    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 45.7k Views 32 Watching
      d12dozr
      Sweet! Thanks, TIG!
      @solo said:
      Another awesome and needed tool, any possibility to have it available in the 'tools' drop down menu? as typing into ruby consol everytime will require me to remember the command and I have already forgotten it.
      +1
      http://goo.gl/f7ooYh
        Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
        It now has 'Material Consolidator' under the 'Tools' menu...
        • Bob JamesB Offline
          Bob James
          Oh, YES!!
          Thank you, TIG
            rv1974
            Hi TIG!
            I have some important suggestion. The majority of people working in the 3D field use some prefixes in the mats\layers\camera names. It's extremely helpful to differ my stuff from the others.I for example name all my assets in this way: zzz_blahblah. And everything is inserted in the initial template file.
            So what I'm asking for is ability to set the default nameprioty directly in the ruby file
            itself (just to set up it once and forget). In my case zzz_* formula would be dominant.
            What do you think?
              rv1974
              At the moment the first material in the database is used in preference to any other matches [the names are not considered just the position in the list], so if you have 'zzz_Material', 'zzz_Material1' and 'xxx_Material99' that are all exact matching 'clones' and 'zzz_Material' is the first one then everything becomes 'zzz_Material' and the others are purged...
              I can't see how we would use 'prefixes' to sort materials [at the moment, as I said, the name is ignored and its 'order of being created' is used] 😕
                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                The listing and sorting algorithms have been optimized for speed and command-line/console progress messages added...
                  rv1974
                  @tig said:
                  rv1974
                  order of being created is already a nice thing. The workaround is to embed a simple planes matrix with user common used materials applied into initial template.
                  Thank you.
                    rocorona
                    @tig said:
                    @gaieus said:
                    @tig said:
                    These are:-
                    materialType
                    color RGB
                    transparency [alpha]
                    What is a material "type"?
                    I feel I'm missing something basilar, but I can't find this in the "modify material" window.
                      @rocorona said:
                      @tig said:
                      @gaieus said:
                      @tig said:
                      These are:-
                      materialType
                      color RGB
                      The materialType is accessible via the API - it returns values [0/1/2] depending on if the material is simply a 'plain-color', has a 'texture' or it has a texture and it has been 'colorized'... that's all... http://code.google.com/apis/sketchup/docs/ourdoc/material.html#materialType
                        rocorona
                        TIG, "thanks" for your reply, and "thanks" for your great and valuable work!
                        • E Offline
                          Ecuadorian
                          I was thinking about this yesterday, as using FormFonts objects bloats my files with duplicate materials.
                          Thanks, TIG! 👍
                          -Miguel Lescano
                            Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                            It is now wrapped into its own class 'MaterialConsolidator'.
                            • H Offline
                              headshot
                              GR8 !!!
                              TY.
                                Staatsfeind
                                thank you for this useful tool !
                                but one question:
                                how do i delete unused materials that result from objects imported by
                                the warehouse and which i dont use anymore?
                                to be more exactly, i tried out several warehouse objects to fit my needs
                                and mixed some of them. at the end i got 50+ textures loaded but maybe only
                                15 are in use. deleting all by hand would take some time.
                                did i get something wrong ?
                                cheers
                                http://www.frenchtouchstudio.com
                                manager/modeler
                                  but one question:
                                  cheers
                                  'Used' Materials are not 'purged'...
                                  Erase all unwanted Component Instances OR go to the Component Browser and find the unwanted component, right-click its icon and pick 'Delete' - this removes it from the model/browser/data-base.
                                  OR if there are no Instances left use Component Browser > Purge... pop-out to remove any unused Components
                                  It's recommended that you also use Layer Browser > Purge... pop-out to remove any unused Layers [that might have been associated with Components that you have just purged]
                                  NOW use Material Browser > Purge... pop-out to remove any unused Materials [that might have been associated with Components that you have just purged]
                                  OR simply use Model Info > Statistics > Purge Unused... to purge them all in one go - this also includes a purge of unused Styles.
                                  OR try my 'Purge' script which is similar but it lets you choose which kinds of thing to purge, and makes a 'report' of what's gone too...
                                    Staatsfeind
                                    hell you react fast ! ;D
                                    thx for your answer, will give it a try.
                                    manager/modeler
                                    • brodieB Offline
                                      brodie
                                      Great plugin, thanks TIG. Not one I'll likely use very often but I just had need of it and it worked perfectly.
                                      -Brodie
                                        DavidXJ98
                                        Thank you for this plugin... it's quite useful.
                                          MartinK
                                          Thanks TIG, I've got just the project for this.
                                          • bagateloB Offline
                                            bagatelo
                                            I set keyboard shortcuts for all the plugins I use.
                                            Since this script takes a long time to complete their tasks in some files, I get confused sometimes I use the shortcuts, and inadvertently I press the shortcut for this plugin. You could insert an option to be given a warning to accept or not if we want to do cleaning?
                                            Another interesting option is the possibility of inserting a percentage level where materials are not identical, but similar would be united into one.
                                            It's possible to rename all the materials in words capitalized?
                                            If we could make a clean sweep in the names would also help.
                                            Why? Try it:
                                            http://www.den4b.com/?x=products&product=renamer
                                            • 2 / 3
