[Plugin Library] LibFredo6 - v14.5b - 24 May 24
@bob james said:
ALL of your plugins are freshly installed using SketchUcation Plugin Store
But then, do you still have problems?
NEW RELEASE: LibFredo6 v6.5a - 30 Dec 14
LibFredo6 6.5a is a release mainly for TopoShaper 2.0 (Terrain from Cloud of Points). It also fixes a few bugs, in particular for exotic setup with non-ascii usernames and Linux configuration.
See main post of this thread for Download of LibFredo6.
NEW RELEASE: LibFredo6 v6.6a - 10 Jan 15
LibFredo6 6.6a is a release mainly for FredoTools::ElementStats 1.0 (Interactive Statistics on Model and Entities). It also fixes a few bugs.
Spanish Language LibFredo6 v6.6a
NEW RELEASE: LibFredo6 v6.6b - 18 Jan 15
LibFredo6 6.6b is a small update of the v6.6a release mainly for FredoTools::ElementStats 1.0 (Interactive Statistics on Model and Entities). It fixes a few bugs and some adjustments. Il also includes an update to the Spanish translation by Oxer.
Thank
Dear Fredo Curviloft not working in 2015 SU. Please help us
In Fredo's absence... Have you installed the latest version from RBZ from the PluginStore ?
http://sketchucation.com/pluginstore?pln=CurviloftHave you also installed the latest version of the LibFredo ?
http://sketchucation.com/pluginstore?pln=LibFredo6Have you then restarted SketchUp to effect the updates ?
If so how is it 'not working' ?
e.g.
Not loading ?
Not functioning as expected ?
Error messages ?
etc...Help us to help you...
You are Super,
Plugin Working...
Thank you Very Very much for your attention and interest..
Hy
I install LibFredo 6.6b (SU2015) but not show the toolbar. I set the "Prefered language" EN. On SU toolbars panel not appear Fredo6 toolbar, but install other plugin that immediately appear on toolbar.Please help.
Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
Anyone?
Have you installed the very latest version of SketchUp v2015 ?
It did previously have some issues with the MAC update to 'Yosemite'...Try disabling the
jbb_layers_panel
plugin.
After a restart any improvement ?
It has observers etc and has been linked to some issues with MACs...My
Mirror
plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate. -
TIG,
Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
Thank you so much.... -
Oops.... A bit premature.... It still crashes.....
Installing the newest sketch up version did the trick.... (again: So far...)
Anyone?
Did you submit the BugSplats?
If you did - did you enter any details in the report? Description, name or email I can use to look up the crash? -
NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
