    HDRI problem Thea render
    extensions
    20 Posts 8 Posters 5.0k Views 8 Watching
    • FrederikF Offline
      Frederik
      @usen said:
      not in the same way as in sketchup shadow thea?
      You're mixing things up...
      Please remember that the hdri will also be a source of the illumination...
      Please take the advice Nigec have provided... πŸ˜‰
      Cheers
      Kim Frederik
      • N Offline
        notareal
        If you want silhouette shadows is Thea, using frontal projection is the way to do it. But if simple "attaching" a model on a HDRI is enough then using shadow catcher is must.
        • NigeCN Offline
          NigeC
          No you don't use a shadow catcher at all, it uses the actual geometry with a texture
          here's a SU version
          Su file
          you can also add bump, and reflections, but you need to use masks
          β€œIt’s only impossible if you stop and think about it!”
          • NigeCN Offline
            NigeC
            here's a quick guide
            frontal projection.pdf
            • massimoM Offline
              massimo Moderator
              Hi Nige and welcome. πŸ‘ πŸ˜„
              • NigeCN Offline
                NigeC
                Thanks massimo, I've been lurking for years so I thought it was a good time to say something! 🀣
                  rhed037
                  Frederik can you pls upload it again the scene with HDRI with the beetle car I want to learned it. tnx
                  • FrederikF Offline
                    Frederik
                    Sorry - but after almost two years, I don't have that scene any more... 😐
                    What exactly is it you want to learn...?
                    How to setup a scene in SU with a shadow catching material...?
                    Or...?!?
                    Cheers
                    Kim Frederik
                      rhed037
                      i have same problem of the hdri when i render the shadow is not visible to the scene can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                      • FrederikF Offline
                        Frederik
                        @rhed037 said:
                        ...can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                        Attached please find a very simple model with some spheres...
                        THe render was complete in 16 seconds using the BSD preset...
                        I've used the "Harbor 3" hdri from the HDRI Hub IBL package, which is free to download for registered users... πŸ˜‰
                        Hope this can help you further...?!?
                        Shadow-catch-test.skp
                        Cheers
                        Kim Frederik
