    HDRI problem Thea render
    extensions
    20 Posts 8 Posters 5.0k Views 8 Watching
    • usenU Offline
      usen
      Thank you, but it's not like I want to shadow
      http://b1303.hizliresim.com/17/d/kzqsl.png
      http://www.sketchupturkiye.com/
      • FrederikF Offline
        Frederik
        Can you elaborate...?
        How do you want it to be...?
        Based on the hdri you've used, I think the shadow looks as it should...
        Cheers
        Kim Frederik
        • usenU Offline
          usen
          I can not do the same thing this video, I'm not doing shadow
          http://b1303.hizliresim.com/17/d/l030q.jpg
          http://b1303.hizliresim.com/17/d/l0338.jpg
          • FrederikF Offline
            Frederik
            I'm not sure that your hdri has the best quality... 😐
            I can only encourage you to try this scene, where you can take learnings from the material settings etc...
            (NB! please note the file-size is 83Mb, because it also contain a free hdri...)
            With the scene you should be able to get a render similar to this if you're using the latest Thea4SU plugin...
            Cheers
            Kim Frederik
            • usenU Offline
              usen
              Thank you very much for your concern, I'm trying. πŸ‘
              • NigeCN Offline
                NigeC
                Tomasz used frontal projection with his scene
                quick tut:
                Setup you scene with the car on a plan add the hdri,
                scale the plane so it reaches the horizon
                Hide everything and render the scene, save the image
                unhide everything
                add the previously rendered image to the plane
                open the thea dialog and double click on the image
                set the diffused slot projection to frontal
                close the mat lab
                do a test render, you'll find the background is slightly darker, set the background intensity to about 1.7, you may need to fiddle about a bit
                thats it πŸ˜„
                Here's the Thea version as a pack file, I don't have the SU file on this laptop
                pack file
                β€œIt’s only impossible if you stop and think about it!”
                • usenU Offline
                  usen
                  not in the same way as in sketchup shadow thea?
                  http://c1303.hizliresim.com/17/f/l0jhg.jpg
                  • FrederikF Offline
                    Frederik
                    You're mixing things up...
                    Please remember that the hdri will also be a source of the illumination...
                    Please take the advice Nigec have provided... πŸ˜‰
                    Cheers
                    Kim Frederik
                    • N Offline
                      notareal
                      If you want silhouette shadows is Thea, using frontal projection is the way to do it. But if simple "attaching" a model on a HDRI is enough then using shadow catcher is must.
                      • NigeCN Offline
                        NigeC
                        No you don't use a shadow catcher at all, it uses the actual geometry with a texture
                        here's a SU version
                        Su file
                        you can also add bump, and reflections, but you need to use masks
                        • NigeCN Offline
                          NigeC
                          here's a quick guide
                          frontal projection.pdf
                          • massimoM Offline
                            massimo Moderator
                            Hi Nige and welcome. πŸ‘ πŸ˜„
                            • NigeCN Offline
                              NigeC
                              Thanks massimo, I've been lurking for years so I thought it was a good time to say something! 🀣
                                rhed037
                                Frederik can you pls upload it again the scene with HDRI with the beetle car I want to learned it. tnx
                                • FrederikF Offline
                                  Frederik
                                  Sorry - but after almost two years, I don't have that scene any more... 😐
                                  What exactly is it you want to learn...?
                                  How to setup a scene in SU with a shadow catching material...?
                                  Or...?!?
                                  Cheers
                                  Kim Frederik
                                    rhed037
                                    i have same problem of the hdri when i render the shadow is not visible to the scene can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                    • FrederikF Offline
                                      Frederik
                                      @rhed037 said:
                                      ...can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                      Attached please find a very simple model with some spheres...
                                      THe render was complete in 16 seconds using the BSD preset...
                                      I've used the "Harbor 3" hdri from the HDRI Hub IBL package, which is free to download for registered users... πŸ˜‰
                                      Hope this can help you further...?!?
                                      Shadow-catch-test.skp
                                      Cheers
                                      Kim Frederik
