    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 44.2k Views 32 Watching
      DavidXJ98
      Thank you for this plugin... it's quite useful.
        MartinK
        Thanks TIG, I've got just the project for this.
        • bagateloB Offline
          bagatelo
          I set keyboard shortcuts for all the plugins I use.
          Since this script takes a long time to complete their tasks in some files, I get confused sometimes I use the shortcuts, and inadvertently I press the shortcut for this plugin. You could insert an option to be given a warning to accept or not if we want to do cleaning?
          Another interesting option is the possibility of inserting a percentage level where materials are not identical, but similar would be united into one.
          It's possible to rename all the materials in words capitalized?
          If we could make a clean sweep in the names would also help.
          Why? Try it:
          http://www.den4b.com/?x=products&product=renamer
            First things last... 😉
            You cannot 'rename' materials via the Ruby API unless you have Sketchup >= v8M1 [OR my SKMtools installed] because material.name=string doesn't exist as a method otherwise. If the method is available then this one-liner will rename ALL materials in the model using CAPITAL letters - otherwise you'll get an error message!
            Sketchup.active_model.materials.each{|m|m.name=m.name.upcase}
            The accuracy idea would apply to what exactly ? I expect Red, Green, Blue, Alpha ❓
            At the moment the code has several tests of equivalence like
            next if mat.color.red != m0.color.red
            You can edit the code [using a plain text editor like Notepad/Notepad++ etc] to apply an accuracy thus, where you'll define the accuracy as say per=0.01 [i.e. we'll accept it as a match if it's within 1%]. You can either hardcode the 'per' or you could get this from an added dialog as the tool runs... [see below]
            So now tweak the test[s]
            next if mat.color.red > m0.color.red*(1+per) or mat.color.red < m0.color.red*(1-per)
            Repeat this for RGB and A...
            To get the accuracy from a dialog add this at the start of the code on a new line immediately after ' initialize()'
            results=inputbox(["0.NNN; "],[0.01],"Material Consolidator Accuracy")
            return nil unless results
            per=results[0]
            you then enter the required accuracy in the format 0.01 =1%, 0.1 =10%, 0.5 =50% etc.
            Obviously if you use the dialog to set the accuracy you do not need a line that says per=... elsewhere in the code!
            If you cancel the dialog the material-consolidation is aborted.
            This accuracy dialog could act as your startup prompt... BUT if you don't implement it then add this line at the start of the code instead
            return nil if UI.messagebox("Consolidate All Materials ?",MB_YESNO,"")==7
            • irwanwrI Offline
              irwanwr
              thank you for the plugin 😄
                Gabbiano
                Really a great plugin!
                Thank you TIG!
                • H Offline
                  hegemonicoMX
                  Came down in the best moment. I had a horrible mess in the materials of a collaborative model. 😉 its a blessing
                  • E Offline
                    Ecuadorian
                    Hey, TIG. How about adding some "fuzzy" logic to this? I mean, sometimes you have very similar materials that have only slightly different properties. For example, half a dozen of glasses with only slightly different tints, or slightly different alpha values, and it would be useful to consolidate them.
                    -Miguel Lescano
                    • JClementsJ Offline
                      JClements
                      A mighty handy plugin. Thanks!
                        bsfranza
                        is there somebody out there who can compile the above mentioned "accuracy" code addon into the plugin and share it with us 😄?
                        would be awesome!!
                        thanks
                          Here's v2.0 which includes optional 'tolerances' for RGBA values.
                          So you can now consolidate colors which are almost a match !
                          Use it with thought...
                          But it is one-step undo-able !
                          https://sketchucation.com/pluginstore?pln=materialconsolidator
                          Please read the updated usage notes in the first post: http://sketchucation.com/forums/viewtopic.php?p=295290#p295290
                            db11
                            Thanks TIG. This will be a very useful addition to an often-used plugin.
                            • pbacotP Offline
                              Thank you!
                                Sorry, for any inconvenience !
                                Here's v3.0
                                It tweaks any options checking - to avoid unexpected results !
                                  bsfranza
                                  WOW super many muchas gracias 😄
                                  heavily appreciated!
                                  edit:
                                  of course one is never satisfied for long ...
                                  plugin works as expected now, but its kind of slow on scenes with many many polygons and the report does not state the progress or if the plugin is still working or if the app is frozen and also there are some crucial options missing...
                                  for example: work in only on entities in active context or vice versa, ignore entities and materials of active objects
                                  dont know if anyone is aware of the age old plugin material maintance - this one is quite fast with what it does ..
                                  maybe someone in the future can combine them and make a proper plugin, i personally would be happy to pay for something like that 😄
                                  • 1 Offline
                                    1010 Gunner
                                    Need help with installation or use of this plugin.
                                    'materialconsolidator' shows in my extension manager although there is no version, author etc information.
                                    It is not showing in the 'extensions' tab
                                    What do I need to do to get it to work?
                                      First thing I'd do is look in the Tools Menu where the instructions say it will be located. See the first post.
                                      If it's not there, then we need to look at how you went about installing it.
                                      What version of SketchUp are you using? Your profile indicates version 7 but it had no Extension Manager.
                                      • 1 Offline
                                        1010 Gunner
                                        That's it, thank you.
                                          SirFievel33
                                          Hey TIG, so I'm running your program on my 150MB file with many materials (~150) and components. It seems to 'freeze' on the "Making Nested Entities List." step. Takes up a lot of CPU processing power but not seeing any progress. I'm leaving it 'running' for a few hours to give it a chance to finish. If it's not frozen and working as intended, could I suggest making some form of a progress bar or status updates, maybe even a pause option. If it's not working as intended, well, consider yourself informed. 😕
                                            SirFievel33
                                            Returned to these error messages within Ruby Console (I'm using Sketchup Pro 2019)
                                            Material Consolidator: Tolerances: R=15 G=15 B=15 A=0
                                            Material Consolidator: Making Material Lists
                                            Material Consolidator: Making Entities List
                                            Material Consolidator: Making Nested Entities List
                                            Material Consolidator: Consolidating Materials
                                            Error: #<NoMethodError: undefined method display_name' for nil:NilClass> C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:202:in block (3 levels) in new'
                                            C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:195:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:195:in block (2 levels) in new'
                                            C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:191:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:191:in block in new'
                                            C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:189:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:189:in new'
                                            C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:71:in `block in module:MaterialConsolidator'
                                            • 2 / 3
