    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 836.5k Views 121 Watching
    • P
      pipinek
      Greetings,
      I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page.
      When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one.
      Any helpful suggestion will be deeply appreciated.
      • fredo6F
        @pipinek said:
        Greetings,
        Go to the Default Parameters dialog (or click on yellow wrench) and enable the icons you wish. You can also read the main post.
        • fredo6F
          NEW RELEASE: FredoTools v2.1a - 12 Oct 14
          FredoTools 2.1a is a release for:
          EdgeInspector v1.2: more accurate and relevant detection of fixing for Tiny Edges, Lost Junctions and Tiny Gaps
          DrawAlong 1.2 v1.2: fixes for inferences on construction points and drawing construction points (avoid doubling)
          • guanjinG
            guanjin
            Show incomplete, occasionally show
            • fredo6F
              NEW RELEASE: FredoTools v2.2a - 19 Oct 14
              FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014
              • guanjinG
                guanjin
                When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。
                • fredo6F
                  guanjin,
                  Can you open the Ruby console and see if there are errors displayed.
                  Do you get this problem with the English version or the Chinese version
                  • guanjinG
                    guanjin
                    @fredo6 said:
                    guanjin,
                    Without prompting any errors.
                    There are Chinese characters display dislocation, English normal
                    This problem has continued for several versions of this
                    Earlier versions without problems
                    Thank you fredo6
                    guanjin
                    • fredo6F
                      @guanjin
                      I can have a look.
                      But could you send me the FredoTools_ZH.lang file that you use. Currently, I don't have one updated for EdgeInspector.
                      • fredo6F
                        @guanjin,
                        If you wish to make a test, could you replace the following attached files in the Fredo6_!LibFredo6 subfolder
                        body_Lib6G6.rbbody_Lib6Palette.rb
                        This should normally take into account the natural width of Chinese characters
                        Thanks for your feedback
                        • T
                          thevzitor
                          Hello to all,
                          I don't know where to post this problem but as it is related to downloading FredoTools, I post it here.
                          It's probably a SketchUcation script problem, I cannot download the extension. Same problem with others extensions.
                          Clicking the download link gives me a blank window and nothing happens. (screenshot enclosed)
                          Is there any other place where to download it?
                          Otherwise I installed LibFredo through the Extension warehouse in SU, restarted SU and still got the same old library... A bit annoying.
                          Otherwise a big thank to Fredo for his extensions !
                          All the best
                            That 'Download' is just an image to show the relevant text below it, that's why it opens as an image.
                            It is NOT a link.
                            Most Plugins are available from the SketchUcation PluginStore.
                            The FredoTools is here: http://sketchucation.com/pluginstore?pln=FredoTools
                            Clicking that red 'Download' button gets you the RBZ archive.
                            You can then use the Preferences > Extensions > Install... button to auto-install it into your Plugins folder.
                            If you get/install the SketchUcation Toolset currently v2.6.1 [install it from its RBZ, downloadable from the Resources menu http://sketchucation.com/resources/plugin-store-download ] you'll then get a PLugins > SketchUcation submenu and SketchUcation toolbar, all within SketchUp itself.
                            This toolset has many useful items - the relevant one in this case is the PluginStore dialog.
                            Its dialog interface is similar to the SketchUcation PluginStore, but in this case the 'Download' button is replaced with a red 'AutoInstall' button.
                            So simply find the required Plugins and click its AutoInstall button.
                            It is automatically downloaded and installed for you in one step.
                            There are other tabbed options to Update and make Bundles to use across SUp-versions or different computers etc... Save those till you get proficient in AutoInstalling... 😉
                            Why make life more complex than it needs to be ?
                            • micioneM
                              micione
                              Fredo,
                              The tool does not seem to appear.
                              Windows 7 - SU2015
                                @micione said:
                                Fredo,
                                Windows 7 - SU2015
                                Did you also install the updated LIB and then restart SketchUp ?
                                • fredo6F
                                  NEW RELEASE: FredoTools v2.4a - 17 Nov 14
                                  FredoTools 2.4a is a release for AngleInspector v1.0, which is a small tool to measure angles anywhere in the model in one click.
                                  Note: it requires to install LibFredo6 v6.4a
                                  • micioneM
                                    micione
                                    Tig,
                                    yes I installed the new library, restarted Sketchup,
                                    but the tool does not appear.
                                    This happens in SU2014 and SU2105.
                                    • fredo6F
                                      @micione,
                                      Could you open the Trace Log file (in Windows > LibFredo6 Settings...) and check if FredoTools was loaded (or export as txt and send it to me).
                                      • micioneM
                                        micione
                                        Ok Fredo,
                                        mail sent .
                                        • F
                                          fantoosh420
                                          I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
                                          Sketchup 14.0.4900
                                          Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
                                          • micioneM
                                            micione
                                            Problem solved.
                                            (today re-downloaded and installed).
                                            Works wonders.
                                            thanks
                                            • 11
                                            • 12
                                            • 23
                                            • 24
                                            • 10 / 24
