    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.6k Views 69 Watching
      @box
      I'm not seeing that occur for me
      • BoxB
        IT doesn't happen on all axis, I have yet to determine exactly when it happens, but I will pin it down.
        • BoxB
          Try this and see if it is just me.
          The patch is drawn up the blue along the red. Second patch added, joint moved up on the blue. Select the two edges(3 points) on the red and scale to 0.
          Please excuse the sloppy movements, I find it's very hard to maneuver on a trackpad.
          http://i155.photobucket.com/albums/s296/storeben/SU/Red.gif
            @pilou said:
            Do you get any errors in the Ruby Console?
            See my previous posts from here
            Messages were the same that the restant on my post linked πŸ˜‰
            So for have no message errors I disconnect plugins after plugins.
            Ah, there's something suspicious:
            Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in definition'
            Looks like this extension has injected itself into the system somewhere. Maybe it modified .definition. What happens if you remove that extension?
            (Also, where did you get that extension?)
              @cadfather said:
              ok, in my case progressbar.rb is the culprit
              now it's smartdrop
              it changes.. πŸ˜†
              Ah yes, progressbar.rb is also known. But wasn't that updated?
              Is smart drop also conflicting?
                @unclex said:
                @thomthom said:
                Re: [Plugin][WIP][OpenSource] Bezier Surface
                Postby thomthom Β» Mon Nov 24, 2014 4:18 am
                unclex wrote:It's just always updating...
                Like the GIF
                Cannot Click or DoubleClick
                and when SU opening, nothing prompt
                Any errors in the Ruby Console?
                What SketchUp version?
                Now I Know what happened
                Smartdrop clash with TTlib2
                something named "definition"
                so I change "definition" to "a4sddefinition" @ smartdrop.rb
                and it works
                [attachment=0:nay6raup]<!-- ia0 -->Smartdrop.rb<!-- ia0 -->[/attachment:nay6raup]
                Right, so this is what is happening:
                Smartdrop is modifying the SketchUp API classes - which is a Bad Thing (TM)
                class Sketchup;;Group
                  def definition
                    return(entities[0].parent)
                This method is bugged - it will fail when the group is empty because it tries to get the parent of the first entity in the entities collection. entities.parent would have worked though - so close. (But not perfectly in all older SU versions as there was a SU bug. There is a workaround for that, but that is not implemented here.)
                This is a good example of why modifying classes and modules that doesn't belong to your own extension is a bad thing. Before SU2015 it was adding a method that was not there, but as of SU2015 we added .definition for Group - meaning now it's also overriding the Ruby API.
                Was this the latest version of smart drop - or is there a new one that might have fixed this?
                  @jeff hammond said:
                  here's a simple introductory example.. maybe something a lot of people can use..
                  seamless background for rendering
                  Wow, tutorials already! 😲 I'm really baffled that people find it usable in any sense - considering it's so much that's missing.
                    @box said:
                    I found a little problem with it.
                    If you scale to 0 as a way of straightening an edge it freezes and won't update the surface. If you get out of edit mode and go back in an move a point it will revert to the unscaled skin.
                    Yea, I'm not surprised there are errors - I actually would have expected many more reports.
                    I'm going to guess that there are errors in the Ruby Console when your issue occur?
                    • BoxB
                      Yes indeed, was just looking at that. a long error I think repeated.
                      Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d> C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_patch_quad.rb:528:inintersect_line_line'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_patch_quad.rb:528:in interpolate_points' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_patch_quad.rb:553:in interpolate_interior'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_patch_quad.rb:262:in refresh_interior' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1046:in block in refresh_automatic_patches'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1044:in each' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1044:in refresh_automatic_patches'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1026:in update_after_transformation' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:427:in transform_entities'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/operator_gizmo.rb:105:in block in init_gizmo' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:65:in call'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:65:in block (2 levels) in initialize' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:319:in call'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:319:in block in initialize' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:1504:in call'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:1504:in onMouseMove' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:473:in onMouseMove'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb:156:in onMouseMove' C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/operator_gizmo.rb:70:in onMouseMove'
                      C:/Users/Ben/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/operator_manager.rb:56:in trigger_event'
                      It appears this keeps repeating, but I could be wrong.
                      Edit: on a second look it doesn't repeat, but is very very long.
                      • panixiaP
                        panixia
                        i bet what people could do out of Sub-d "as it is" would be even more surprising πŸ˜›
                        • PixeroP
                          Pixero
                          I have one request that would make it much more useful.
                          Add support for editing without messing up UVs like your vertex tools works.
                            Thanks for posting the error message.
                            • pbacotP
                              So are there instructions or tutorials for this?
                              • jeff hammondJ
                                heh.. i was just thinking it was a way to show the scale/rotate/move options available via the gizmo.. also a way to point out that using a radius isn't the best way to build a psyche wall..
                                tangent blends aren't the smoothest since they abruptly change from one direction to another and you will see a more defined line in light/reflections.. you want something that eases into the transition.. bezier surface provides this type of blend (a little more control/ snapping of control points is necessary but as is, it still gets the job done.)
                                here's a tangent fillet vs one with G3 continuity for example:
                                radius fillet on the left -- G3 on the right
                                  Error: #<NoMethodError: undefined method `parent' for nil:NilClass>
                                  C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in `definition'
                                  Removed and all works fine πŸ˜‰
                                  This extension is from a French developper πŸ˜‰ Cplassais
                                  Look his other plug at PluginStore ColorEdge
                                  he made also Explode View (with me πŸ˜‰
                                  And numerous other ones it site
                                    Not much. I basically released this because I haven't been keeping up development lately. So I had thought it was more of a preview and perhaps invite some developers to perhaps contribute in an open source project. However it appear to have drawn a bit more attention than I expected.
                                    There are a couple of videos, though I'm not sure if they are visible in the PluginStore - at least I could not find where they ended up. Though they should be linked in this thread, and on the EW description page. You'll also find them from my YouTube channel.
                                    But they really are just teasers and not how to.
                                    I'm also about to go on vacation for a week so I'll be slow to respond and won't be able to produce anything soon. (I'm in short of time in general.) Meanwhile I'd encourage people to share their experiences on the forum.
                                      But the one that cause problems, that not publicly available? I was hoping to be able to inspect it and then see if I could reach out to the author and ask that he can release a new version that doesn't conflict.
                                        Got a wireframe of that mesh? I'm curious to what makes out the difference. (I'm wondering if my SUbD tool might address that.)
                                          Components on face by CPlassais
                                          • jeff hammondJ
                                            the render mesh looks like this:
                                            the tangent one has all facets at equal angles/sizes whereas the g3 blend starts off mellower then gradually tightens..
                                            at the highest end, this stuff only really matters if you're designing surfaces for cars etc but at the midTOlow end, some of it can & should trickle down into sketchup/architecture/furniture/etc.
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
