    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
    • jeff hammondJ Offline
      @rich o brien said:
      Ur more than welcome.
      I imagine you'll get lots of mileage outta this?
      probably.. for me, it seems great to quickly mess around with new shape ideas.. like clay in a way..
      [edit]
      it's the controller (widget, gumball, whatshername) that makes it so fast.
        The song from Ghost is in my head now.
        • pbacotP Offline
          There's a procrastinators beware message... Hand it over!
          Glad it's available in the SCF pluginstore.
            lucky for me i'm on a super crappy connection right now so i can't be arsed to youtube the scene.
              At least! β˜€
              Brilliant! 😎
              Works on the 2014?
              Seems not! 😞
              Impossible to valide the second point of the patch!
              I have the last TT_lib2
              Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in definition'
              C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/instance.rb:23:in definition' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1129:in update_mesh'
              C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:159:in update' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/tool_create_patch.rb:142:in onLButtonUp'
                Seems in 2014 no compatibility with SketchyPhysics 3, Scalp
                Patch is drawn with the grid
                but now i have just the menu one time on the right Click
                then no possibility to edit the patch! πŸ˜‰
                Just this on the Ruby Console
                nextFrame()->updateMainWnd()
                • BoxB Offline
                  What an outstandingly wonderful tool.
                  http://i155.photobucket.com/albums/s296/storeben/genie.gif
                    For any reason after relaunch SU that works! πŸ˜’ 😎
                    Waiting the manual for translate it in French! β˜€
                      AcesHigh
                      how come I totally missed this plugin for 4 years? It should be on the list of essential plugins!
                      • cottyC Offline
                        cotty
                        Maybe because Thomthom published it yesterday πŸ˜‰
                        my SketchUp gallery
                        • PixeroP Offline
                          Pixero
                          Thanks, will come in handy for all those soft surfaces.
                          • jolranJ Offline
                            jolran
                            This is so cool!
                            I'm not gonna get any work done now playing with this πŸ˜„
                            How do you add Tripatch to Qaudpatch ? Possible ?
                            • jolranJ Offline
                              jolran
                              Some really nice editing capabilities there, with the Gizmo and all. WOW! 😲
                              So you decided to release it non commersial, huh ?
                              For some time now I have been working on curves and surfaces for my node editor, maybe
                              I can try making it compatible with you patches as well, now that your code is in public...
                              That would be cool to use your tools after baking down geometry..
                              Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                              Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                              • BoxB Offline
                                Select the edges you want to add to then click add patch and it will follow the shape.
                                http://i155.photobucket.com/albums/s296/storeben/SU/Adding.gif
                                • jolranJ Offline
                                  jolran
                                  Yes I noticed that. But Tripatch ?
                                  edit: ah, it may not be included yet. There are some things not added in this version.
                                  Doesent matter. Bloody marvelous anyway πŸ‘
                                  • BoxB Offline
                                    Sorry About that Jolran, I misread your question, didn't realise it was specifically the tris you were after.
                                    In case anyone is wondering how useful and fast this is to work with.
                                    This rough test torso is less than five minutes work.
                                      Rodin! πŸ˜„
                                      • jolranJ Offline
                                        jolran
                                        No worries πŸ˜„ Nice chest.
                                        • panixiaP Offline
                                          panixia
                                          it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
                                          i suppose i installed it properly and also updated ttlib to last version..
                                          i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
                                          • jolranJ Offline
                                            jolran
                                            Same here. I only had it working in 2014.
                                            Error "defined method `force_encoding' for #String:0xb10993c"
                                            This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
                                            • 12
                                            • 13
                                            • 7 / 13
