    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 585 Posters 9.8m Views 587 Watching
      @bob james said:
      @fredo6 said:
      Bob,
      Why don't you simply remove all my plugins files and folders, and then reinstall from the Plugin Store, checking at each step that this is OK.
      ALL of your plugins are freshly installed using SketchUcation Plugin Store
      @Bob
      OK, try my suggestion first to tidy up, and then to have only Fredo's stuff loading [Plugins Manager] - if there's no issue something else is to blame and we are a step nearer catching the little varmint[s]...
      You do have far more than the average number of Plugins loading, so it is quite possible something is producing weird results, so it's possible that Fredo's latest Lib is the collateral damage, and quite 'innocent'......
      • Bob JamesB
        Bob James
        @tig said:
        Nil desperandum !
        πŸ˜†
        @tig said:
        The first thing I see that's not right is that you have a copy of the 'Fredo6_!LibFredo6' folder INSIDE the 'Fredo6_Curviloft' folder.
        It is not needed, it's not as shipped and should be removed.
        Although I can't see how that might be affecting things !
        The only 'Fredo6_!LibFredo6' folder should be in the Plugins folder.
        After the removal of the wrong copy can you restart to see if anything is better... πŸ˜• .
        I noticed that and removed it, It had no effect.
        I removed all Fredo plugins and did a fresh install using SketchUcation Plugin Store so what's there came from those installations.
          Please re-read my post...
          I suggested that you Disable 'everything that is not "Fredo"' - temporarily, using the Plugins Managers Sets to make it easy...
          And restarted SketchUp to see if the error remains.
          Disabling the Fredo stuff might prevent that error appearing - but something that still loads might still then cause the error when the Lib is re-enabled - so we are not a step forward...
          IF you still get the Fredo Lib errors with only the Fredo stuff loading then it is to blame...
          BUT if not something else which you currently have Disabled is actually the culprit...
          Since you have nothing odd about your windows-user-name or your Windows setup, you should not have these errors, IF all of your installed plugins are compatible with 'UTF-8...'
          Please try my steps to see what is the culprit - I think it's NOT Fredo's Lib, but something that is interacting with it unexpectedly...
          I wait to be proved wrong πŸ˜’
          • Bob JamesB
            Bob James
            I did those things before you sent that message πŸ˜„
            I'm working on your suggestions now.
            • Bob JamesB
              Bob James
              :heart_eyes:
              I'm happy to announce to TIG and Fredo that all is well ❗
              I deleted:
              • LibTraductor.rb
                JPP_Dir_20
                ROUNDCORNER_Dir_23
                TOPOSHAPER_Dir_10
                TOS_Dir_18
                cd_power_extension_m.rb
                cd_power_m.rb
                cd_power_n.rb
                Although I don't know which one was the bad guy because I deleted all of them at once. I didn't use SketchUcation Plugins Manager because I've never used it before and didn't want to mess things up by doing it incorrectly.
              'BZ_Dir_17' is Bezierspline
              'DOCUMENTATION_Dir' is empty
              I'm sure you both are relieved as much as I that this is resolved.
              Thank you both for your extra effort and patience. πŸ‘
              • fredo6F
                But then, do you still have problems?
                • Bob JamesB
                  Bob James
                  See previous joyful post πŸ˜„
                  • fredo6F
                    NEW RELEASE: LibFredo6 v6.5a - 30 Dec 14
                    LibFredo6 6.5a is a release mainly for TopoShaper 2.0 (Terrain from Cloud of Points). It also fixes a few bugs, in particular for exotic setup with non-ascii usernames and Linux configuration.
                    See main post of this thread for Download of LibFredo6.
                    • fredo6F
                      NEW RELEASE: LibFredo6 v6.6a - 10 Jan 15
                      LibFredo6 6.6a is a release mainly for FredoTools::ElementStats 1.0 (Interactive Statistics on Model and Entities). It also fixes a few bugs.
                      • OxerO
                        Oxer
                        Spanish Language LibFredo6 v6.6a
                        LibFredo6_ES.lang.zip
                        • fredo6F
                          NEW RELEASE: LibFredo6 v6.6b - 18 Jan 15
                          LibFredo6 6.6b is a small update of the v6.6a release mainly for FredoTools::ElementStats 1.0 (Interactive Statistics on Model and Entities). It fixes a few bugs and some adjustments. Il also includes an update to the Spanish translation by Oxer.
                          • L
                            Lokal
                            Thank
                            • C
                              cemileca
                              Dear Fredo Curviloft not working in 2015 SU. Please help us
                                In Fredo's absence... Have you installed the latest version from RBZ from the PluginStore ?
                                http://sketchucation.com/pluginstore?pln=Curviloft
                                Have you also installed the latest version of the LibFredo ?
                                http://sketchucation.com/pluginstore?pln=LibFredo6
                                Have you then restarted SketchUp to effect the updates ?
                                If so how is it 'not working' ?
                                e.g.
                                Not loading ?
                                Not functioning as expected ?
                                Error messages ?
                                etc...
                                Help us to help you...
                                • C
                                  cemileca
                                  You are Super,
                                  Plugin Working...
                                  Thank you Very Very much for your attention and interest..
                                    SRoland
                                    Hy
                                    I install LibFredo 6.6b (SU2015) but not show the toolbar. I set the "Prefered language" EN. On SU toolbars panel not appear Fredo6 toolbar, but install other plugin that immediately appear on toolbar.
                                    Please help.
                                    • emnE
                                      emn
                                      Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
                                      Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
                                      Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
                                      Anyone?
                                        Have you installed the very latest version of SketchUp v2015 ?
                                        It did previously have some issues with the MAC update to 'Yosemite'...
                                        Try disabling the jbb_layers_panel plugin.
                                        After a restart any improvement ?
                                        It has observers etc and has been linked to some issues with MACs...
                                        My Mirror plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate.
                                        • emnE
                                          emn
                                          TIG,
                                          Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
                                          Thank you so much....
                                          • emnE
                                            emn
                                            Oops.... A bit premature.... It still crashes.....
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 113
                                            • 114
                                            • 47 / 114
