    1.5k Posts 471 Posters 3.4m Views 470 Watching
      tomot
      @fredo6 said:
      Tomot,
      What do you mean by inconsistent highlight?
      How should the corner and roundings be to be OK?
      I'm not being critical of the plugin, perhaps its a rendering issue.
      I'm trying to find out why the HDR light striking the rounded corners is not uniform along the rounded edge of each Tile as I try to show in the pic by the red line
      For example if I had a number of tiles with rounded edges sitting in sunlight, Each rounded edge along each tile would reflect the sun uniformly. not only for 1 tile but also all other tiles.
      my plugins
      tomot
      • N Offline
        nickcconnor
        Thanks Fredo6, your round corner plugin has been a wonderful tool - really solid and reliable - thank you so much.
        I was just wondering if there were any issues running this in sketchup 15, as it doesn't seem to install for me?
        Thanks again,
        Nick
        • cottyC Offline
          cotty
          It's 2015 compatible.
          my SketchUp gallery
            It's fine in v2015.
            Do you also have the latest LibFredo... ?
              kittiset
              thank you
                buinhuthuong
                thankyou
                • HieruH Offline
                  Hieru
                  Has anyone else found the plugin to be a but buggy with 2015?
                  I'm using the latest version (along with the latest LibFredo) and I regularly find that I can't select edges on basic shapes with one or all of the RoundCorner tools.
                  After restarting my PC everything usually goes back to normal, but the plugin will suddenly stop functioning at some point during a modelling session.
                  www.davidhier.co.uk
                    It's good one my end but I'm running very little enabled addons.
                      I use Round Corner quite frequently and I haven't seen any problems with it at all on SU2015. it has behaved very well.
                      • HieruH Offline
                        Hieru
                        @rich o brien said:
                        ...I'm running very little enabled addons.
                        Me either...I'm still in the process of adding them as needed. Maybe there is a conflict that didn't crop up in 2014, so I'll try disabling everything else and see what happens.
                        www.davidhier.co.uk
                        • HieruH Offline
                          Hieru
                          OK, so I've tried disabling all other plugins, but no luck.
                          I've also completely removed Round Corner and LibFredo from the plugin folder and reinstalled them. Again no luck....when I try anything other than Sharp Corners I get the warning "Invalid (Property filter)".
                          I haven't tried installing manually (without the Sketchucation tool).
                          www.davidhier.co.uk
                            Can you share or show an example mesh?
                            • fredo6F Offline
                              The message "invalid (property filter)" comes when you select an edge with NO face.
                              So you may want to inspect your model and see if there is no hidden edge defect.
                              • HieruH Offline
                                Hieru
                                Thanks guys, but I've solved the problem now.
                                For some reason the edge properties were set by default to 'soft' only. Not sure if that's a bug or a d'oh! moment on my behalf.
                                www.davidhier.co.uk
                                  Diago
                                  Hi there a question. Does Round Corner work on Sketchup 2015 on Mac? If so, how can I install it? thanks in advance.
                                  • RedFoxyR Offline
                                    RedFoxy
                                    Hi there.
                                    I have been looking through the topic but can't find any satisfying answer to my problem... I am working on Sketchup 2015 for mac and the RoundCorner plugin keeps crushing it pretty much every single time i try to use it... I have checked all my plugins and they're up to date, so is the v-ray version... Also don't have any error messages when I run the program. But all the plugin needs to crush is simply trying to select or unselect ANY line and bam - there's the bug splat... Any ideas what may be causing that? I'm running out of patience πŸ˜› 😑
                                      Try disabling the V-ray plugin and see if you still get the crash.
                                        Diago
                                        Red Foxy, do you have v-ray for SU 2015 for Mac? could you please upload the file? I really don't find any v-ray for SU 2015 for Mac.
                                        • RedFoxyR Offline
                                          RedFoxy
                                          Thanks for the quick reply... well, i did that, checked some edges, got all excited, added one more and well.. yeah. bug splat... 😞 So still no solution... Will probably try unchecking and trying all the plugins one by one, maybe i'll find something responsible for that πŸ˜• Thanks anyway for the suggestion...
                                          Yeah, got it from the chaosgroup website πŸ˜„
                                          http://www.chaosgroup.com/en/2/vrayforsketchup.html
                                            Maybe you could post the SKP file that you're trying to run Round Corner on?
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 73
                                            • 74
                                            • 66 / 74
