    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • HieruH
      Hieru
      Has anyone else found the plugin to be a but buggy with 2015?
      I'm using the latest version (along with the latest LibFredo) and I regularly find that I can't select edges on basic shapes with one or all of the RoundCorner tools.
      After restarting my PC everything usually goes back to normal, but the plugin will suddenly stop functioning at some point during a modelling session.
      www.davidhier.co.uk
        It's good one my end but I'm running very little enabled addons.
          I use Round Corner quite frequently and I haven't seen any problems with it at all on SU2015. it has behaved very well.
          • HieruH
            Hieru
            @rich o brien said:
            ...I'm running very little enabled addons.
            Me either...I'm still in the process of adding them as needed. Maybe there is a conflict that didn't crop up in 2014, so I'll try disabling everything else and see what happens.
            www.davidhier.co.uk
            • HieruH
              Hieru
              OK, so I've tried disabling all other plugins, but no luck.
              I've also completely removed Round Corner and LibFredo from the plugin folder and reinstalled them. Again no luck....when I try anything other than Sharp Corners I get the warning "Invalid (Property filter)".
              I haven't tried installing manually (without the Sketchucation tool).
              www.davidhier.co.uk
                Can you share or show an example mesh?
                • fredo6F
                  The message "invalid (property filter)" comes when you select an edge with NO face.
                  So you may want to inspect your model and see if there is no hidden edge defect.
                  • HieruH
                    Hieru
                    Thanks guys, but I've solved the problem now.
                    For some reason the edge properties were set by default to 'soft' only. Not sure if that's a bug or a d'oh! moment on my behalf.
                    www.davidhier.co.uk
                      Diago
                      Hi there a question. Does Round Corner work on Sketchup 2015 on Mac? If so, how can I install it? thanks in advance.
                      • RedFoxyR
                        RedFoxy
                        Hi there.
                        I have been looking through the topic but can't find any satisfying answer to my problem... I am working on Sketchup 2015 for mac and the RoundCorner plugin keeps crushing it pretty much every single time i try to use it... I have checked all my plugins and they're up to date, so is the v-ray version... Also don't have any error messages when I run the program. But all the plugin needs to crush is simply trying to select or unselect ANY line and bam - there's the bug splat... Any ideas what may be causing that? I'm running out of patience πŸ˜› 😑
                          Try disabling the V-ray plugin and see if you still get the crash.
                            Diago
                            Red Foxy, do you have v-ray for SU 2015 for Mac? could you please upload the file? I really don't find any v-ray for SU 2015 for Mac.
                            • RedFoxyR
                              RedFoxy
                              Thanks for the quick reply... well, i did that, checked some edges, got all excited, added one more and well.. yeah. bug splat... 😞 So still no solution... Will probably try unchecking and trying all the plugins one by one, maybe i'll find something responsible for that πŸ˜• Thanks anyway for the suggestion...
                              Yeah, got it from the chaosgroup website πŸ˜„
                              http://www.chaosgroup.com/en/2/vrayforsketchup.html
                                Maybe you could post the SKP file that you're trying to run Round Corner on?
                                • RedFoxyR
                                  RedFoxy
                                  the whole file is quite big, unless you mean a separate component then sure, but it crashes on things as simple as a cube.. I managed to get 2 surfaces rounded however it took me like 6 attempts or something πŸ˜„ this thing really teaches you patience.
                                  komoda 120x50x76.skp
                                    What edges are you trying to round over? And what values are you using for Offset and the Number of sides?
                                    Patience is good. πŸ˜‰
                                    • RedFoxyR
                                      RedFoxy
                                      Just the sides of the main box and the parameters were 2mm and 2 sides.
                                        OK. I just tried it on my computer and it worked fine. I only selected the front and back vertical edges and the bottom edge. How were you making the selection? Is it possible you were selecting the top edge where the round over has already been done?
                                        • RedFoxyR
                                          RedFoxy
                                          I don't think so, i just select the four vertical edges and try to run the roundcorner... As I said before, sometimes it works but it crashes on rather stupid moments such as unselecting a selected edge or something else as simple as that...
                                          Sometimes i feel like with sketchup patience is everything πŸ˜„
                                            I quickly redrew your cabinet and then rounded over the edges on the top and sides in one go.
                                            I double clicked with Select while holding the Ctrl key (Option on Mac) on all three sides in turn to select their edges and then ran the tool once.
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 74
                                            • 75
                                            • 49 / 75
