Materials ?",MB_YESNO,"")==7
                                • irwanwrI Offline
                                  irwanwr
                                  thank you for the plugin 😄
                                    Gabbiano
                                    Really a great plugin!
                                    Thank you TIG!
                                    • H Offline
                                      hegemonicoMX
                                      Came down in the best moment. I had a horrible mess in the materials of a collaborative model. 😉 its a blessing
                                      • E Offline
                                        Ecuadorian
                                        Hey, TIG. How about adding some "fuzzy" logic to this? I mean, sometimes you have very similar materials that have only slightly different properties. For example, half a dozen of glasses with only slightly different tints, or slightly different alpha values, and it would be useful to consolidate them.
                                        -Miguel Lescano
                                        • JClementsJ Offline
                                          JClements
                                          A mighty handy plugin. Thanks!
                                            bsfranza
                                            is there somebody out there who can compile the above mentioned "accuracy" code addon into the plugin and share it with us 😄?
                                            would be awesome!!
                                            thanks
                                            • 2 / 3
