    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 13.0k Views 19 Watching
      [sw:33r5rvua]OodUcDzqTrbYE8v[/sw:33r5rvua]
        @jeff hammond said:
        (like- i don't think you could do it even if you tried really hard.. not on osx at least)
        is that a challenge?
        what could happen is that you use your own phone to make a cube map. upload it and then use it.
        • jeff hammondJ Offline
          haha.. no
          i have approximately zero need to see my mug plastered on one of my models.
            Well when this goes public people will be able to pick your mug as a reflection...
              great.. let me get a haircut first.
              • Phillip HP Offline
                Phillip H
                Rich, again, this is very impressive work. Kudos. This is a regular stop for me now. I can't wait to see how this develops.
                HP EliteBook 8440p Intel® Dual Core™ i7 M620@ 2.67 4GB RAM
                NVIDIA NVS 3100, 512 MB
                Windows® 8.1 64 bit
                SketchUp Pro 2015 version 15.3.331 64-bit
                • ntxdaveN Offline
                  ntxdave
                  I am suddenly getting nothing at all when I click on one of the models!!
                  Is the new 3D icon in the lower right corner supposed to do something different.
                  I am running Win 8.1 with IE 11. I will also try the pages on Chrome and see what happens there.
                  Press F1...thank me later
                  • ntxdaveN Offline
                    ntxdave
                    Worked fine in Chrome 39.....now I need to figure out what is happening in IE.
                    I have been excited because so far, the SketchUcation 3D Viewer has worked in IE when others did not....
                      Gábor
                      As the viewer at the moment is under continuous development and bug-fixing it might happen that it behaves strange or completely stops for short periods of time. If that lasts longer than an hour try to cache erase-reload (Ctrl-F5) to get the latest script.
                      • ntxdaveN Offline
                        ntxdave
                        OK - Got it working again...
                        I tried the Ctrl-F5 but did not see any difference. Then I deleted all of the temp files and now it is working again 😍
                        However, am I seeing things or did something change. A little while ago, I thought I saw a text box at the bottom of the viewport but now I am not seeing it. Is that something you are working on?
                        We have a convention coming up at the end of next month and this view would be so neat to have (I know that is unrealistic but it might give you an idea of my state of mind related to this viewer).
                        I think you guys are doing a great job 👍 👍 👍 👍 👍
                          Gábor
                          As I said: Under development. Hopefully will see some more new features and less bugs in the upcoming days. 😄 ( Current new feature: Displaying actual scene names in the right bottom corner if the model has scenes.)
                          EDIT: So if you have the latest script you should be able to see the scene names e.g. at Rich's latest model.
                          • ntxdaveN Offline
                            ntxdave
                            Thanks for the update....Looks like I better start using better scene names ☀
                            Just out of curiosity, once all of the scene stuff is working properly, are you looking at the ability to play/auto play scenes?
                            This gets more exciting every day.....
                              @dave
                              Camera animations are rudimentary with no real control over direction and speed.
                              If we do add a camera animation function it will likely be controlled via curves and handles. Where curves dictate the path and the handles dictate the interpolation type.
                              [sw:hd3njr2t]WRmF4s46i3p9zg7[/sw:hd3njr2t]
                                [sw:1xtujlnx]mOxMBxrqNM1ENwT[/sw:1xtujlnx]
                                  ...knees and toes.
                                    @Dave
                                    Haha... it was element of larger file.
                                    [sw:3etbgswg]epepwLuT50CHuQX[/sw:3etbgswg]
                                      It's all really cool stuff.
                                      • ntxdaveN Offline
                                        ntxdave
                                        This is looking better every day
                                          [sw:3s28li8q]zNb1LfYAi7PC0mm[/sw:3s28li8q]
                                            "D'OH!" 😆
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
