    Question about thumbnails
    29 Posts 7 Posters 1.9k Views 7 Watching
    • KrisidiousK Offline
      Krisidious
      There is a setting in model info to save thumbnails... I suppose if it had never been on before you would not get a thumbnail... Maybe...
      By: Kristoff Rand
        mrossk
        No luck there either (Under Model Info/File there is "redefine thumbnail" but it's checked) Curious and a bit annoying.
        https://www.mkaplanfinefurniture.com/
          64-bit or 32-bit?
          Would it help if I just make a screen shot of my thumbnails and you can look at them instead? πŸ˜„
          • hellnbakH Offline
            hellnbak
            Probably a dumb question, but have you tried all the options here?
              mrossk
              I'm not familiar with that menu. Where is it?
                @helnbak
                those are options related to Mystic Thumbs and not part of the Windows OS
                • hellnbakH Offline
                  hellnbak
                  Well, just click on the File option, and it should list Thumbnail, click on it
                  • hellnbakH Offline
                    hellnbak
                    @rich o brien said:
                    @helnbak
                    Yeah, I knew it was Mystic Thumbs, just thought I would throw it out there FWIW
                      mrossk
                      oh, gotcha. I have regular non-mystic thumbs. Boring, but they've served me well
                        mrossk
                        Here's another possible clue. If in the file menu, I click "show all files" instead of just "skp" files, the few backup files ("skB),show their thumbnails. So the SKB files have thumbnails, but the regular SKP do not. That seems weird.
                          mrossk
                          One more thing- I've noticed that the same issue applies to PDF files on my computer. I used to see thumbnails of those files, now I just see a big "PDF" logo. I imagine this must be some Windows or Explorer setting. Anyone familiar with the behind-the-scenes workings to give me a heads up?
                            Krisidious
                            What exact OS are you on? What bit? I take it 64bit... Is it an upgrade or a full install. If you're having issues with seeing thumbnails on multiple programs I would say it's not SU related. Have you tried running windows installer again and giving windows a fresh start on system files?
                            When is the last time you saw thumbnails? was it recently? what have you installed in the meantime?
                            http://windows.microsoft.com/es-es/windows-vista/turn-back-time-on-your-pc-undo-system-changes-with-system-restore
                            By: Kristoff Rand
                              On a 64bit PC with SketchUp v2015 Pro the Registry entry:
                              HKEY_CLASSES_ROOT\.skp\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}
                              Should have the Default value of:
                              {A86C8053-587B-4dfb-A5E2-54E9803E4463}
                              Which in turn is a reference to SketchUp's ThumbsUp.dll [the one in the Layout folder, NOT the SketchUp folder!]...
                              You can copy that 'value' in full from the .skb entry !
                              I found on mine it was set incorrectly.
                              I changed it as set uout above and now the thumbnails appear for SKP files...
                              Edit the Registry with Run > regedit at your own risk !!!
                                Krisidious
                                Tig, yours was set incorrectly during factory install? Or it just happened somehow?
                                By: Kristoff Rand
                                  It was just wrong 'somehow'.
                                  I did NOT initially get any thumbnails in v2015 64bit, but that Registry tweak fixed it.
                                  Obviously, I had not previously been getting thumbnails in 32bit v2014 on the 64 bit PC as they are not compatible...
                                  If I recall that Registry entry was either not set up with any 'value', or perhaps it was referring to a wrong 'value' - I can't recall - anyway, it now works ! πŸ˜„
                                  It's odd that the ThumbsUp.dll path that is referred to in the convolutions of the Registry is to the one in the Layout folder rather than then one in the SketchUp folder - but I see it's the same in v2014 too... πŸ˜•
                                  What values do you get for that Registry entry?
                                  I think they are common across 64bt PCs...
                                    Krisidious
                                    But, I bet you were Beta huh? you could have had an old install of 2015 put something funky in.
                                    I'll check mine.
                                    Currently, I have large thumbs for any newly saved files, but all small thumbs for older files. Need a batch program to update all the thumbs.
                                    By: Kristoff Rand
                                      2015M1 is out in the download area - a poor-do by Trimble who have failed to announce it for three days !
                                      Does your SketchUp.ShellExtension point to the logical ThumbsUp.dll or the Layout one ?
                                      Under CLSID ?
                                        Krisidious
                                        logical ThumbsUp.dll it's value is {A86C8053-587B-4DFB-A5E2-54E9803E4463}
                                        By: Kristoff Rand
                                          That is the "illogical" dll !
                                          If you do a find based on that string, it takes you to a Layout path !
                                          There are two of these dll files supplied with a SketchUp installion, one in the Layout folder and another in the SketchUp folder.
                                          One might have thought that the SketchUp folder one would be referred to regarding SketchUp's SKP thumbnail display, and not the Layout one - although they do appear to be identical !
                                          This odd path is set up like this in v2015 and v2014 !
                                          The string '\ThumbsUp.dll' only ever appears in conjunction with a 'Layout' path, AND it is linked back to SKP etc...
                                          It never appears connected to SketchUp directly !
                                            Krisidious
                                            Mine is set correctly and I got it the day it was released. I don't recall any updates as of yet. I'm on Win 7 Ultimate 64bit.
                                            By: Kristoff Rand
