    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 817.7k Views 121 Watching
    • guanjinG Offline
      guanjin
      @fredo6 said:
      NEW RELEASE: FredoTools v2.2a - 19 Oct 14
      FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014
      When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。
      • fredo6F Offline
        guanjin,
        Can you open the Ruby console and see if there are errors displayed.
        Do you get this problem with the English version or the Chinese version
        • guanjinG Offline
          guanjin
          @fredo6 said:
          guanjin,
          Without prompting any errors.
          There are Chinese characters display dislocation, English normal
          This problem has continued for several versions of this
          Earlier versions without problems
          Thank you fredo6
          guanjin
          • fredo6F Offline
            @guanjin
            I can have a look.
            But could you send me the FredoTools_ZH.lang file that you use. Currently, I don't have one updated for EdgeInspector.
            • fredo6F Offline
              @guanjin,
              If you wish to make a test, could you replace the following attached files in the Fredo6_!LibFredo6 subfolder
              body_Lib6G6.rbbody_Lib6Palette.rb
              This should normally take into account the natural width of Chinese characters
              Thanks for your feedback
                thevzitor
                Hello to all,
                I don't know where to post this problem but as it is related to downloading FredoTools, I post it here.
                It's probably a SketchUcation script problem, I cannot download the extension. Same problem with others extensions.
                Clicking the download link gives me a blank window and nothing happens. (screenshot enclosed)
                Is there any other place where to download it?
                Otherwise I installed LibFredo through the Extension warehouse in SU, restarted SU and still got the same old library... A bit annoying.
                Otherwise a big thank to Fredo for his extensions !
                All the best
                  That 'Download' is just an image to show the relevant text below it, that's why it opens as an image.
                  It is NOT a link.
                  Most Plugins are available from the SketchUcation PluginStore.
                  The FredoTools is here: http://sketchucation.com/pluginstore?pln=FredoTools
                  Clicking that red 'Download' button gets you the RBZ archive.
                  You can then use the Preferences > Extensions > Install... button to auto-install it into your Plugins folder.
                  If you get/install the SketchUcation Toolset currently v2.6.1 [install it from its RBZ, downloadable from the Resources menu http://sketchucation.com/resources/plugin-store-download ] you'll then get a PLugins > SketchUcation submenu and SketchUcation toolbar, all within SketchUp itself.
                  This toolset has many useful items - the relevant one in this case is the PluginStore dialog.
                  Its dialog interface is similar to the SketchUcation PluginStore, but in this case the 'Download' button is replaced with a red 'AutoInstall' button.
                  So simply find the required Plugins and click its AutoInstall button.
                  It is automatically downloaded and installed for you in one step.
                  There are other tabbed options to Update and make Bundles to use across SUp-versions or different computers etc... Save those till you get proficient in AutoInstalling... 😉
                  Why make life more complex than it needs to be ?
                  • micioneM Offline
                    micione
                    Fredo,
                    The tool does not seem to appear.
                    Windows 7 - SU2015
                      @micione said:
                      Fredo,
                      Windows 7 - SU2015
                      Did you also install the updated LIB and then restart SketchUp ?
                      • fredo6F Offline
                        NEW RELEASE: FredoTools v2.4a - 17 Nov 14
                        FredoTools 2.4a is a release for AngleInspector v1.0, which is a small tool to measure angles anywhere in the model in one click.
                        Note: it requires to install LibFredo6 v6.4a
                        • micioneM Offline
                          micione
                          Tig,
                          yes I installed the new library, restarted Sketchup,
                          but the tool does not appear.
                          This happens in SU2014 and SU2105.
                          • fredo6F Offline
                            @micione,
                            Could you open the Trace Log file (in Windows > LibFredo6 Settings...) and check if FredoTools was loaded (or export as txt and send it to me).
                            • micioneM Offline
                              micione
                              Ok Fredo,
                              mail sent .
                              • F Offline
                                fantoosh420
                                I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
                                Sketchup 14.0.4900
                                Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
                                • micioneM Offline
                                  micione
                                  Problem solved.
                                  (today re-downloaded and installed).
                                  Works wonders.
                                  thanks
                                  • OxerO Offline
                                    Oxer
                                    New Spanish Language file v2.4a
                                    Spanish Language File
                                    • fredo6F Offline
                                      Oxer,
                                      Thanks very much. This will go in next update
                                        mcjoiner
                                        Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
                                        When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
                                        I'm currently using sketchup pro 8.
                                        Suggestions?
                                        • fredo6F Offline
                                          It is probably related to the style for displaying Edges.
                                          To see the colors you need to set up the style by material in your model
                                          • fredo6F Offline
                                            NEW RELEASE: FredoTools v2.5a - 10 Jan 15
                                            FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
                                            [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
                                            Note: it requires to install LibFredo6 v6.6a
                                            • 11
                                            • 12
                                            • 23
                                            • 24
                                            • 10 / 24
