    HDRI problem Thea render
    extensions
    20 Posts 8 Posters 5.0k Views 8 Watching
    • usenU Offline
      usen
      How do I uninstall in the picture plane? 😞 Thanks.
      http://c1303.hizliresim.com/17/d/kzc0d.jpg
      http://www.sketchupturkiye.com/
      • V Offline
        Vicspa
        uncheck background in the environment tab.
        if you are talking about the ground plane the car is on, just delete.
        I hope I'm telling you the right thing.
        • soloS Offline
          Not sure what you are asking for is what you are pointing at, looks like you want to make that plane a shadow catcher, nor do I understand what the problem with the HDRi is as your arrow points to the ground.
          To fix the floor, make sure it's painted with a material (any) then using thea tools open the editor (material editor) clear material then select shadow catcher.
          • usenU Offline
            usen
            Thank you, but it's not like I want to shadow
            http://b1303.hizliresim.com/17/d/kzqsl.png
            • FrederikF Offline
              Frederik
              Can you elaborate...?
              How do you want it to be...?
              Based on the hdri you've used, I think the shadow looks as it should...
              Cheers
              Kim Frederik
              • usenU Offline
                usen
                I can not do the same thing this video, I'm not doing shadow
                http://b1303.hizliresim.com/17/d/l030q.jpg
                http://b1303.hizliresim.com/17/d/l0338.jpg
                • FrederikF Offline
                  Frederik
                  I'm not sure that your hdri has the best quality... 😐
                  I can only encourage you to try this scene, where you can take learnings from the material settings etc...
                  (NB! please note the file-size is 83Mb, because it also contain a free hdri...)
                  With the scene you should be able to get a render similar to this if you're using the latest Thea4SU plugin...
                  Cheers
                  Kim Frederik
                  • usenU Offline
                    usen
                    Thank you very much for your concern, I'm trying. πŸ‘
                    • NigeCN Offline
                      NigeC
                      Tomasz used frontal projection with his scene
                      quick tut:
                      Setup you scene with the car on a plan add the hdri,
                      scale the plane so it reaches the horizon
                      Hide everything and render the scene, save the image
                      unhide everything
                      add the previously rendered image to the plane
                      open the thea dialog and double click on the image
                      set the diffused slot projection to frontal
                      close the mat lab
                      do a test render, you'll find the background is slightly darker, set the background intensity to about 1.7, you may need to fiddle about a bit
                      thats it πŸ˜„
                      Here's the Thea version as a pack file, I don't have the SU file on this laptop
                      pack file
                      β€œIt’s only impossible if you stop and think about it!”
                      • usenU Offline
                        usen
                        not in the same way as in sketchup shadow thea?
                        http://c1303.hizliresim.com/17/f/l0jhg.jpg
                        • FrederikF Offline
                          Frederik
                          You're mixing things up...
                          Please remember that the hdri will also be a source of the illumination...
                          Please take the advice Nigec have provided... πŸ˜‰
                          Cheers
                          Kim Frederik
                          • N Offline
                            notareal
                            If you want silhouette shadows is Thea, using frontal projection is the way to do it. But if simple "attaching" a model on a HDRI is enough then using shadow catcher is must.
                            • NigeCN Offline
                              NigeC
                              No you don't use a shadow catcher at all, it uses the actual geometry with a texture
                              here's a SU version
                              Su file
                              you can also add bump, and reflections, but you need to use masks
                              • NigeCN Offline
                                NigeC
                                here's a quick guide
                                frontal projection.pdf
                                • massimoM Offline
                                  massimo Moderator
                                  Hi Nige and welcome. πŸ‘ πŸ˜„
                                  • NigeCN Offline
                                    NigeC
                                    Thanks massimo, I've been lurking for years so I thought it was a good time to say something! 🀣
                                      rhed037
                                      Frederik can you pls upload it again the scene with HDRI with the beetle car I want to learned it. tnx
                                      • FrederikF Offline
                                        Frederik
                                        Sorry - but after almost two years, I don't have that scene any more... 😐
                                        What exactly is it you want to learn...?
                                        How to setup a scene in SU with a shadow catching material...?
                                        Or...?!?
                                        Cheers
                                        Kim Frederik
                                          rhed037
                                          i have same problem of the hdri when i render the shadow is not visible to the scene can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                          • FrederikF Offline
                                            Frederik
                                            @rhed037 said:
                                            ...can you pls uplaod any model and ready to render in thea so that i can check what is wrong in my scene and follow your settings tnx
                                            Attached please find a very simple model with some spheres...
                                            THe render was complete in 16 seconds using the BSD preset...
                                            I've used the "Harbor 3" hdri from the HDRI Hub IBL package, which is free to download for registered users... πŸ˜‰
                                            Hope this can help you further...?!?
                                            Shadow-catch-test.skp
                                            Cheers
                                            Kim Frederik
