    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • SkeeterdS Offline
      Skeeterd
      Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
        tellkurt
        How would I install the plugin for Sketchup 2014 ?
        • fredo6F Offline
          The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
          Then, you can auto-install Bezierspline and all other plugins in one click.
            mamagroene
            so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
            • TIGT Online
              How did you install it ?
              Sounds like some files are missing...
              Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
              Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
              Restart after the installing to ensure everything is synchronized...
                antonio.calvo
                Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                • W Offline
                  witjazz
                  thanks
                  • Y Offline
                    yaseerr
                    like it thank you
                    • fredo6F Offline
                      NEW RELEASE 1.7a - 19 Oct 2014
                      This release is required for SU 2014 when your username contains non-ascii characters
                      Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                      Download new release at main post
                      • W Offline
                        WebBeau
                        Thanks a lot
                        • E Offline
                          Esense3d
                          Hello Fredo
                          I would like to translate this plugin on all German but can not find language files
                          Bezier spline is only partially translated
                          Fredo I now have this new address
                          Roland F Swiss
                          • fredo6F Offline
                            @esense3d said:
                            Hello Fredo
                            Roland F Swiss
                            Thanks for this proposal.
                            BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                            Anyway, the current version already includes a German translation.
                            • E Offline
                              Esense3d
                              Hello Fredo
                              I See but it is not Full Translated
                              Just Parts of it
                              I also have your other plugins translated fully ie including the main folder
                              and other
                              Therefore, any icons etcetera in German
                              If you want I send you these versions as rbz versions to
                              If you do not mind I would publish in the German part please
                              Roland F.
                              • fredo6F Offline
                                NEW RELEASE 1.7b - 22 Mar 2015
                                This release removes noisy traces at startup of Sketchup
                                • fredo6F Offline
                                  NEW RELEASE 1.7c - 23 Mar 2015
                                  This release removes noisy traces at startup of Sketchup - second trial
                                    rdcraighead
                                    This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                                    • G Online
                                      Gábor
                                      What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                                      • Rich O BrienR Online
                                        It's free.
                                        • MsketcherM Offline
                                          Msketcher
                                          I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                                          • N Offline
                                            NZSnowman
                                            Just downloaded. Can not wait to try. Looks great!
                                            • 22
                                            • 23
                                            • 8 / 23
