    Question about thumbnails
    29 Posts 7 Posters 2.5k Views 7 Watching
      64-bit or 32-bit?
      Would it help if I just make a screen shot of my thumbnails and you can look at them instead? πŸ˜„
      • hellnbakH
        hellnbak
        Probably a dumb question, but have you tried all the options here?
          mrossk
          I'm not familiar with that menu. Where is it?
          https://www.mkaplanfinefurniture.com/
            @helnbak
            those are options related to Mystic Thumbs and not part of the Windows OS
            • hellnbakH
              hellnbak
              Well, just click on the File option, and it should list Thumbnail, click on it
              • hellnbakH
                hellnbak
                @rich o brien said:
                @helnbak
                Yeah, I knew it was Mystic Thumbs, just thought I would throw it out there FWIW
                  mrossk
                  oh, gotcha. I have regular non-mystic thumbs. Boring, but they've served me well
                    mrossk
                    Here's another possible clue. If in the file menu, I click "show all files" instead of just "skp" files, the few backup files ("skB),show their thumbnails. So the SKB files have thumbnails, but the regular SKP do not. That seems weird.
                      mrossk
                      One more thing- I've noticed that the same issue applies to PDF files on my computer. I used to see thumbnails of those files, now I just see a big "PDF" logo. I imagine this must be some Windows or Explorer setting. Anyone familiar with the behind-the-scenes workings to give me a heads up?
                      • KrisidiousK
                        Krisidious
                        What exact OS are you on? What bit? I take it 64bit... Is it an upgrade or a full install. If you're having issues with seeing thumbnails on multiple programs I would say it's not SU related. Have you tried running windows installer again and giving windows a fresh start on system files?
                        When is the last time you saw thumbnails? was it recently? what have you installed in the meantime?
                        Invalid URL
                        (windows.microsoft.com)
                        By: Kristoff Rand
                          On a 64bit PC with SketchUp v2015 Pro the Registry entry:
                          HKEY_CLASSES_ROOT\.skp\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}
                          Should have the Default value of:
                          {A86C8053-587B-4dfb-A5E2-54E9803E4463}
                          Which in turn is a reference to SketchUp's ThumbsUp.dll [the one in the Layout folder, NOT the SketchUp folder!]...
                          You can copy that 'value' in full from the .skb entry !
                          I found on mine it was set incorrectly.
                          I changed it as set uout above and now the thumbnails appear for SKP files...
                          Edit the Registry with Run > regedit at your own risk !!!
                          • KrisidiousK
                            Krisidious
                            Tig, yours was set incorrectly during factory install? Or it just happened somehow?
                            By: Kristoff Rand
                              It was just wrong 'somehow'.
                              I did NOT initially get any thumbnails in v2015 64bit, but that Registry tweak fixed it.
                              Obviously, I had not previously been getting thumbnails in 32bit v2014 on the 64 bit PC as they are not compatible...
                              If I recall that Registry entry was either not set up with any 'value', or perhaps it was referring to a wrong 'value' - I can't recall - anyway, it now works ! πŸ˜„
                              It's odd that the ThumbsUp.dll path that is referred to in the convolutions of the Registry is to the one in the Layout folder rather than then one in the SketchUp folder - but I see it's the same in v2014 too... πŸ˜•
                              What values do you get for that Registry entry?
                              I think they are common across 64bt PCs...
                              • KrisidiousK
                                Krisidious
                                But, I bet you were Beta huh? you could have had an old install of 2015 put something funky in.
                                I'll check mine.
                                Currently, I have large thumbs for any newly saved files, but all small thumbs for older files. Need a batch program to update all the thumbs.
                                By: Kristoff Rand
                                  2015M1 is out in the download area - a poor-do by Trimble who have failed to announce it for three days !
                                  Does your SketchUp.ShellExtension point to the logical ThumbsUp.dll or the Layout one ?
                                  Under CLSID ?
                                  • KrisidiousK
                                    Krisidious
                                    logical ThumbsUp.dll it's value is {A86C8053-587B-4DFB-A5E2-54E9803E4463}
                                    By: Kristoff Rand
                                      That is the "illogical" dll !
                                      If you do a find based on that string, it takes you to a Layout path !
                                      There are two of these dll files supplied with a SketchUp installion, one in the Layout folder and another in the SketchUp folder.
                                      One might have thought that the SketchUp folder one would be referred to regarding SketchUp's SKP thumbnail display, and not the Layout one - although they do appear to be identical !
                                      This odd path is set up like this in v2015 and v2014 !
                                      The string '\ThumbsUp.dll' only ever appears in conjunction with a 'Layout' path, AND it is linked back to SKP etc...
                                      It never appears connected to SketchUp directly !
                                      • KrisidiousK
                                        Krisidious
                                        Mine is set correctly and I got it the day it was released. I don't recall any updates as of yet. I'm on Win 7 Ultimate 64bit.
                                        By: Kristoff Rand
                                        • KrisidiousK
                                          Krisidious
                                          Sorry Tig... I messed up that screenshot somehow. look again. I fixed it.
                                          CLSID has a default value of {A86C8053-587B-4DFB-A5E2-54E9803E4463}
                                          be it logical or not I have no idea. I do have thumbnails in Explorer, SU Import and SU Open/Saveas though.
                                          By: Kristoff Rand
                                            That {A86C8053-587B-4DFB-A5E2-54E9803E4463} refers to the ../Layout/ThumbsUp.dll, which seems illogical as it's setting up a SketchUp SKP thumbnail AND there is a ../SketchUp/ThumbsUp.dll
                                            It works but it makes no sense !
