    HDRI problem Thea render
    extensions
    20 Posts 8 Posters 4.7k Views 8 Watching
    • FrederikF Offline
      Frederik
      @usen said:
      Thank you, but it's not like I want to shadow
      Can you elaborate...?
      How do you want it to be...?
      Based on the hdri you've used, I think the shadow looks as it should...
      Cheers
      Kim Frederik
      • usenU Offline
        usen
        I can not do the same thing this video, I'm not doing shadow
        http://b1303.hizliresim.com/17/d/l030q.jpg
        http://b1303.hizliresim.com/17/d/l0338.jpg
        http://www.sketchupturkiye.com/
        • FrederikF Offline
          Frederik
          I'm not sure that your hdri has the best quality... 😐
          I can only encourage you to try this scene, where you can take learnings from the material settings etc...
          (NB! please note the file-size is 83Mb, because it also contain a free hdri...)
          With the scene you should be able to get a render similar to this if you're using the latest Thea4SU plugin...
          Cheers
          Kim Frederik
          • usenU Offline
            usen
            Thank you very much for your concern, I'm trying. πŸ‘
            • NigeCN Offline
              NigeC
              Tomasz used frontal projection with his scene
              quick tut:
              Setup you scene with the car on a plan add the hdri,
              scale the plane so it reaches the horizon
              Hide everything and render the scene, save the image
              unhide everything
              add the previously rendered image to the plane
              open the thea dialog and double click on the image
              set the diffused slot projection to frontal
              close the mat lab
              do a test render, you'll find the background is slightly darker, set the background intensity to about 1.7, you may need to fiddle about a bit
              thats it πŸ˜„
              Here's the Thea version as a pack file, I don't have the SU file on this laptop
              pack file
              β€œIt’s only impossible if you stop and think about it!”
              • usenU Offline
                usen
                not in the same way as in sketchup shadow thea?
                http://c1303.hizliresim.com/17/f/l0jhg.jpg
                • FrederikF Offline
                  Frederik
                  You're mixing things up...
                  Please remember that the hdri will also be a source of the illumination...
                  Please take the advice Nigec have provided... πŸ˜‰
                  Cheers
                  Kim Frederik
                  • N Offline
                    notareal
                    If you want silhouette shadows is Thea, using frontal projection is the way to do it. But if simple "attaching" a model on a HDRI is enough then using shadow catcher is must.
                    • NigeCN Offline
                      NigeC
                      No you don't use a shadow catcher at all, it uses the actual geometry with a texture
                      here's a SU version
                      Su file
                      you can also add bump, and reflections, but you need to use masks
                      • NigeCN Offline
                        NigeC
                        here's a quick guide
                        frontal projection.pdf
                        • massimoM Offline
                          massimo Moderator
                          Hi Nige and welcome. πŸ‘ πŸ˜„
                          • NigeCN Offline
                            NigeC
                            Thanks massimo, I've been lurking for years so I thought it was a good time to say something! 🀣
                              rhed037
                              Frederik can you pls upload it again the scene with HDRI with the beetle car I want to learned it. tnx
                              • FrederikF Offline
                                Frederik
                                Sorry - but after almost two years, I don't have that scene any more... 😐
                                What exactly is it you want to learn...?
                                How to setup a scene in SU with a shadow catching material...?
                                Or...?!?
                                Cheers
                                Kim Frederik
                                  rhed037
                                  i have same problem of the hdri when i render the shadow is not visible to the scene can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                  • FrederikF Offline
                                    Frederik
                                    @rhed037 said:
                                    ...can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                    Attached please find a very simple model with some spheres...
                                    THe render was complete in 16 seconds using the BSD preset...
                                    I've used the "Harbor 3" hdri from the HDRI Hub IBL package, which is free to download for registered users... πŸ˜‰
                                    Hope this can help you further...?!?
                                    Shadow-catch-test.skp
                                    Cheers
                                    Kim Frederik
